Question about Swatch Irony Chrono #YOS414G Watch for Men
I have a swatch irony chrono, but when I stop the stop-watch and push the bottom button, the sweep hand ends up at the 11 o'clock and not the 12 position. My quartz Parnis does this, and its driving me nuts!!Thank you for any help.
Posted by john618 on
Andy H
    New Friend:
  • 3 Answers
Assuming the mechanics work ok (thay all do 360 degree turns) it's just a calibration issue: download from SWATCH support a PDf which describes how to zero the watch hands, it's simple as taking the crown out to 3rd step, the pushing the buttons repectively till they point 12 direction. Exact details in the PDF.
Posted on Feb 06, 2011
Chron startstop button stuck
put a spot of WD40 down the sides of the button then try pull and pushing with tweezers
Mar 27, 2015 | Swatch Irony Chrono #YOS414G Watch for Men
Tip
SWATCH - IRONY CHRONO / DIAPHANE CHRONO settings
Follow this link and see how to set your IRONY/DIAPHANE CHRONO watch:
http://www.swatch.com/templates/zz_en/pdf/manuals/irony_diaphane_chrono.pdf
on Aug 04, 2010 | Watches
Swatch diaphane second hand stuck
Hello, a week ago the small second hand (not long chrono second hand) got stucked and my irony swatch just stop moving. Although the chronometer could be running if started... The small hand just didn't move.
I tried different tricks, like removing battery, pull out main wheel and use chrono buttons to reset arms. Etc.
Today I noticed that when turning the wheel backwards a couple of times (one or two hours back) the little hand moved one second back... Pushing wheel back to On possition made the small hand move forward one second and get stucked again.
Then I did this procedure a couple of times, at some point I turned the wheel back for a while (may be 5 full turns) and noticed the small hand moved more than one second (5, 10, 15 seconds backward)... when I noticed it was moving freely I pushed wheel to on position and noticed the small second hand was running normal.. I hope it works for some of you. Greettings from Canada
Nov 06, 2012 | Swatch Diaphane Chronograph Blooded Silver...
Swatch, irony, men's watch, doesn't work
the second hand, the small one at about 6 o'clock is moving which indicates your watch is working. the other large hand is not the second hand but the chronograph hand or stopwatch hand. You start it in motion by pushing the button a 2 o'clock. You also stop it this way. The button a 4 o'clock is the button than resets it to zero (12 o'clock). You didn't say what wasn't working. Does this help?
Oct 31, 2012 | Watches
The second hand on my invicta chronograph watch doesn't reset to zero
Easier than you think.
Pull your Crown out to the FIRST stop (were you would normally set your date). Push the "A" button (top chrono button) for your dial at the "3 oclock" area, Push the "B" button(bottom chron button) for the second hand.
Dec 26, 2009 | Invicta Subaqua Noma Iii S
Hye...my watch swatch stop functioning even i already changed the battery.
Could be Following Reason
1, Watch movement required overhaul
2, Circuit or coil warn out
3, Battery connection are not on right place
4, Test new battery to check its strength
If watch has only battery cover on the back and does not has backcase
like most of swatch watches are then watch can not be overhaul.
hope this information is helpful
from
AmFix Jewelry & Watch Repair
203 N. LaSalle Street
Chicago, IL 60601
Ph: 312 641 7000
Email: [email protected]
Web: www.goamfix.com
Sep 25, 2009 | Swatch Irony Chrono Unisex Watch #YMS400G
I need to reset the hands
Assuming you want to reset the zero posistion of the chronometer (stop watch) hands...
On my watch I can adjust it by doing the following...
To reset the microseconds hand / top right
1) Pull the center knob full out (2 clicks)
2) Press the bottom push button to adjust the hand
To reset the seconds hand / middle
1) Pull the center knob a full out (2 clicks)
2) Press the top push button to adjust the hand
To reset the minutes hand / top left
1) Pull the center knob out half way (1 click)
2) Next press the bottom push button to adjust the hand.
Once all hands are reset, push the center knob back in fully...done
Mar 16, 2009 | Swatch Irony watch
Need instructions on National Geographic Men's watch #NG010GYSK
go to Buliva web site and look for the chorograph 561/598
FEATURES
1. Hours, minutes, seconds and date display.
2. 60 minute Chronograph (CHRONO) with minutes and
seconds display.
3. 24 hour hand, permanently synchronized with the normal
12 hour hand.
A. SETTING THE TIME
1. Pull the crown out to position “3” (See diagram). If the crown has
a “screw-down” lock, then unscrew the crown lock first by turning
the crown toward you, then pull it to position “3”. Do not forget to
screw the crown back “IN” after all setting is completed.
2. Turn the crown towards you (hands moves clockwise) until the
date changes at approximately midnight.
3. Continue turning the hour and minute hands to the correct time.
If it is afternoon you must go past 12 o’clock again (noon) to set
the correct time.
4. When the correct time is set,push crown back to position “1”.
B. SETTING THE DATE
1. Pull crown to position “2”(See proceeding diagram).The watch
will continue to run.
2. Turn the crown away from you until the correct date appears.
3. Once the date is set, push the crown back to position “1”.
Note: Do NOT set the date between the hours of 8:00 PM and
3:00 AM.This would not damage the watch,but the date may need
to be reset later.
C. CHRONOGRAPH (CHRONO) ADJUSTMENT
If the chrongraph second hand is not positioned at the proper
starting position (12 o’clock or “zero” position), use the below
procedure.It does not need to be repeated unless the watch
receives an impact sufficient to move the hand out of position, or
the Battery has been changed.
1. Pull crown out to position “3”.
2. Push button “A” to move the Chrono Second hand (long hand) to
the “0” or 12 o’clock position. Each button push will move the
hand one step – BUT holding the button down will advance the
hand rapidly.
3. Push crown back to position “1”.
D. USING THE CHRONOGRAPH (CHRONO)
Note:
The maximum chrono reading is 60 minutes, However the
chrono will continue running once 60 minutes has passed. The
resulting one hour periods may be added together mentally to keep
track of longer periods.
For example – If you know that approximately one hour has
passed since you started the chronograph, and the chrono reads
25 minutes, then you know that the chrono has been running 60
minutes plus 25 minutes, which is one hour and 25 minutes.
1. Push Button “A” to start the chronograph. Push button “A” again
to stop the chronograph.
2. Push button “B” to return the two chronograph hands to the
“Zero” or starting point.
3. The Chronograph can be stopped and started again
(Button “A”), repeatedly, to “ADD” times together.
BOOK NO. 561/598 Chrono FS00/01/10
Watch Setting Guide
4/2007
Feb 13, 2009 | Bulova Watch
How do you set and deactivate the alarm function.
I did find two authorized dealers:
www.kenmarwatches.com
www.princetownwatches.com
Contact both and request users manual fur your specific model. They must be able to help.
Jan 05, 2009 | Bulova Watch
SECTOR CHRONOGRAPH 200 WATCH
That's easy. You need to calibrate it. In normal time mode, pull the crown out all the way and then use the pushers to step it back to the zero position. When finished, push the crown back in. You can also calibrate the sub-dails in a similar fashion.
Sep 19, 2007 | Watches
Swatch Irony Chrono #YOS414G Watch for Men Logo
1,299 people viewed this question
Top Swatch Watches Experts
Janelle Schoonover
Janelle Schoonover
Bruce Robin
Michael Thomas
Michael Thomas
Are you a Swatch Watch Expert? Answer questions, earn points and help others
