Frigidaire  Electric Dryer Logo
A
Anonymous Posted on Dec 11, 2010
Doesnt heat, or only works intermittently. - Frigidaire Electric Dryer
docpelletier
Level 1:
Problem Solver:
  • Contributor 14 Answers
  • Posted on Nov 12, 2015
docpelletier
Contributor
Level 1:
Problem Solver:
Answers
14
Questions
Helped
9088
Points
36
The intermittent nature rules out the thermal fuse (which is either burned out or not).
Take off the panel so you can watch the burner. If the ignitor comes on for a minute (you will see it glow), but then turns off with no gas igniting, the problem is probably the gas-valve solenoids.
If the ignitor heats up only once in a while (like after the dryer has been off for a while), but the gas consistently is released and the fire lights whenever the ignitor heats up, the problem is the thermistor (thermostat in the blower). The second thing is actually the easiest to fix, and cheapest. You my find that simply cleaning the thermistor probe will fix it. For my kenmore, the part has been updated from the original to limit the degree to which it gets fouled up with gunk. I can give you links to parts and/or instructions if you like.
Anonymous
Level 3:
  • Frigidaire Master 43,501 Answers
  • Posted on Dec 12, 2010
Anonymous
Frigidaire Master
Level 3:
Answers
43501
Questions
0
Helped
10835468
Points
101584
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
if you dryer is gas check out this gas no heat tip....
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Maytag dryer will heat up the first time but not again. Igniter goes on but doesnt light.
Replace both valve coils. They will open the valve the first time, but when they get hot, they become intermittent at best.
Simpson Nova oven model 63-538 fan and light not working
I have the same oven and the fan doesnt work intermittantly. I turn it on and off a few times and if that doesnt work I give the fan a push with the handle of a wooden spoon. Works so far so I havent bothered with a 'real' fix as yet.
Heat sometimes works in 2003 envoy
First I recommend checking that your coolant level is good. Please check this cold so you don't risk getting burned. I have seen too many heater complaints where the coolant level was simply too low to fill the heater core. Next, you should check if the heater control valve is operating. I don't have any GM experience, but heater valves are often the cause of intermittent heater operation in many cars. Good luck!
2helpful
When I turn on the seat heater on the drivers side, it will stay on for about 10 seconds and then it goes off. Cannot turn it back on until the car if turned off/on. Seat doesnt ever heat up. Passenger...
Here is a heated seat TSB for cars built prior to 12/14/07
TSB 09-4-8
03/09/09
INOPERATIVE HEATED SEAT(S) - BUILT
BEFORE 12/14/2007
FORD:
2005-2007 Five Hundred, Freestyle
2008 Taurus X, Taurus
MERCURY:
2005-2007 Montego
2008 Sable
ISSUE
Some 2005-2007 Freestyle, Five Hundred, Montego and 2008 Taurus, Sable and Taurus X vehicles built before 12/14/2007 may exhibit an inoperative heated seat(s). This concern may be caused by an intermittent open element in the heated seat mat.
ACTION
Follow the Service Procedure steps to correct the condition.
SERVICE PROCEDURE
The heated seat system is controlled by the heated seat module located underneath the front passenger seat cushion. The heated seat switches are part of the heating ventilation air conditioning (HVAC) module but the heated seat system operates independently from the climate control system. The heated seat module regulates seat temperature by monitoring resistance of a thermistor type thermostat located in the cushion heater mat. The heated seat module is designed to remain on, heating the seat and maintaining temperature until switched off. For vehicles built before 5/1/2006, the module will time-out and switch off after 10 minutes.
1. Refer to Workshop Manual (WSM), Section 501-10 for pin point test on inoperative heated seat(s).
a. When testing the heater mats resistance and circuits for an intermittent open, technicians should sit in the seat while testing the circuit resistance, move the seat in multiple seating positions and apply pressure to several areas of the heated seat mat to ensure the mat element is not open intermittently.
2. Refer to WSM 501-10 for heated seat element replacement when an open electrical circuit has been identified.
Parts Block
WARRANTY STATUS: Eligible Under Provisions Of New Vehicle Limited Warranty Coverage
IMPORTANT : Warranty coverage limits/policies are not altered by a TSB. Warranty coverage limits are determined by the identified causal part.
OPERATION DESCRIPTION TIME
MT090408 Use SLTS Operations If Actual
Available Or Labor Time
Performed As Actual Time
DEALER CODING
CONDITION
BASIC PART NO. CODE
14D696 28
I hope this helps to solve it.
Have a 99 intrigue when I start the car the heat/ac module may or may come on, more often than not it doesnt. radio and lighter work fine. Heat/AC & Mirror/compass no power. Heat module replaced still...
does your cruise control work??? I had no heat or a/c intermittent, and cruise did not work. I replaced the ignition switch (behind the key) and everything works fine now. Switch was 80 dollars and about 2.5 hours of work... the shop wanted 450 dollars.
1helpful
1999 GMC Savana Heater
Need to check your coolant level, that is the first culprit...It has to be full in order to circulate in the heater core...
2answers
Dryer lights, heats up some but wont relite
Replace the coil packs on the gas valve this fixes 90% of gas dryers lighting intermittently. The bracket comes off and they are sold seperately from any appliance parts retailer.
This worked for my dryer.
Sunbeam microwave doesnt work
i just brought my sunbeam microwave like two days ago. and it will not heat up
Top Frigidaire Dryers Experts
ZJ Limited
ZJ Limited
Paul Bade
Are you a Frigidaire Dryer Expert? Answer questions, earn points and help others
