Question about Canon PowerShot SD950 IS Digital Camera
My Canon SD950is camera asks me to submit time/date info every time I turn on the camera. The manual says this means the internal battery is depleted and needs to be recharged. I have a fully charged battery on board and still get the message. Any ideas?
Posted by rschlamer on
Anonymous
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 198 Answers
Yes I get something similar with my Panasonic camera just because I take the battery out when the camera is waiting for the next outing, but it is ok as soon as I set the clock and if I leave the battery in. From what you said then perhaps the internal battery is faulty but if you don't usually leave the battery in, you could try leaving the battery in for a few days to see if that restores some power to the internal battery.
Posted on Dec 12, 2010
1helpful
Time/date won't retain
The camera's internal date/time "backup" battery is supposed to maintain the date/time for about 3 weeks with the camera turned off. If the camera is not used for a longer period, the date/time will need to be reset. If you are having to reset sooner than that, it is likely that the internal battery (not user replacable on most models) has failed.
1helpful
2answers
Every time I turn on camera it ask to set date,
The Time/Date battery is a small round lithium battery the size of a dime in the battery compartment. You can get the numbers off it and buy one at Walmart or Ebay.
Instructions for replacing it:
http://www.manualslib.com/manual/275745/Canon-Powershot-Sx10-Is.html?page=267
When I turn on the camera, it ask me to set date and time
You can try and get a specialist repairer to change the battery, these are precision items and difficult to repair yourself. I would just live with it.
1helpful
4answers
Everytime I turn on my camera it asks me to set date/time. It goes to the default date/time setting of 00.00.0000 00:00 mm/dd/yy. What do I do to set the date/time so that it permanent? The photos are...
It takes around four hours for a freshly charged main battery to charge the internal backup battery. It you do that and it still doesn't charge it, you need a new internal battery. The fully charged internal battery in most of them will hold the charge for up to 3 weeks with the main battery out of the camera.
3helpful
I have an Olympus 850sw and each time I turn it on it asks to enter the date and time. Why is that?
Most of the cameras with a date time clock have a secondary internal power source like a small watch type battery some point and shoot cameras use a storage cell which takes power from the main battery. This means when the main battery looses power the camera clock will hold a setting for about 1 day or 24 hours. To keep the camera clock set you need to keep a charge in the main battery. Here is a screen shot from the manual explaining this function.
No memory card, set time
The date/time battery is "built in" (not replaceable) to this model according to page 13 in the manual (available here). It is supposed to recharge when you have the regular battery installed, but if you leave the regular battery out for more than "approximately three weeks", the internal battery may go flat.
I'm not sure this has anything to do with the memory card issue, though. Check the battery problem by inserting a freshly charged battery, turning on the camera and setting the correct date and time, then turning off the camera and waiting an hour or so (with the main battery still in the camera). Turn the camera back on, and if the date and time have to be reset again, your internal battery may be bad, and the camera would need to be serviced.
Date and time
WHY DOES MY CAMERA DELAY SNAPPING PICTURES. I HAVE TO WAIT A LONG TIME WHEN SNAPPING A SERIES OF PICTURES.
Canon A450 internal battery problem?
There are cameras with 'fixed' internal batteries to maintain date/time they are long lived and not usually replaceable.
If this is such a model and it is new then a replacement should be forth coming from the vendor or Canon.
The vendor is the first stop then Canon support
Canon PowerShot SD950 IS Digital Camera Logo
Top Canon Cameras Experts
old marine
old marine
Steven Wander
Steven Wander
nexrad_chris
Are you a Canon Camera Expert? Answer questions, earn points and help others
