Posted on Dec 12, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My new epson p 50 don't work with new refill ink rechargable, the printer say don't recognize the ink, but the seller tell me there no problems of compatibility... why my printer don't work???
Kat Pulami
Level 2:
New Friend:
Cheetah:
An expert who has answered 20 or more questions within one hour.
  • Expert 90 Answers
  • Posted on Jan 03, 2015
Kat Pulami
Expert
Level 2:
New Friend:
Cheetah:
Answers
90
Questions
Helped
33148
Points
140
New refill ink rechargeable have chips on it. please wash connector points with aerosol and use again. if not change the chips set.
Level 3:
  • Epson Master 7,733 Answers
  • Posted on Dec 12, 2010
Epson Master
Level 3:
Answers
7733
Questions
0
Helped
1863204
Points
21487
  1. With the ink cartridge holder in the ink cartridge replacement position, lift the lids on the cartridges but do not take them out.
    • If the cartridge holder is not in the ink cartridge replacement position, press and hold the my new epson p 50 don't work with new refill ink - maintenance_button.gif Maintenanmy new epson p 50 don't work with new refill ink - fonte1.gifmg src="/uploads/images/fonte1.gif" alt="fonte1.gif" class="h_mi" /> ink carmy new epson p 50 don't work with new refill ink - cleaning_button-also-ink_cart_replacement.gifages/cleaning_button-also-ink_cart_replacement.gif" alt="cleaning_button-also-ink_cart_replacement.gif" class="h_mi" /> cleaning button (depending on your printer model) until the holder moves out.
  2. Check the yellow tag/flap has been removed from the top of the cartridges.
  3. Push down firmly on each cartridge to make sure it is clicked into place.
  4. Close the lids down gently but firmly so they my new epson p 50 don't work with new refill ink - maintenance_button.gifareful not to touch the cartrimy new epson p 50 don't work with new refill ink - fonte1.gif.
  5. Press the Maintenance/ fonte1.gif ink cartridge replacement/ cleaning_button-also-ink_cart_replacement.gif cleaning button on the panel to move the carriage back to the right hand side and start the ink charging procemy new epson p 50 don't work with new refill ink - dx4400onbutton.jpgmi">
  6. This process takes about one and a half minumy new epson p 50 don't work with new refill ink - black%20ink%20icon.jpg>
  7. When ink charging is finished, the print head returns to its home posimy new epson p 50 don't work with new refill ink - black%20ink%20icon.jpg under the plastic casing. The dx4400onbutton.jpg power light stops flashing and remains on, and the black%20ink%20icon.jpg error light goes out.
  8. my new epson p 50 don't work with new refill ink - getfile.aspx?rid=110s="h_mi">If the black%20ink%20icon.jpg error light flashes after the print head returns to the home position, the ink cartridge may not be installed properly. getfile.aspx?rid=110
  9. If the red light is no longer displayed, but Status Monitor still reports a Non-Genuine Ink warning when the cartridges are genuine, perform a full uninstall and reinstall of the printer driver, using the latest driver from the Drivers & Software section of the Epson Support website. For help with this step, see one of the following Related Articles:
  10. If the red light is still on the printer, and Status Monitor indicates that an ink cartridge is not recognised, follow the steps below:
    1. Power the printer OFF.
    2. Disconnect the power lead for 60 seconds.
    3. Reconnect the power lead. Do not power the printer on yet.
    4. Perform a printer operation check.
1helpful
3answers
Epson workforce 520 won't recognise ink cartidges
When replacing ink on the Epson Workforce 520, Ensure the cartridges have the correct/same number of gold contacts. Ive seen them with 7 and 9 gold square contacts and they were otherwise identical, and the ones with 9 contacts threw an "cartridge not recognized" error on the printer's dispay.
1helpful
Epson wont recognize black refill cartridge.
I'm assuming that you are probably using Non-Epson Ink Cartridges, because those are what normally cause that problem, with a printer not recognizing an installed ink cartridge. Unfortunately, there is no way to make your Epson Printer use or accept that Non-Epson Ink Cartridge, if it cannot actually recognize it. Its even possible that some Generic or Third-Party brands, may not always be recognized by the newer models of Epson Printers, because of the inexpensive [cheap] and or incompatable Electrical Chips that are mounted on the actual ink cartridge. Sometimes you will even get Error Messages up on your Monitors screen, telling you that you are actually using a Non-Epson Ink Cartridge, or that your printer cannot recognize the cartridge that you installed. Sometimes the Ink Level Indicator, on your Status Monitor, will not show an actual ink level, but may indicate a cartridge error or problem instead. Not all Generic or Third-Party ink & ink cartridges are made the same and none of them actually contain the right formulation of ink, for the Epson Printers [formula is patented by Epson Company]. Some are probably close and seem to be better than others, but some simply can clog-up or even damage the Printhead Assemblies on Epson Printers, or simply won't be accepted at all. Epson Ink Jet Printers are one of the few printers on the market that seem to have so many problems with non-manufactors inks, especially the newer models made in the last couple of years. Its because the Epson Printers use a completely different printhead inking system than most other brands of printers. Most, if not all of the other manufactors, use thermal or bubble jetprint heads and because the other brands use a totally different system, they don't seem to have as many problems using refilled inks or non-manufactor's ink cartridges. Printer manufacters do not make available their ink formulation and in most cases, the formulation is patented. Any difference in the ink formulation can actually cause clogging in the small printhead nozzles or damage other critical components. One individual printhead nozzle is so tiny, that it will not accept a human hair, so you can see why they can get clogged so easily, or even why the nozzles can be so easily damaged...Even if you were actually using a New-Epson Ink Cartridge, its always possible that you got a bad cartridge. At this point, the only thing I can suggest is that you try a different New-Epson Ink Cartridge, or at the very least, a different brand of Non-Epson Ink Cartridges and see if that helps.
Ink cartridge not recognized, epson t10
some printers don't recognize a refilled cartridge..... even if it was used in the printer if it was new...
but u should not have any problem printing........
the only problem u face is u can't get the remaining ink levels...
21helpful
5answers
My Epson NX415 does not recognize refilled and reset cartridges. What can I do about it?
Don't let your ink levels drop below 25% before refilling and resetting your cartridges. There is an inner and an outer chip on these cartridges. The inner chip disables the outer chip when it's contacts are no longer bathed in ink. So, it doesn't matter if you "reset" the outer chip after refilling your empty cartridge because the chip was disabled. I'm really curious how you refilled these cartridges yourself without souring yourself on refilling from the experience. I own a Cartridge World ink refilling store and I refilled a set of these cartridges when we had replacement chips available (we don't now because our chip distributor was violating Epson patents) and it was an absolute mess, took forever, and the cartridges still didn't work in our test printer.
2answers
Refilled the ink and it is still saying it needs
Unfortunately, you may need to buy new Epson manufactured ink cartridges. Some of the ink cartridges and/or printers have a setting that says this cartridge is empty and refilling the cartridge does not clear the empty code.
(It is annoying but the cheap printers are paid for by the ink purchases after the fact.)
6helpful
2answers
Epson Workforce 600 "ink cartridge cannot be recognized" error
My printer quit printing blue after I cleaned the print heads. What can I do? I tried recharging the cyan cartridge and cleaning the print heads again. it's still not working! GRR!!
2helpful
2answers
Canon pixma refill is not recognized
Dear nedaa,
You need to deactivate ink level detection function to keep your printer working after refilling the cartridge. Click here to know more how to deactivate ink level detection function.
Source:
Canon Inkjet Printer Forum
Canon Manual & Tools Dowload
Error light -Epson Stylus Cx3200
HI
Try getting a new black ink. The printer is not recognizing it.
Hope this helps
Epsom stylus CX4700 won't print - new ink cartridges installed
They cut costs on Epson compatible cartridges by using low quality ink and chips or not resetting the chips at all. Sounds like you got cartridges that the chips were not reset on so your printer thinks all the cartridges are empty. I own a Cartridge World ink refilling store and I would never recommend purchasing compatible Epson cartridges from anyone. I would buy refills of Epson brand cartridges and make sure the seller reset the chips.
Top Epson Office Equipment & Supplies Experts
Grand Canyon Tech
Grand Canyon Tech
NH TECH
Level 1 Expert
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
