Check your connector of audio input of the monitor to an output of the source of the sound that you want to hear in your monitor. For example the audio output your computer to audio input of your monitor. Check if there is a loose connection or loose wire.
There should be two RCA jacks on the back for left and right audio outputs, white and red respectively, if it has stereo out. Connect these outputs to a stereo receiver or amplifier into an auxiliary port or TV audio input via a red and white RCA cable.
you need to repair or get a whole new audio output driver .go to google and type in "audio output driver download" you might need to put in your laptop tag, which is on the bottom of your laptop...or should be on the bottom.
On the earlier model AOC 32", there was only 1 audio output in the form of a digital Toslink output (fiber optic). An updated model was introduced in late 2008 which included a left and right phono audio output. The only ways to combat the lack of phono audio output on the earlier model are to either, A: Purchase an analog to digital converter online, or B: Go through a device with an analog to digital audio converter built in. Something like a stereo receiver should do this without any problem. Hope this helps.
ok fist thing first do u have the mute on the tv set ? 2nd thing can u get audio out of the video and audio output jacks one way to find out is take the audio jack and run it to a stereo or your computer should have a audio input jack to see if any audio is coming out of the if circuit of the tv. if it is and u have sound thru the video and audio outputs then u may have blown the audio output ic in the set . please let me know how it whent marty
