Question about Panasonic PT-47WX53 47" Rear Projection HDTV
Picture has shadows and blue is a dominant color.
Posted by flynn893 on
Anonymous
  • 476 Answers
Hello, your Panasonic rear projection TV might be due for some color convergence repair, there are some power amplifiers that overheat and begin loosing the color correction control.
Posted on Dec 11, 2010
Colors are way off. Too much orange, colors eratic.
You need a convergence kit. Search Goo*le and tvrepairkits.com will have a kit make for your specific tv.
Replace with the kit and your colors will be better than ever!
Thank you!
Jun 14, 2011 | Hitachi 57F510 57" Rear Projection...
There is a blue shadow (especially around on screen graphics, lettering etc.) when in HD mode. I attempted to align the colors through the color convergence but the blue alignment did not work. I also...
No.This tv have a convergence problems,it dead.The tv have R,G,B colors lines mis alignments,have colors shadows pictures or 3D pictures look alike?The tv convergence board,must be repaired by repacling 2 STK convergence ICS and some or all of it resistors too.To fixed the tv convergence board,to solved the tv picture convergence problems.The shop,will cost u like $300-350 for parts and labors.
Feb 14, 2011 | Mitsubishi WS-65807 65" Rear Projection...
I have a 55" rear
U tries go into the tv colors setup and turn down the color RED,might help?Tv could have a problems known a convergence problems,it dead very common problems for old DLP tvs.The tv have R,G,B colors lines mis alignments,have colors shadows pictures or 3D pictures look alike?Yes,than the tv have a dead convergence board.The tv convergence board require changes 2 STK convergence ICS and some or all of it resitors too.For fixing the convergence board to solved convergence picture problems.The shop,will cost u like $300-350 for parts and labors.
Feb 08, 2011 | Hitachi Televison & Video
I have red and green shadows. I tried using the Converge Red/Blue and Multipoint Red/Blue functions as described in the manual but neither worked
The tv 100% have convergence problems,it dead.Tv have colors lines R,G,B mis alignments,have colors shadows pictures or 3D pictures look alike?The tv have a dead convergence board,the 2 STK convergence ICS and some or all of it resistors are dead too.These parts on the tv convergence board,must be change to fix the tv convergence board to solved the tv picture convergence problems.The shop,will cost u like $300-350 for parts and labors.
Dec 10, 2010 | Philips Televison & Video
The picture comes in good except that the colors red,pink and blue has become real dominant I tried to adjust the color but those 3 colors reall show through
Hitachi was know for their problems with picture tub sets. Every time is was the main the board was bad that was control green gun.
Aug 12, 2009 | Hitachi Televison & Video
Dominant blue
Can you post to the party who has too much green how to adjust the video adjustments? They need to know so they can see if
its just a simple adjustment.
In your case, first turn the color level clear down to where you
have a black and white picture. As in the case of too much green,
question is if the picture is black and white or if there is a color
on the screen so its blue and white? I suspect it will be which
is typical when the guns start to fail. Likely the green and red
guns are weak in output. There are screen adjustments in the set that a tech can set up that may help some, but the only real fix is to replace the guns which is expensive and requires a complete allignment. All 3 guns need changing to get it back to spec and it is a good idea to replace the flyback for reliability. Get an estimate and likely you can replace the set for the same money.
Jul 26, 2008 | Mitsubishi CS-27205 TV
Mitsubish hd 1080I wt 46809
Check settings first to make sure no one changed anything out of the ordinary. Are the shadows that of a color or darkened shadow? It could be out of convergence, which can be corrected in the menu - or it could be low quality video cables to. Also, if there is no green, does a white color show up when you're in a menu mode (Red+Blue+Green = White Image)? If so, then the green picture tube is working and it's just a color adjustment, otherwise you may have to invest in a new green picture tube.
Apr 22, 2008 | Televison & Video
Tube set zenith tv
This is very typical of a Zenith set.Your picture tube will have to be replaced.One of your 3 primary colors (red,green,&blue) have turned off leaving you with the color of the dominant color.I would heave it.
Feb 10, 2008 | Televison & Video
Rca d61w20 dominate red & blue screen also very blurry picture
Red and blue present, but no green = bad green CRT is
best guess.Remove lower front panel = adjust screen and focus
controls for best pix..................T.
Oct 30, 2007 | RCA P52926 52" Rear Projection Television
Panasonic PT-47WX53 47" Rear Projection HDTV Logo
56 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Muntejaya Ginting
Muntejaya Ginting
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
