Question about Whirlpool Cabrio 7.0 Cu. Ft. Super Capacity Plus Electric Dryer
This dryer takes a long time to dry, sometime over and hour, what is the best setting for this dryer for jeans?
Posted by vgantz on
Tim Whalen
  • 3,074 Answers
Http://www.partselect.com/dryer+wont-dry-clothes+repair.htm
Posted on Dec 11, 2010
What is the best settings to wash jeans on.
While hand washing and line drying is safest, it's also costly in terms of time and effort. Unless your jeans are particularly dirty, it's best to wash them in cold water, select one of the gentler cycles, and dry them at a low temperature. Special detergents formulated to preserve dark colors really do work.
What temperature do you wash jeans? When to Use Warm Water - For man-made fibers, knits and jeans, use warm water (90°F). Most of your clothes can be washed in warm water. It offers good cleaning without significant fading or shrinking. When to Use Cold Water - For dark, bright colors that bleed or delicate fabrics, use cold water (80°F).
Wash your jeans in the sink or a tub.
  1. Fill a tub with a few inches of cold or lukewarm water. Mix in a gentle, color preserving detergent.
  2. Turn the jeans inside out, then lay flat in the tub. Don't bunch them or wrinkle them. Let them soak for about 45 minutes.
  3. Run them under the water to rinse. Hang up to dry.
  4. Can you put jeans in a tumble dryer?
    According to Good Housekeeping "All fabrics and especially jeans benefit when youtake them out of the dryer slightly damp. ... If, even after tumbling on low heat and a delicate cycle, you see lots of lint on the dryer's filter, you may want to switch to linedrying your jeans to help preserve the fabric.
    hope this helps you out.
Oct 28, 2017 | Washing Machines
Wirlpool Estate Gas Dryer that does not dry
i think your temperature sensor is defective in the dryer section..
check it out
May 04, 2008 | Dryers
Gas Dryer does not dry clothes. The dryer on highest setting will dry for over an hour and items such as towels,jeans nad the like are not dry
If your dryer is not drying like it once did or if you just have nottaken the time to give yourself a clean dryer in a long time then youneed to do that. At least once a year the dryer cleaning should takeplace. Lint build up in the dryer duct is one of the main causesfor your dryer to fail.
Here is the rest of this tip about DryerMaintenance
heatman101
Jun 28, 2011 | Whirlpool Dryers
My whirlpool duet dryer doesn't get jeans or towels dry
jeans and towels are very thick, they will take more time to dry.
Apr 07, 2010 | Dryers
Dryer taking 3 hours to dry jeans and towels
Here is a tip that I wrote that will give you some things to check out...
http://www.fixya.com/support/r4312805-dryer_maintenance
heatman101
Apr 05, 2010 | Fisher and Paykel DEGX1 Electric Dryer
Not heating and drying clothes properly takes about 2hrs to dry jeans??? what is the problem
frist check the vent if this is to difficult for u pull vent hose from dryer run dryer with load 45min normal dry time . longer for jeans 60- 70 mins. if this works. u have vent problem. if not remove back of dryer replace cyle tstat this is one closer to vent duct problely 4 wires
Oct 26, 2009 | Whirlpool LER5636P Electric Dryer
What is the best setting to dry jeans on a kenmore 9000 electric
Use Auto Dry for most things and vary the "dryness" level to more or less depending on the thickness of the material you are drying. Auto is most efficient and will adjust itself for finish time.
Auto dry and select "more dry" before hitting start, for jeans or towels.
Aug 28, 2009 | Kenmore Dryers
Maytag dryer not drying clothes properly
Have you tried cleaning off the sensor? Many of the newer dryers have a sensor that, when dirty, can no longer determine the moisture level of the clothes. Some manufacturers recommend using a light vinegar solution. Check your owners manual for location and recommended cleanier. Also, make sure your exhaust hose is clear of obstructions and that you vacuum out your lint trap area. HTH.
Aug 17, 2009 | Maytag Neptune MDE5500AY Electric Dryer
Have heat & tumbling but will take 3 hrs to dry a load/ no jeans
Likely that your Dryer vent is clogged up. Especially if its long. Check that by hooking up a shopvac to one end with duct tape to seal any air leaks between the vent pipe and the vac hose. Turn it on and check the other end of the vent pipe for suction. If its faint then there may be a crapload of lint in there or a birds nest. Compressed air in the pipe with an agitating device may work or shopvac hose if run is short. Be prepared for a mess on either end.
Heather
Jul 28, 2009 | Whirlpool Ultimate Care II LSQ9564J Top...
Whirlpool Cabrio 7.0 Cu. Ft. Super Capacity Plus Electric Dryer Logo
481 people viewed this question
Top Whirlpool Dryers Experts
Michael Thomas
Michael Thomas
Marvin
Marvin
John Tripp
John Tripp
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
