SOURCE: DVD no video
I HAD THE SAME PROBLEM AND YOU NEED TO PRESS THE PROGRESSIVE SCAN BUTTON AND HOLD IT. YOUR TV IS OLDER LIKE MINE AND PROGRESSIVE SCAN WON'T WORK WITH YOUR TV.
SOURCE: DVD Drawer / VHS Eject button
My 1st suggestion is to pull the AC power plug from the wall, wait 5 minutes (have a smoke or a coffee) and plug it back in.
Then retry the functions that are giving you grief.
Report back with the results and we'll go from there.
** Please re-comment if the suggestion did not work for you, there may be several other possibilities.
** Please add a comment before giving a rating Other than Solved
SOURCE: VHS won't work
Had the same problem on my JVC vcr/dvd combo unit.
You need to turn off the timer function. I did this by making sure my remote was in the "VHS" mode...turn the swith from TV to the right (found on the remote in the upper left corner...an then hit the "vcr" button. Then point the remote at the VCR unit and hit the No. 4 button (timer turns off). Your unit should not have the red timer displayed and you should be able to play your tapes okay.
Hope this helps.
SOURCE: jvc dvd/vcr player records from vcr to dvd but
Have you finalized the DVD in question? Unfinalized discs usually won't play in other machines. Is the DVD type compatible with the other dvd players? (Some may not handle DVD+R for example; it is an acceptable disc for the jvc DR-MV79.) Try a different brand and type of DVD. Check your other players supported discs.
To Finalize the disc, Menu > Setup > Disc Setting > Finalize (if needed set Disc Protection to Off).
I hope this helps.
Testimonial: "that was great so simple yet so important who knew you had to finalize after you told the dvd recording to finish "
SOURCE: trying to copy an unprotected
hello
did you try to copy to dvd from external source? does it then work? if so might use a cleaning tape for vhs, maybe solves the problem
regards
