you would have to get ahold of duo-fast directly here is there site Duo Fast Request Info fill out the form to request a manual for your type of nailer
Your gun uses 22 degree round head plastic strip nails. Most likely nail that is easy to find in stores is 21 degree nails for Hitachi , Duo Fast and others. Both work ok.
The manual for your gun specifies 34-degree nails from 2 to 3 1/2 inches long. 28-degree, wire collated nails are a Stanley-Bostitch thing and they only work in their nail guns, they will not work in your nail gun. You need 34-degree, paper-tape collated nails. I know Senco framing nails will work in your gun and I think Duo-fast makes 34-drgree nails but check that before buying them.
Use 34 degree, paper collated, clipped head nails. They were always the most common strip nails years ago as Senco, Paslode, and a number of other nailers used them.
No... it will fire 21-degree nails and perhaps 23-degree nails (but sont think they exist) and it is a full-head framing nailer so it is designed for firing round head nails. Using clipped nails will likely jam the nailer as these nails are stripped closer together with overlapping heads in the nail strip and the FR350A has a full round driver so you will run into issues with clipped nails. If you are having problems finding full round head nails, you can find them on Amazon to fit this nailer. Otherwise any good tool or trade tool store that sells nailers will likely have a suitable nail supply available for the FR350A.
The problem will reside in the nail chamber. Most likely you have junk there or a scored feed area. Check the plunger and feed area for dirt and/or scoring to determine what exactly is holding up your advancing of strip nails.
if thats a hitachi nr90ad, then you should be using 30 degree paper taped clipped headed nails,, never use plastic or wire collated nails in that gun,, some boxes might say 30 up to 34 degree and thats fine, also in a lot of areas clipped headed nails are no longer code, so they made the nails full headed, the head is just off set,,
The F28WW takes 28Deg nails that are collated with wire, so your nails won't work in that gun. The N80SB is also a 28Deg nailer so your 30 Deg nails won't work in that gun either.
Sorry about the bad news but it looks like your going to have to spring for new nails
