Casio Exilim Pro EX-F1 Digital Camera Logo
A
Anonymous Posted on Dec 12, 2010
Casio pro 200 keyboard - Casio Exilim Pro EX-F1 Digital Camera
(Wk-200) Volume wheel spinning all the way around and not stopping at "min" or "max"
If the volume wheel on your Casio WK-200 keyboard is spinning all the way around and not stopping at the "min" or "max" positions, it is likely that the potentiometer that controls the volume has become faulty or damaged. A potentiometer, or pot for short, is a type of variable resistor that is commonly used to control the volume on electronic devices.
Here are a few troubleshooting steps you can try:
  1. Power off your keyboard and unplug it from the power source.
  2. Remove any batteries from the battery compartment.
  3. Locate the volume potentiometer inside the keyboard. It should be near the volume wheel and will have three pins or legs.
  4. Check the potentiometer for any visible signs of damage, such as cracks or broken pins.
  5. Gently wiggle the volume wheel while observing the potentiometer. If it appears to be loose or wobbly, it may need to be replaced.
  6. If you have experience with electronics and soldering, you may be able to replace the potentiometer yourself. Otherwise, it is recommended that you take your keyboard to a qualified service technician for repair.
If the issue persists after attempting these troubleshooting steps, it is likely that the potentiometer needs to be replaced. In any case, it is best to seek the assistance of a professional technician to avoid causing further damage to your keyboard.
Mar 18, 2023 • Casio Music
Do u know if this keyboard has a protect voltage/amp fuse?
Most electronic keyboards will have a fuse. If it is not on the rear pannel, it will be inside on the power supply board.
How to convert Casio to Pro tools
Get a USB (printer) cable.
Download PC driver from
http://support.casio.com/en/support/download.php?cid=008&pid=20
If you have a Mac, driver for this keyboard is available from 3rd party. It's called "CASIO USBMIDISRIVER for MAC OS-X".
Is there a video on using the features on a casio wk-200 keyboard?
http://www.youtube.com/user/Ghostkid202#p/u this guy explains some stuff too i hope this helps. please give me a good rating :-)
2helpful
I have a casio wk-200 piano. I bought headphones
The keyboard has a mic jack that is the same size as the headphones. You probably put the headphone plug into the wrong jack is all.
Jan 10, 2010 • Casio Music
1helpful
Casio WK 200 keyboard, USB doesn't work
You may need to install the drivers to give the computer to fully recognize the keyboard. The computer may see the keyboard, but isn't recogning it fully due to the lack of drivers.
1helpful
I fixed the dead keys on my Casio WK-200 keyboard. Now some...
Most of these have VELOCITY sensing and that involves two contacts per note. If the velocity sense on those notes is somehow not working, broken wire or trace on the board or short that MIGHT cause your problem.
Aug 12, 2009 • Casio Music
1helpful
3answers
Casio LK 200 and smf software
If you have the smart card slot you can save your songs to the memory card by using Anvil Studio which is a free program. Save your midi song in Format 0 and be sure to use channel 4 for right hand playing and channel 3 for left hand. Be sure to keep the file size under 80k if you have other channels active for other instruments!
Top Casio Cameras Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
k24674
Are you a Casio Camera Expert? Answer questions, earn points and help others
