E0 error - ensure pot or pan is placed correctly
E1 error - the circuit has malfunctioned
E2 error - the temperature sensor is opening circuit or short circuit
E3 error - the voltage is higher (140 - 160V) for 3 seconds
E4 error - the voltage is lower (80 - 100V) for 3 seconds
E5 error - the cooktop surface temperature is too high
E6 error - Internal electronic temperature is higher than normal for 3 seconds
E7 error - Internal electronic temperature sensor is opening circuit or short circuit
(e cooker modal) all types of error code solution tell me
Philips stove e4 error solution. Helpful. Model number hd4909
Write your answer...
System is showing E1 thn what can i do?
SOURCE: I am using Pigeon induction
your cooker has a low or high voltage problem.
check your plug and clean all parts inside your cooker.
maybe have some corroation in connectors and terminals.
Good Afternoon friend, I appreciate your inquiry!
Typically on an Electrolux induction cooktop the "E4" error code stands for key sensor for timer. Which means you could be experiencing an issue with the right board, center board, or left board. I would perform a reset on your cooktop and you can do that by flipping the household circuit breaker off for ten minutes.
If that does not assist with clearing any false error codes or the error "E4" continues to display I would suggest seeking assistance from a professional for proper diagnosis and repair. Hopefully this helps. -Matt
So E1 is circuit has malfunctioned but can it be repaired without replacing the circuit board?
E4 problem havells induction
How to repair e1 code???? Plz share full details
sir I always run induction on steplizer but it shows again E4 sir I check bridgerectfier that is OK sir then I replace MOSFET after that it shows E4 I replace brigrectifier after that it shows again E4 what to do
I'm getting e4 problem in induction stove of pigeon
Crompton induction e4 please help
I am getting E1 error code on my induction stove. How do I reset
