Step A. Set the floating element ring to its' infinity position (if you are using extension tubes, this will vary and you must set according to the tubes).
Step B. Focus the camera on your subject.
Step C. Look at the bellows scale on the camera body (it will generally range from 0-40) Important: Don't read the scale akin to the lens you are using. This will make perfect sense, when you examine the bellows. Mentally record this number.
Step D. Adjust the floating element ring to the recorded number.
Step E. Leave the ring on this new setting and re-focus the camera on your subject.
Step F. Make sure the dark slide is removed and capture your photograph. :)
- That's it mate. Not so foreboding, when you
