SOURCE: NEC phone system - Forwarding incoming call gets busy signal
please call the engineer from which you have purchased the EPBAX system to congiure the same. It happens if something is wrong in line card at the exchange or the extentions are not configured properly with the Key Telephone System.
SOURCE: Vonage customer, problem running through home phone wiring
Make sure you have disconnected the original phone line at the first entry point to your home. Even though regular phone service is disconnected (software) the original phone line carries some "noise" which can cause issues when trying to utilize existing phone wiring throughout the home.
SOURCE: Getting 'busy signals and line in use message' on my phone.
the "line in use" indicates that there is not enough current on your line, either there is a broken wire and the phone is not getting any current, or there is a short on your line reducing the current on your line.
you should unplug your phone and check with a diffrent phone to see if there is any dial tone on the jack that you have a problem with... if everything is good with a diffrent phone then it is likely that the trouble is your phone, if the trouble still exists, bring a corded phone to the NID outside of your home, and test if there is dial tone there, and that you can make and receive calls... if the trouble goes away, they you need to troubleshoot further inside your home, if the trouble still exists, then you have a trouble outside that your local phone company needs to take care of, and you should contact them so that they can make the repairs..
SOURCE: My vetech cordless phone is not working
DO you have a 2 line model? If so check and make sure the conf (conference) button is not pushed as it will keep the line off-hook forever. Hope this helps!
SOURCE: call receptionist and dont get busy signal
You need to dial two commands on the receptionist's phone. On the intercom dial 7311# for outside line call waiting signals and 7321# for inside calls. (0 cancels).
Carl
