Question about Cameras
Its message "Leens Cover Closed" What
Robert Taylor
  • 747 Answers
Some pocket point and shoot cameras have a sliding lens cover which needs to be opened before the camera is turned on. Olympus is great for that and they are great ideas but you need to slide this cover open.
Posted on Dec 12, 2010
My Toshiba e-studio 233 copier is giving the error message, "Close side cover." Opening any cover to close again changes the message to "Close x" where x is the part opened, until that...
there is a switch at the side that is being push by the cover when it closes check this switch to be sure it hits the button when close or you may replace the switch it has a problem.
Jun 27, 2011 | Office Equipment & Supplies
Canon MP830 printer giving error message "inner
If the inner cover is open when starting normal printing,close it before pressing [OK] on the machine.Do not open or close the inner cover when printing.This may damage the machine.
Jun 02, 2011 | Canon PIXMA MP830 All-In-One InkJet...
Its showing "close ink cover"
Hi there!
The message "Close Ink Cover" means that the cartridge door is not closed securely.
-please open the ink cartridge cover and make sure all cartridges are installed correctly and then close the cartridge cover. That should clear the message on the screen.
Hope this helps!
May 08, 2011 | Brother DCP 165C Compact Color Inkjet...
Brother MFC 7220 message indicates "Close back cover". Cover is closed. Nothing seems to eliminate the problem.
Inside the back cover there is a black "rod" this is the rear sensor actuator. It should be straight with its peg fitting inside a slot on the rear cover area (and should also have a small spring on it)
Mar 01, 2011 | Brother MFC-7220 All-In-One Laser Printer
Printer displays message "Front or
CHECK FOR THE LEAP SWITCH WHICH IS CLOSED WHILE THE COVER OF PRINTER IS CLOSED.
Feb 04, 2011 | Samsung SCX 4521F All-In-One Laser Printer
After changing cartridge the message "cover open"
raise the cover and see if u can see a switch of some kind puss it down and see if it will print or restart ur computer and see what happens
Jan 23, 2011 | Lexmark X3480 All-In-One Printer
Brother MFC 7820N error message "back cover open" but cover is closed. machine is now not functional as error message can't be removed
If you open the back cover (depress the release button on the top right) If you lift it up look for two black anchors that grab the base when you close the lid. I have one that has a broken tab on the left side, which happens to be the same side as the cover closed switch. If the top is not closed all the way the rollers do not line up and the cover switch is not depressed to let normal operation. Also, if the switch arm is busted (case colored plastic push pin protruding from the cover) it will not make contact with the switch when closed. Try closing the cover and push down on left side of the fax. Does the error go away? If not, the actuator arm or the switch are bad.
James
Apr 06, 2008 | Office Equipment & Supplies
Cameras Logo
26 people viewed this question
Top Cameras Experts
Muntejaya Ginting
Muntejaya Ginting
Marvin
Marvin
Are you a Camera Expert? Answer questions, earn points and help others
