Question about Parrot 3200 Ls Color Handsfree Bluetooth Car Kit
Hi i have a parrot 3200 ls i dont know the password 2 pair my phone with it i did have the booklet with the password in but i have thrown it out .i wud like help if possible with the password thanks richard.
Posted by richardsomer on
taran_2005
  • 10,515 Answers
As per user manual, if you are pairing your set for the first time :-
The first time that you switch on the 3200 LS-Color, you must pair your
mobile phone with the kit.
. Enable the Bluetooth mode on your phone.
. On the hands-free kit, scroll through the menus until you come to Settings
Pair with phone..., and select the relevant option for your phone. A 4-digit
PIN code then appears on screen. Memorise it.
. Search for any peripherals: for further information on this procedure,
refer to the Bluetooth chapter in your mobile phone's user guide or
check out our website at :
www.parrot.biz/guide_chm/3200LS COLOR/index.html
. Once the search has finished, "Parrot 3200LS / Parrot 3400LS" is dis
played on your phone.
. Select the kit. Your phone prompts you to enter a code: key in the code
shown on the kit screen and confirm on your phone.
. The kit's screen displays "Pairing".
. Once the data has been exchanged, "pairing successful" appears on
the 3200 LS-Color.
Download the complete manual from :-
http://www.parrot.com/uk/support/userguides/#CK3200
Click on English. A pop up would be there. Save it and open it with the help of acrobat reader.
Note - For most of the handset , the default code is 0000.
Let me know,if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Posted on Dec 11, 2010
Paired my nokia with my 3200 ls kit worked ok but then stoped and now my nokia cant detect my 3200 ls kit
Try deleting all paired devices first, Menu / settings / paired devices. The remove the battery from your mobile phone for ten seconds. Then try pairing again, this should do the trick, if not the parrot may need a software update.
Nov 23, 2011 | Parrot 3200 Ls Color Handsfree Bluetooth...
PARROT 3200 LS says memory full and will not automatically sync with my phone- i have to do it manually each time. do you have any suggestions?
Go to settings/ paired devices and delete all the phones stored in there. then pair you phone again and select connect automaticlly. If the phone does not sync then you will have to send you contacts to the kit by Bluetooth. You can find instructions on how to do this on the parrot support web site. As you dont say which phone you have I can not tell you more.
Feb 10, 2011 | Parrot 3200 Ls Color Handsfree Bluetooth...
I have just bought a new apple I phone 4. I can not get it paired to my Parrot 3200 LS. I am "told" the 3200 LS will not work with Iphone 4. The phones "sees" the parrot but on the...
remove all the previous paired phones from the parrot memory and then try again. if this dont work then you will need to have the software of the parrot updated. You can do this yourself but you will need a laptop with bluetooth. then download the software from parrot web site.
Feb 03, 2011 | Parrot 3200 Ls Color Handsfree Bluetooth...
How do i pair my blackberry with parrot 3200 ls, asking for numeric key
The first time that you switch on the 3200 LS-Color, you must pair your mobile phone with the kit.
1.Enable the Bluetooth mode on your phone.
2.On the hands-free kit, scroll through the menus until you come to Settings Pair with phone and select the relevant option for your phone. A 4-digit PIN code then appears on screen. Memorize it.
3.Then from mobile serach the 3200 LS-Color device
Once the search has finished, "Parrot 3200LS / Parrot 3400LS" is displayed on your phone.
4.Select the kit. Your phone prompts you to enter a code: key in the code shown on the kit screen and confirm on your phone.
5.The kit's screen displays "Pairing".
6.Once the data has been exchanged, "pairing successful" appears on the 3200 LS-Color.
Thank You
Oct 08, 2010 | Parrot 3200 Ls Color Handsfree Bluetooth...
My nokia 2330 classic doesnt pair with my parrot 3200 ls color. after synchrinsing them unable to get authorisation code
It all depends. When you want to connect a blue tooth to a phone, You will need to switch on the blue tooth device and the phones blue tooth you are pairing with.
When pairing both device, you will ask for pairing code, You four digit numbers(default code(0000). and pair.
After pairing both device, you detected paired, you can now use the blue tooth device with your phone.
there are no special code for pairing Blue tooth device.
Normal codes used are any four digit, four numbers you want to use.(0000, 1234).
Take care.
Aug 16, 2010 | Parrot 3200 Ls Color Handsfree Bluetooth...
Ive just braught car car with a 3200 ls already in the car, ive erased all old phone that have ben used on it but i dont know how to link my nokia n95 to it, can anyone help me ?
2 ways of doing this. Go in to the bluetooth menu of your phone and search for the device, it will come up parrot 3200ls select this and it will give you a pin on the screen enter pin in the phone when asked and hay presto! you will have to send over the contacts tho, you do this by going into contacts then options, mark, mark all, send, via bluetooth, select the parrot, and it will send them all over. The other way is if it doesnt give you a code on the screen when pairing, go in to settings, pair with phone, then other phone, pin will come up. search from phone and then select.
Nov 29, 2009 | Parrot 3200 Ls Color Handsfree Bluetooth...
Parrot 3200 Colour LS
My Parrot came with the default code 1234
Jul 25, 2008 | Nokia N95 Cellular Phone
Parrot 3200 Ls Color Handsfree Bluetooth Car Kit Logo
5,104 people viewed this question
Top Parrot Cell Phones Experts
Marvin
Marvin
ray gallant
john h
Are you a Parrot Cell Phone Expert? Answer questions, earn points and help others
