Question about Panasonic Viera TH-50PZ80U Plasma TV
My tv is giving me the 10 blink issue. Can I buy an ABoard online and replace it myself or do I need to know how to solder?
Posted by tsbrody on
charles
    New Friend:
Cctv video blinking my cctv video blinking in night time ..what is the problem
Posted on May 05, 2012
Anonymous
    New Friend:
  • 3 Answers
Found this tonight:
1 blink STV 5v sense DG Board
2 blinks 15v SOS D Board
3 blinks 3.3v SOS D Board
4 blinks Power SOS P Board
5 blinks 5v SOS D Board
6 blinks Driver SOS 1 SU / SD / SC Boards
(SC energy recovery circuit)
7 blinks Driver SOS 2 SU / SD / SS Boards
(SC floating voltage area)
8 blinks Driver SOS 3 SS Board
(SS energy recovery circuit)
9 blinks Panel Config. SOS
10 blinks Sub 5v SOS / Main 3v SOS DG Board
DTV 9v SOS / Tuner Power SOS
11 blinks Fan SOS PB Board
12 blinks Sound SOS H Board
13 blinks Communication error DG Board
with IC8001 (Pesks Lite 2)
Posted on Dec 12, 2010
  • tsbrody Dec 12, 2010
    Sorry, the last words were supposed to be "to solder." In my original post. I found the service manual online and it listed those as the issue. It indicated they were on the "A board". Just need to know if the baord plugs in or if it needs to be soldered. A $200 board and some elbow grease sounds better than a $500 repair bill.
Our 40' hisense tv keeps blinking sometimes it goes for an hour or two without and sometimes it blinks continuously
Hello
You haven't given the exact model number to your Hisense TV here. Yet, i posts this solution, as this is a common problems to all TV, irrespective of Brrand and model.
Check its power supply regulator board, for any loose solder points. Resolder all the suspected solder terminals to this board, by applying a little more solder, without making any solder bridge short in between adjecent solder terminals. You have to take the board out from the TV to do this job.
Reset it and see whether it helps you. If not, power retgulator board must be replaced as card basis. OK.
Feb 15, 2012 | Hisense Televison & Video
Panasonic TH-42PZ77U HD Plasma tv has 10 blinking lights
Ur power supply board is dead, u know basic electronics’ and soldering? Most of the times, the power supply board just have dead leakages gases capacitors.These capacitors always bulges up on it top,or puff up on it top.Replaced these gases leakages capacitors will get your tv power stable,and work again.Or tries websites like Shopjimmy.com,Ebay.com to buy a whole refurbish power supply board for the replacement.
Jun 02, 2010 | Panasonic TH-42PZ77U TV
Won't power on
hello,
Normal 0 false false false MicrosoftInternetExplorer4 st1\:*{behavior:url(#ieooui) } /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Ur power supply board is dead, u know basic electronics’ and soldering? Most of the times, the power suppply board just have dead leakages gases capacitors.These capacitors alway bulges up on it top,or puff up on it top.Replaced these gases leakages capacitors will get ur tv power stable,and work again.Or tries websites like Shopjimmy.com,Ebay.com to buy a whole rerfurbish power supply board for the replacement.
May 25, 2010 | Mitsubishi WS-55511 55" Rear Projection...
42"viera TH42PX50U wont turn on just 10 red blinking lights
Based on my research 10 blinking lights means the video controller inside your TV has malfunctioned and needs to be replaced.
Even though Circuit City went out of business Panasonic should still support their product through manufacturers warranty.
You can contact them at one of the support #'s below
Consumer Electronics
  • Technical Support: 1-800-211-7262 (Mon-Fri, 9AM-9PM EST, Sat-Sun 10AM-7PM EST)
Plasma & Monitors
  • Technical Support: 1-888-972-6276 (Available 24 hours, 7 days a week)
I know you may be frustrated with your TV malfunctioning, I had similar issues with my LG. When you call, for prompt and professional service simply give them the model # and explain that the red status light blinks 10 times when you attempt to turn on the TV.
Hope this helps
Aug 15, 2009 | Panasonic VIERA TH-65PV500 65 in. Plasma...
TH-42PX60U red light blinks 10 times wont come on
On a Panasonic TV the 10-blink error code can sometimes be caused by low voltage running through an HDMI cable, particularly from a Media PC or some video game consoles. Try disconnecting any HDMI cables and unplugging the Television for 30 seconds, then power it on without the cables attached.
If this works, connect the cables to the front panel (usually HDMI-3) which uses a different controller board.
Dec 08, 2008 | Panasonic TH-42PX60U Television
TV Sony Wega Trinitron turns off automatically, blinks 10 times
if you know how to solder, solder the power supply then the jungle IC.if still not working. maybe flyback had a problem it need to replace.
Nov 16, 2008 | Televison & Video
Toshiba 50H81 Re Blinking Light...wont work
best advice is go get a manual book on how to fix tv
May 07, 2007 | Toshiba 50H81 50" Rear Projection...
Panasonic Viera TH-50PZ80U Plasma TV Logo
1,787 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Muntejaya Ginting
Muntejaya Ginting
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
