Question about 2wire (1000-400108-001) Router
Will an at&t 2wire wireless router work on the windstream isp
Posted by wracing69 on
5 Related Answers
Anonymous
  • 5 Answers
SOURCE: 2Wire router
if your wireless connection is not working even if the wireless light is lit up on ur 2wire modem/router....try to delete the 2wire network from the prefered list...go to network connection, right click on wireless netwrok connection, go to properties and click on wireless network..select the 2wire netwrok on the prefered list and remove..reconnect to the network by clicking on view available wireless netwrok and select the 2wire network again...if its asking for a WEP key or password take a look at the bottom on the modem a 10 digits number enclosed in brachets..thats the network or wep key. access 192.168.1.254 and click on home network, got to wireless settings---edit settings...change ur wireless channel to 10 adn power settings to 10, save ur changes=)...ohh and by the way make sure that the wifi switch of ur laptop is turned on=)
Posted on Jun 29, 2007
Anonymous
  • 556 Answers
SOURCE: Connecting a netgear wireless router to a 2wire
Are the router addresses assigned on the same subnet?
many routers have a base address of 192.168.0.1 and a subnet mask of 255.255.255.0 meaning all addresses 192.168.0.? are part of their network.
One problem can be that both routers can be using the same subnet -- not an issue if they are connected to different connection points (such as two different houses) on the internet. However when connected to each other in your house they are confused because they have the same two different networks with the same addresses. -- for slightly different reasons --
For those that want you to connect from one router to the wan of the other you need to assure the base addresses are in different subnets -- assuming the one connected to the internet is addressed as 192.169.0.1 with a subnet mask of 255.255.255.0 his network as stated before is all addresses 192.168.0.?. Change the second router to a base address of say 192.168.2.1 with a subnet mask of 255.255.255.0 his network is everything staring 192.168.2.? they are now different and it should work. On the wan side of the router you can assign a unique 192.168.0.? address not in the DHCP range of the first router or accept a dynamic IP address from the first router. The dynamic address is probably the easier and less problematic of the solutions.
For those wanting you to connect to a lan port and ignore the wan port they should also have asked you to turn off DHCP in the second router (where you do not use the wan port) and allow the first to do all the dynamic network address assignments. In this case you could have two DHCP servers on the network competing to assign possibly the same network addresses -- if they have overlapping ranges duplicate addresses could be assigned resulting in device connection issues for those with duplicate addresses. Even in this case you may need to assure the gateway addresses are unique on the network ie of both routers are addressed as 192.168.0.1 the second where the WAN is not used could become 192.168.0.2 (where that address is not in the active DHCP server's assignment range) or 192.168.2.0 (note the DHCP server had better be off or else the empty wan port 192.168.2.0 could become the "gateway" address of attached PCs and since there is no connection there will be no access to the internet.
I hope this helps
It is quite likely either solution could work if all the proper changes were made.
Posted on Dec 15, 2007
Anonymous
  • 53 Answers
before you connect the netgear router to your 2wire modem, you have to get the modem configured first. you did not include the firmware version of your modem (firmware version is found at the UI, go to gateway.2wire.net, click on the system icon.) for firmware version less than 3.7, go to homeportal/management, click on configure services, uncheck enable routing, then click on submit. for version 3.7 or higher, go to homeportal/management, click on configure under broadband link, put a dot in disable pvc search, set VPI to 0 & VCI to 35, the connection type box should be direct IP, then click on submit. then go to configure services, uncheck enable routing box, then click submit. you will notice the broadband link on the 2wire modem turn orange/amber, then you have successfully set the modem to bridged mode. that way you can now connect the router according to manufacturer's instructions (or just read the manual for the netgear router....)
Posted on Apr 03, 2008
Anonymous
SOURCE: ISP problem with 2wire 2700HG-B
When I purchased the same router on Amazon I did my best to set it up on my own, but you need the correct IP information you can only get from your customer support at AT&T. I'm using this router with an old Airport card in an 2003 iBook and a 2007 iMac (built in Airport express card). The set-up was all done wirelessly, with bellsouth (AT&T) customer service instructing me over the phone, the process took about 15 minutes.
My suggestion is to call AT&T and speak with someone who knows what their doing, and they do use the SBC global page to set up the unit, starting with http://192.168.1.254/ for the system summary, from there you can set up your password etc...
Posted on May 24, 2008
marked
Mark Gil
  • 6487 Answers
SOURCE: CAN A 2WIRE DSL ROUTER WORK WITH A CABLE INTERNET CONEECTION
The 2wire dsl modem/router cannot be use with a another cable modem , since this 2wire device is also a modem/router and its made for the DSL conenction that's why it wont work with Cox cable, the best thing that you can do is to ask Cox to give a wireless modem/router like this 2wire so you can still use the wireless connection of your computer..
Hope that helps..........
Posted on Sep 06, 2008
My 2WIRE router won't give out wireless signal.
Unplug the ISP modem and the 2wire, Check ALL cables and reseat connections, plug in the ISP modem, wait for selftest, plug in wireless, wait for selftest, does your wireless SSID show in Available Wireless Networks on the Laptop? Can you connect using a Ethernet cable to verify it's getting a signal? Contact your ISP and have them verify the signal, have a ISP tech come out to analize the signal, it may be outside?
Feb 07, 2013 | 2wire Computers & Internet
If I wanted to download Maplestory(PC Game) how long would it take to download if I'm getting my internet connection from my 2wire (2701HG-B) Wireless Router
It all depends on the package & line speed you choose from your ISP ( Internet Service Provider )
http://www.speedtest.net/ this site will give an idea of your connection speed to the internet
the download size is 2.1gb so u can work it out after doing the test
May 27, 2011 | 2wire (2701HG-B) Wireless Router
How do I forward a port on my 2wire970 router.
The sad answer is that you really can't forward a port on 2wire equipment. Since the hardware is provided by the ISP they only give you basic settings (security keys, firewall etc). There are advance features you can hack into (http://www.mydigitallife.info/2007/04/29/advanced-configuration-page-for-2wire-homeportal-residential-router-gateways-singtel-mio/) but I wouldn't recommend it. If you do the advanced settings and mess anything up they may charge you for the router or cancel your service. The easiest solution is to get a personal router that supports port forwarding and just connect it to the 2wire router you already have or just replace it with the ISP (if it's a wireless router) for a normal box.
Apr 03, 2011 | 2wire (1000-400108-001) Router
I do not know anything about wireless connections. I have bought a new Samsung TV an want to hook wireles to my pc. The service I use is Windstream and I have a wireless modem now. It is a 2wire modem what...
You will need to check the wireless settings of the router
is there any computer connected to the router ?
If yes then you can open the router set up page on that computer.
Router set up page is the page where you can check all the wireless settings of the router.
once you get all the wireless settings of the router you can try to connect to the wireless network on the samsung TV
Click here for step by step instructions on how to check the settings on the router
Jan 10, 2010 | 2wire HomePortal® 1800HW Router...
Belkin router is unable to connect to 2Wire ADSL modem/router. 2Wire router has DHCP server enabled and Belkin has DHCP server disabled. Belkin is set to obtain an IP automagically. 2Wire IP is...
If the Internet light is off then there is a problem with the phone line to the ADSL modem or the modem is faulty or there is a problem at the telephome exchange.
Disconnect the phone cable at the ADSL modem and connect a phone handset to this cable - check for a dial tone and that you can dial out.
If you don't get a dial tone, use a different or new phone cable.
If the phone line is OK then : -
Ring your ISP to get them to test your connection to your ADSL
modem.
Oct 17, 2009 | 2wire Wireless-G 802.11g ADSL Gateway
Wirless router not working
it seems to be a problem with your ISP.May try these steps.
1. disconnect the router from the computer and the modem.
2. now connect the Ethernet cable to the modem & to the computer and see if that works.
else contact your isp.
for more help.
moz-screenshot.pnghttp://www.ikarmatech.com
Sep 08, 2009 | 2wire (1000-000005-002) 802.11g/b Wireless...
Linksys wireless adapter won't auto connect to 2Wire router
Go into the wireless adapter settings and make your connection "default" and then it should connect automatically .. and if not then look for a "connect automatically setting
May 29, 2009 | 2wire HomePortal® 1800HW Router...
2wire 2700HGV cannot detect wireless Linksys IP camera WVC54GC
Purchase a different router and return the 2wire to the ISP explaining it is not compatible with your equipment at home. You may need to provide them with the new router's MAC address.
Nov 21, 2008 | 2wire 2700HG-B Router (2700HGB)
2wire (1000-400108-001) Router Logo
170 people viewed this question
Top 2wire Computers & Internet Experts
efs_perpends
efs_perpends
Mike
Are you a 2wire Computer and Internet Expert? Answer questions, earn points and help others
