Question about Humax DRT400 TiVo 40-Hours Video Recorder
IF POSSIBLE UPGRADING FOR HD TV VIDEO TANK FOR ANSWERS
nnasw5
    New Friend:
Hi
i want to update my IRCI-PVR humax
Posted on Feb 04, 2011
I have a Sony Bravia led digital kdl32m4000 tv, I am upgrading my satellite box to hd will I get the signal in hi def. or do I need to upgrade my tv?
No you don't need a new tv. Hook up your HD cable box using HDMI cable. Hdmi out on your cable box then hdmi in on your tv. You need your tv remote to change source input to hdmi.
Jun 10, 2017 | Sony Televison & Video
What is the best video card that is compatible with my Dell Inspiron 530s?
You can use any PCIe X16 card you want, the only restriction being the power supply. Most of the high end gaming cards require minimum 400w supply with 600w for crossfire. The 530 comes with a 300w supply so, if you were looking for a card with out upgrading power supply you would have to stay within the 300w supply. I personally like the ATI/AMD Radeon HD cards because you gain sound and video through card but thats just me. If you are a light to moderate gamer and want HD video for tv monitor, etc. a midrange card, probably in the price range of $80.00 would ne good for you and could be done without upgrading power supply.
May 02, 2011 | Dell Inspiron 530s Desktop Computer
When i turn it on the light under the screen is blue then goes orange and i have no picture/sound, kind of like when you select video and the dvd is not turned on
Tries unplug,replug the tv and cable box an hour later.The tv should now,reset itself back to the factory setting.The cable box resetting and it upgrading it softwares.The tv should work now.
Oct 21, 2010 | Westinghouse LTV-32w1 32 in. HD-Ready LCD...
Upgrading to freeview HD
Simple answer is no unless Panasonic decide to release an upgrade to the software to allow it
May 01, 2010 | Panasonic Viera TH-42PX80U Plasma TV
I want to upgrade some hardware on my aspire 6920g
There shouldn't be any issues in upgrading those features, I have personally swapped processors on OEM systems for juicier processors with no issues and swapping out for a bluray drive shouldn't give you any problems either (personally I will be doing the same thing) The screen I haven't seen available to the 6920 Ive seen it for the 8920 but thats 18.4 I believe so that wouldn't fit but if you know that there is one that was put into your model computer then I should definitely work on your computer. as far as the mini pci-e TV card we do have the blank spot BUT I do not believe this one is possible due to also needing the board to insert in the TV tuner location its possible it could work but I do not believe so.
Sep 30, 2009 | Acer Aspire 6920 Notebook PC
Will a 512 mb video card work with a 300 watt power supply
It all depends. Does the card require a 6 pin PCI-E power connection? Does your power supply have such a connector? If both answers are yes then it is possible. If the card does not require a power connection then it is also possible. But I would recommend upgrading to at least a 450 watt psu to run it more efficiently. Hope this helps.
Dec 21, 2008 | Computers & Internet
Upgrading to hd
if the tv has the red... blue...green ..picture inputs you hook in through there and you dont have to do anything because your cable sat box will seng the HD signal right through to your tv!
Dec 09, 2008 | Akai PT5250A Television
How do I set up the HD on my tv?
Press the TV/Video button on the remote. If it skips those inputs its possible the inputs are skipped in the set up menu you need to go in the menu and set up the inputs...It may be becuase there is no signal to those inputs as well.
Aug 01, 2008 | Sony KP-51HW40 51" Rear Projection...
Ps3
hold down your power button when you turn it on, for 5 seconds, it runs the screen settings menu and puts it in the best possible option for the leads fitted. hope this helps
Jan 22, 2008 | Sony Playstation 3 (PS3) Console
Humax DRT400 TiVo 40-Hours Video Recorder Logo
91 people viewed this question
Top Humax Televison & Video Experts
 Grubhead
Grubhead
Are you a Humax Televison and Video Expert? Answer questions, earn points and help others
