Question about Bushnell BackTrack Handheld GPS Receiver
Have a busnell neo golf gps how do you open it to replace battery
Posted by toyota57 on
Anonymous
  • 977 Answers
Hey!
From Bushnell's website:
The internal rechargeable battery is encased within the sealed shell off the Bushnell Neo. Any attempt to gain access to the battery will result in damage to the device and void the manufacturer's limited warranty. If the internal battery in your device requires service, please contact Bushnell Technical Support.
In case of a problem or clarification, don't hesitate to post me a reply before rejecting my answer.
If you are satisfied, rate my solution with the "thumbs" or (even better) add a testimonial.
Best regards,
Pelu.
Posted on Dec 12, 2010
  • 1172884 Dec 22, 2010
    turn cover on back to the right about 1/8 inch or until it stops. you may need small knife to pry off. use a good grade triple AAA battery. I've changed mine twice. batteries will last a good long time. I use mine hunting and bought it when they first came out.
2answers
Bushnell neo ion golf gps watch . cannot find serial number to register for updates ?
Hello, B J -
Instructions for registering your watch start on page 20 of the watch instructions (see the PDF document, Adobe Acrobat Reader software needed - free):
https://www.bushnellgolf.com/content/non_product/support/NeoPlus-GPSWatch-Manual.pdf
Apparently, the watch serial number is printed on the watch packaging. You may not have kept that. Or, you may not have purchased the watch from an authorized dealer.
If you find you need the watch serial number to register your purchased watch, it may be located inside the watch battery compartment.
NOTE: The instructions for your model watch state the following:
WARNING Do not attempt to open the Neo+ Watch. Risk of explosion if battery is replaced with incorrect type. •Do not attempt to open, disassemble or service the internal battery. The battery must be replaced by a qualified technician.
Visit a jewelry store and ask one of the store employees to open the watch back and look in the battery compartment for a number.
Best wishes.
2answers
Why won't my Bushnell golf watch charge?
After using it for several months it suddenly won't charge. I have tried several times, and I have also tried to clean it with a soft brush. AmanStino Mouse Pad with Gel Wrist Pad black9 0 7 8 AmanStino
Bushnell neo+ wont charge
Flat batteries. Out of life. Renew.
Golf buddy pro
Here is a site that carries replacement batteries for the golfbuddy pro gps range finder: Golfbuddy Pro GPS Battery
Restore bushnell neo
NEO issued 100 million NEO, or 100 million shares, in the NEO blockchain. NEO works quite a bit like shares. In fact, NEO even gives owners voting rights, which according to its whitepaper, is where the value in the cryptocurrency is derived. Read more at: https://www.neonbeginner.com/2018/04/15/whatisneo/
1helpful
I have a backup folder for all my courses. I accidently deleted a course in "My Courses" section of the software. I copied a backup file into the igolf folder where all of my courses reside. It's in the...
This solution applies to the newest version of iGolf Neo Sync. If you don't have the newest version download it from the IGolf site. Open iGolf Neo Sync and all of the courses in your backup file should appear under "My Courses". If all of your courses don't show up, click on "Settings" under "MY DEVICE" . On the page that opens you will see the tentative location of your backup files (for example, C:\Golf\Backup). If the location isn't correct browse for the right location. Once you find it click OK. Now all of your courses should show up under "MY COURSES" on the iGolf Neo Sync page. You can then send any of the courses to your GPS.
2helpful
Need a manual for Busnell 1500 Pinseeker Tournament
bushnell.com>north america>english>golf>laser rangefinders>Pro 1600 tournament edition> now look toward the bottom of the page and you will see the manual tab....you can download it to your computer. The 1600 and 1500 work the exact same way....the case and battery door are the only thing different!!!
Bushnell BackTrack Handheld GPS Receiver Logo
Top Bushnell GPS Experts
ADMIN Canada
ADMIN Canada
Tom Chichester
Are you a Bushnell GPS Expert? Answer questions, earn points and help others
