Hello jagdishgolas!
Theres a few things you need to do first to determine what its causing the problem
Here are some steps you can follow:
1) Print a Supply status report (Main Menu > Reports > Supply status)
If you still see the shadowing is on this page we can tell that the problem is not on the computer
Check toner level on this supply status, if its showing lower than 10 % i would recommend to replace the cartridge
2) Run 3or 4 Calibrations in a row (Main Menu > System Setup > Print Quality > Calibrate Now)
3) Run 2 cleaning modes ( Main Menu >Services > Cleaning Mode)
4) Access the secondary service by hitting the checkmark and the cancel button at the same time, then hit the checkmark again
Under the secondary service look for "Clean Belt" anr run it twice
Try printing again
Heres a link where you can find an Authorized repair center near to your location :
http://h20465.www2.hp.com/GPL/search.aspx?language_code=en&country_code=us&SearchType=SSP
