Question about Logitech Z-2300 Computer Speakers
Basically, I've noticed a fairly faint static noise while listening to music at about 30%-40& with the Logitech z-2300's. I dont know if the problem persists when the speakers are any higher because I dont generally listen to music that high, but I've found that a potential solution can be making sure that the uncompressed Digital Signals. If not then how can I make the static go away, or is it just all in my head? Resources: http://forums.logitech.com/t5/2-1-2-0-Speaker-Systems-READ/Z-2300-All-Static-Please-advise/td-p/429012
Posted by xerxesclayto on
swimmer33
    New Friend:
  • 30 Answers
Most speakers I have owned or listened too have a faint buzz or static to them. If you are using a computer turn up the volume on the computer all the way and then you should not have to turn the volume knob on your speakers past 20% that's what i did with mine and they sound fine. If you are using something else like an i pod or something like that make sure you turn the volume on the device all the way up to ensure you don't have to turn the speakers up that high. If that's not your problem then i don't know.
Posted on Dec 15, 2010
Sennheiser HD 205 crackle when listening to music
If the crackling occurs only when opening windows or another program, the crackling is not due to the headphones but to a lack of CPU resources in your computer settings.
If you are in Windows 7,
  1. click the Start button 4f6cbd09-148c-4dd8-b1f2-48f232a2fd33_818.jpg, and then click Control Panel. In the search box, type Performance Information and Tools, and then, in the list of results, click Performance Information and Tools.
  2. Click Adjust visual effects. 18abb370-ac1e-4b6b-b663-e028a75bf05b_48.jpg If you're prompted for an administrator password or confirmation, type the password or provide confirmation.
  3. Click the Visual Effects tab, click Adjust for best performance, and then click OK.
May 23, 2012 | Sennheiser HD 205 Professional Headphones
I got my KM60 in Singapore where they use 240V. I moved back to the states and now when I turn it on the amp buzzes for a few seconds and then it has a faint static while it is on. This static...
The only change you need to make for the 120 operation should be to change the fuse to a 2 amp fuse. Faint static is typical of the electronic noise of amps... as long as it it is faint. The power supply will act differently on 120 than 240... probably takes a brief more time to get the system stable, hence the initial buzzing. As long as it performs don't worry about it.
Aug 11, 2011 | Hartke KM60 1x10 Keyboard Amplifier
My gatewayspeakers started to make loud noise when i shutting down the device or starting or if I inser any USB devise. the loud noice goes away if I mute it or attach the headphones to the system. What do...
Is it an electric noise ?
I've it is, its because your computer is a bit old, and it has problems providing power to all your hardware. But, i've you listen to music, the music will mask the noise.
So you probably need to buy a new pc, i've you dont want any noise.
Jul 17, 2011 | Gateway Audio Players & Recorders
User hears faint static while on a call. It's not load enough to make it hard to hear the caller, but a noticable crackling/static noise can be heard in the background. happens on every call.
Cell phones transmit the sound as digital data. The data when converted back to analog to listen too CAN have "digitizing noise" which will sound like static.
WORSENING the problem is if there is noise in the background of the person sending the voice and the worst possiblle is to have MUSIC in the background. These both drive the CODEC (the analog conversion system) crazy and will create what you describe. The CODEC is designed to transmit ONLY voice.
Oct 23, 2009 | Motorola Mobility Moto Q
Right speaker on the logitech z2300 sound system wont play.
Make sure the PAN control is centered in your mixer control panel.
Sep 05, 2009 | Logitech Z-2300 Computer Speakers
08 nissan frontier problems
No you need a new battery or alt. or both running a stereo will kill both faster. and could carosion faster too.
Jun 29, 2009 | 2008 Nissan Frontier
Centre speaker
Your center speaker is probably busted since you say you here an odd popping noise from it. You will need to get a new center speaker. It is not your sound card unless the same happens if you buy a new center speaker.
Oct 01, 2008 | Logitech X-540 Computer Speakers
Logitech Z-2300 Computer Speakers Logo
306 people viewed this question
Top Logitech Audio Players & Recorders Experts
Marvin
Marvin
Anthony Ward
Anthony Ward
Are you a Logitech Audio Player and Recorder Expert? Answer questions, earn points and help others
