Question about Honeywell Electronic Programmable Heat/Cool Thermostat - CT3300A100 Heater
I'm installing a Honeywell Thermostat RTH2410. In Step 1 you need to identify the system type. I have a Carrier Heat Pump model FA4BNF030. Is this a heat pump with or without auxiliary/backup heat?
Posted by crslbuckley on
Brandon Berry
  • 407 Answers
Auxiliary heat is electric heat that is put into the air handler on the inside of the house. Its used when your heat pump doesn't provide enough heat, but heat strips are not always used. To see if you have auxiliary heat, look inside and see if you have breakers on the front panel of the air handler or anywhere close. No breakers, no electric heat. Hope this helps!
Posted on Dec 12, 2010
How do you program the Honeywell RTH 2410B1019 thermostat for a heat pump.
5-1-1 Day Programmable Thermostat - Honeywell
yourhome.honeywell.com/.../thermostat/5-1-1-day-programm...
HoneywellSet the Honeywell 5-1-1 day programmable thermostat to your maximum comfort settings. Works with heat pump systems. Buy now!
Nov 18, 2015 | Honeywell Heating & Cooling
Trying to install honeywell 7 day program thermostat but I don't know if I have a heat pump. My initial thermostat W white O orange G green R red C blue Y yellow. When I install the Honeywell the O is not...
Look real good at the terminal block. Look at both the left side and the right side of the terminal block. O should be there! You probably do not own a heat pump. Also have patients when programing the thermostat!
Dec 30, 2014 | Heating & Cooling
I just bought a honeywell RTH2510/RTH2410. It states that if your old thermostat has Y1 WI & W2 stop and contact a qualified contractor. WHAT? how hard can it be, just need to know what wires go where?
Your system has 2 stages of heat. Therefore you should have a 2 stage tstat. The 2510 is 1heat/1cool, put your w2 wire in with your w1 wire, you will be fine.
If you need further help, reach me via phone at https://www.6ya.com/expert/thomas_092728000e6acb79
Oct 26, 2013 | Honeywell Electronic Programmable...
Carrier OEM to Honeywell Programmable Tstat - NEED HELP
you likely have a "two stage" system, but not a two stage heat pump. the first stage is probably the heat pump itself, and the second stage is the auxilliary resistance heat that suppliments the heat pump at lower temps. if i knew the terminals that are available on the new stat, i could advise you on the proper wiring.
Jan 27, 2013 | Carrier Heating & Cooling
CARRIER FILTER FOR MODEL FA4BNF030
I can't find a filter to fit my Carrier air conditioner it needs 16 1/2x21 5/8x1 where can I find this can you please help, thank you
Jun 25, 2012 | Carrier Heating & Cooling
I installed a honeywell rth2410 and with the fan switched to auto and system in off position, the fan is still running and will not **** off
sounds like you have 24 v going to the g terminal check that otherwise the fan relay in the furnace is stuck closed or the thermostat is defective
Apr 10, 2011 | Honeywell Electronic Programmable...
I'm tryingt to install RTH2410 honeywell thermostat for a central air/gas heat system. I accidentally discarded the old thermostat, because I thought the honeywell would be easier to install, but nothing...
Call 1-800-468-1502 for wiring assistance.
You probably have the wrong wire on the R terminal. Make sure that the wire on the thermostat R is the same wire that is on the furnace R terminal.
Oct 17, 2010 | Honeywell Heating & Cooling
Installed a RTH2310B to replace an older model honeywell. All wires do not match. only 3 do r, w1, and g do and o and e do not. what should i do?
The Honeywell RTH2310B is a standard thermostat and is not compatible with a heat pump system. The terminals O and E are for a heat pump system. I am assuming that the terminals you described that do not match are from the old thermostat. What you will need to do is get a heat pump thermostat. Sometimes it can be hidden within a lot of other descriptions on the front of the box, but it will say heat pump and either 2 heat/1 cool or 2 heat/2cool. You should just need the 2 heat/1 cool heat pump thermostat. Hope this helps.
Aug 17, 2010 | Heating & Cooling
I Have a honeywell RTH2410 Thermostat I wired it without the blue wire which used to go to X on my old thermostat. Now it comes on with aux heat all the time and I have a Heat Pump. How can I fix this?
What was the old thermostat labels and the wire colors that went to them?
The typical heatpump wiring Terminals are:
R = Red = Hot side of Transformer
C-B-X = Common side of transformer Depending on brand of heatpump
Y = Yellow = Cooling Contactor
G = Green = Furnace Blower
O = Orange Reversing Valve Energize to Cool
B = Blue Reversing Energise to Heat Depending on brand of heatpump.
W2 = White = Auxiliary Heat
You need to be sure where each wire comes from when you connect them to the new thermostat.
The best way to do that is to go to the furnace and see where they are connected. R-Y-G are probably correct, you need to see where the Blue wire comes from and determine what the X terminal was on the old thermostat.
Dec 29, 2009 | Honeywell Electronic Programmable...
Replacing thermostat: tstatccshp01 with th8320u1008
Hook up o to o/b, then in the installation programming set the change over valve to energize in cool. Then hook up w to aux. Good luck.
Jan 21, 2009 | Heating & Cooling
Heating & Cooling Logo
642 people viewed this question
Top Honeywell Heating & Cooling Experts
Paul Carew
Marvin
Marvin
Are you a Honeywell Heating and Cooling Expert? Answer questions, earn points and help others
