I recently had a similar problem where the vacuum would turn on but the brush would not rotate. I could hear the motor turn on and the belt was in tact, but the brushes would not turn. I took out the brushroll and it would not turn by hand either. There is a white cap on one end of the roll and a black one on the other. Use a hammer and a punch (or sturdy screwdriver) on the metal rod from the white end to knock the metal rod out of the roll. There is a bearing and wave washer on each end. I cleaned all of the hair and gunk out of both bearings and it rotated much better. I actually bought a couple of new bearings (trade # 608 - same size as what's in rollerblades) and lightly sanded the surfaces where the roll and caps meet so I hopefully won't have to do this again for a while. I heard of people putting WD-40 on the rims of the caps, but I wouldn't recommend this because I don't think the plastic would react well to it. Hope this helps.
Mine did this and I found I had blown the micro switch. I removed the two leads from the micro switch, located just above the motor, then connected them together with a wire. The brush ran fine. The switch is only 5 amps and I burned it out like a fuse when the brushes were caught by a throw rug. Hope this help. Ps please disconnect the plug before connecting and disconnecting the switch.
SOURCE: Bissell Lift Off pet revolution vacuum losing suction
You may have a clog in the hose. Unhook the hose and see how the suction is there, if ok, then check the dirt inlet by the brush roll. If suction is low at the hose, then there is a clog in it.
SOURCE: hair gets stuck in upper
Check both filters. If one or other is increasingly dirty, wash or clean it out. Also check the air waves leading to the bagless bin canister part. If one air way is blocked the remaining dirt will try and access the bin other way due to the natural vacuum suction aspect.
SOURCE: Troubleshoot Bissell Lift-Off Revolution Pet Vacuum Cleaner
I assume you mean the vacuum motor isn't running, could be the switch, cord or the motor, If you are able, I would start with the switch.
SOURCE: Bissell 6595-1 with broken electrical connector
I had the same problem with the Bissell 3750-T. I read these postings and I called Bissell. They had me check the connector and it was burnt and missing a pin. They are going to send me a prepaid shipping label to return the power cord and they are going to send me a new vacuum.
SOURCE: I have a Bissell lift-off revolution. The power
I have the same issue too. Brush motor is working and brush is turning on but the vaccum motor is not working. If I take the canister out of the frame then it wont turn on at all. Any help?
