HP Broadcom NetXtreme Network Adapter Logo
Question about HP Broadcom NetXtreme Network Adapter
Hi i am using the pc sony vaio i have the problem on wireless adabter it was in desable mode and difficutl to active it ,while i am useing the bottom in front of pc on and off of wirless adabtor but i i on the bottom nothing is display on the screen what to do
Posted by sharuparu on
  • Anonymous Jul 17, 2021
    ALEX I'd like to try topic " What's my PC "at $500 please? Jeopardy! (RIP Alex !)
Anonymous
    New Friend:
  • 24 Answers
In Vista, you can either go to control panel, device manager and right click on it and click "eneble"
or go to control panel > network sharing and set up wireless network connection
or
go to task manager (press and hold ctrl . alt . delete for a couple of seconds), until task manager comes up. Then click on the services tab, scroll down till you see "Plug Play or Plug and Play and make sure it's running. If it's not, right click on it then click "enable"
In XP
Open Network Connections
Right-click Wireless Network Connection, and then click Properties.
On the Wireless Networks tab, do one of the following: •
To enable automatic wireless network configuration, select the Use Windows to configure my wireless network settings check box. This check box is selected by default. For information about what happens when you enable automatic wireless network configuration, see Notes.
To disable automatic wireless network configuration, clear the Use Windows to configure my wireless network settings check box.
To connect to an existing wireless network, do one of the following:
Access point (infrastructure)
To connect to an existing access point (infrastructure) network, under Available networks, click the network name, and then click Configure.
In Wireless Network Properties, specify the wireless network key (Wired Equivalent Privacy) settings, or, if the network key is automatically provided for you (for example, the key is stored on the wireless network adapter given to you by your administrator), select the The key is provided for me automatically check box. If you are unsure about whether a network key is needed or which settings you need to enter, contact your network administrator or the wireless network adapter manufacturer.
Important
If a network does not broadcast its network name, it will not appear under Available networks. To connect to an access point (infrastructure) network that you know is available but that does not appear under Available networks, under Preferred networks, click Add. In Wireless Network Properties, specify the network name (Service Set Identifier) and, if needed, the wireless network key settings.
Computer-to-computer (ad hoc)
To connect to an existing computer-to-computer (ad hoc) network, under Available networks, click the network name, and then click Configure.
If you want to connect to a computer-to-computer (ad hoc) network and both computer-to-computer and access point (infrastructure) networks are within range of your computer, click Advanced, and then click Computer-to-computer (ad hoc) networks only.
To configure a new wireless network connection, click Add, and then do the following: •
If the network connection that you are configuring is to a computer-to-computer (ad hoc) network, select the This is a computer-to-computer (ad hoc) network; wireless access points are not used check box.
To change the order in which connection attempts to preferred networks are made, under Preferred networks, click the wireless network that you want to move to a new position on the list, and then click Move up or Move down.
To change the wireless network connection settings for a network that is listed in Preferred networks, click the wireless network for which you want to change settings, click Properties, and then change the settings as needed.
To remove a wireless network from the list of preferred networks, under Preferred networks, click the wireless network that you want to remove, and then click Remove.
To update the list of available networks that are within range of your computer, click Refresh.
To automatically connect to available networks that do not appear in the Preferred networks list, click Advanced, and then select the Automatically connect to non-preferred networks check box.
To open Network Connections, click Start, click Control Panel, click Network and Internet Connections, and then click Network Connections.
When you enable automatic wireless network configuration, you can connect to an existing wireless network, change wireless network connection settings, configure a new wireless network connection, and specify preferred wireless networks. You will be notified when new wireless networks are available. After you select a wireless network, your wireless network adapter will be automatically configured to match the settings of that network, and a network connection attempt will be made.
To configure settings on the Wireless Networks tab, you must be logged on as an administrator, and you must use a wireless network adapter that supports the Wireless Zero Configuration service. If you are unsure whether your wireless network adapter supports the Wireless Zero Configuration service, contact your network administrator or the wireless network adapter manufacturer. For more information about automatic wireless network configuration, see Related Topics.
If you are using third-party wireless networking software, clear the Use Windows to configure my wireless network settings check box.
If you are unable to connect to an existing wireless network and the name of the network that you want to connect to appears under the Preferred networks list, click the preferred network name, and then click Properties. In Wireless Network Properties, review the settings to ensure that they are correct. If you are unsure whether the settings are correct, contact your network administrator or the wireless network adapter manufacturer.
If the Preferred networks list includes both access point (infrastructure) and computer-to-computer (ad hoc) networks, you cannot move a computer-to-computer network to a position in the list that is higher than the position of an access point network.
To provide enhanced security for 802.11 wireless networks and for wired Ethernet networks, IEEE 802.1x authentication is enabled by default. For more information about how to set up 802.1x authentication.
Hope this helps
Posted on Dec 12, 2010
Anonymous
  • 4 Answers
Samsung sgh 310 r pfo jumper
Posted on Apr 09, 2012
Sony vaio vgn
It seems your laptop accessed 2 connection modes at the same time.
New Sony vaio svp 132a1cl will not awake when it puts itself in sleep mode
What keys do you press to wake up, Check if using wireless keyboard mouse,the batteries are good, check if laptop is charged, or on adapter.
I want to get all my sony vaio vgn-s590b driver program because i cant get wifi signal n lan for the internet'
Unfortunately, the Wireless card in the VAIO model VGN-S580B does not support n standard. The integrated Intel PRO/Wireless 2200BG Network Connection Driver supports IEEE 802.11b and IEEE 802.11g standards. It is require to use an external Wireless card to use the n standard.
However, here is the link to download all the drivers for your computer model:
http://esupport.sony.com/CA/perl/swu-list.pl?mdl=VGNS580B&LOC=3
Thanks
1helpful
2answers
Is my Sony VAIO PCV-RS226 PC Desktop upgradeable to windows 7 ?
it's possible to install windows 7 on your Sony VAIO PCV-RS226 PC Desktop, but your 512Mb memory are insufficient to run properly the operating system. Windows 7 have a power graphic, if you still use a small memory your PC will work very slowly. The solution is:
  1. install more memory to work fast (2*512Mb or more)
  2. don'nt install a game that use more memory, it fatigue the machine and can cause an intermittent problem.
Vaio VGN-NS328 funtion key to turn on the wireless internet
Your laptop uses a wireless "Switch" located on the front edge of the laptop on the far left side. There will be an led indicator light to the right of the switch itself. Move the switch to the right to activate the wireless radio. Move the switch to the left to de-activate. Below is the link to the user manual for your laptop. It is in PDF format, so you will need Adobe reader to open it. I am also giving you a picture below of the front edge of your system.<br /> <br /> <br /> <a href="http://www.docs.sony.com/release/VGNNS300_series.pdf">http://www.docs.sony.com/release/VGNNS300_series.pdf</a><br /> <br /> <br /> <br /><img src="http://www.fixya.com/uploads/images/96F2F95.JPG" />
How do i use a wireless modem on my sony vaio
type in IE 192.168.1.1 then fallow the instrection
Sony VAIO internal wireless driver causes computer to lock up
There is a possibility you have a faulty wireless card. I would go with a external PCMCIA wireless card. Don't forget to disable the internal wireless card in the BIOS.
Wireless adabter
Is there a switch on the side of front of the machine to turn off the wireless? Make sure it is set to on. They put a switch there so that you can turn off the wireless to use the system on a plan or anywhere where wireless is forbiden.
DO I have wireless?
Hi, im sure the PCG-K315M dont have a built in wireless card, You can buy a Usb wireless card for about 20-30 pounds from any shop. If your laptop did have wireless onboard there should be a switch on one of the sides of the laptop,
Have a good christmas
John
4answers
A Open Computer running Windows XP is
run with safe mode and go with admin privileges then when u are in go START -RUN - TYPE THERE ( MSCONFIG ) -startup and desable all startup items and restart the pc!!!
Let me know if u get help OK?
Top HP Computers & Internet Experts
Mehandi Husain ...
Marvin
Marvin
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
