Question about Panasonic TH-42PX60U Television
My Panasonic was working fine when I shut it off last night and I turned it on today and everything has a pink tinge to it now. It seems as though I lost a color. Can someone help me address this issue please?
Posted by biff_001 on
Anonymous
    New Friend:
  • 3 Answers
Found this tonight:
1 blink STV 5v sense DG Board
2 blinks 15v SOS D Board
3 blinks 3.3v SOS D Board
4 blinks Power SOS P Board
5 blinks 5v SOS D Board
6 blinks Driver SOS 1 SU / SD / SC Boards
(SC energy recovery circuit)
7 blinks Driver SOS 2 SU / SD / SS Boards
(SC floating voltage area)
8 blinks Driver SOS 3 SS Board
(SS energy recovery circuit)
9 blinks Panel Config. SOS
10 blinks Sub 5v SOS / Main 3v SOS DG Board
DTV 9v SOS / Tuner Power SOS
11 blinks Fan SOS PB Board
12 blinks Sound SOS H Board
13 blinks Communication error DG Board
with IC8001 (Pesks Lite 2)
Posted on Dec 12, 2010
I turned on my TV and the whole screen has a pink tint
If using a box for signal disconnect it from power for a while to see if when it reboots this issue is gone or not.
Nov 28, 2012 | Samsung HLP4663W 46" Rear Projection HDTV
Our Panasonic 50" TH 42PX75U
well it sounds like something fried inside the tv. In my experience, this sounds like your y-sustain board went bad. it could be your video board also. considering todays value of the 50" panasonic plasma, it will be cheaper to replace it, unless you are willing to spend around $300 to get it fix at a shop.
good luck
Jun 17, 2011 | Panasonic TH-42PX75U 42 in. Plasma...
97 intrepid shut off fine last night, today will
sounds like a fuel pump or maybe check on the asd relay or fuel pump relay try taking them off and tap on them then try to start if no start sounds like a fuel pump or timing belt issue. good luck
Jan 05, 2010 | 1997 Dodge Intrepid
My monitor doesn't display anything, though it's receiving input from the CPU. I know that input is being received because the monitor status light is green, and times out (turns orange).
Same thing happened to me! Went to bed last night, everything was fine. Woke up today, orange light came on, no display, slight flickering seen, but that's it. Cables and cords are fine, tried unplugging and plugging it back in, NOTHING. Totally dead. I'm guess off to buy a new one today. Typical made-in-China JUNK.
Jan 03, 2010 | Acer AL1916W 19" LCD Monitor
Samsung Series 7 won't stay on, it keeps restarting on its own.
I have the exact same TV and the exact same problem, I'm afraid to shut it off,
Jul 12, 2009 | Haier Televison & Video
Electrical / Lights / Gages
Pull instrument/ cluster panel and re-melt cold solder joints where circuit board connects to dash connectors. Get them hot enough to turn them bright silver, usually 3-5 seconds each pin.
Good Luck!
Jun 24, 2008 | 1996 Dodge Neon
Dell A-966 All-in-one Ink Jet Printer
Goto control panels
open printers and faxes
Tell me everything you see in there.
How is the printer Connected?
Nov 13, 2007 | Dell 966 All-In-One InkJet Printer
Powers off
bad microchip have a tech look into your problem and correct it.good luck.
Apr 23, 2007 | Panasonic DVD-S55 DVD Player
Panasonic TH-42PX60U Television Logo
1,180 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Muntejaya Ginting
Muntejaya Ginting
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
