The F05 fault is nothing to do with what soaps you use.. Its a little red wire located at the front bottom centre of your aquasteam washer that has come lose or detached. A task to get to it but pretty easy and dodgey repair men would have your pants down for such a simple thing
Hi i have whirlpool aquasteam AWO/D AS148 with fault F05 what do i need to do and can i repair it myself??
thanls
Might be wrong soap, too much soap, soap in wrong tray, heater or thermistor broken, hoses backwards, no water being sensed going into the machine, no water going out, and me fave: leak detected. More HERE
Get a free service manual HERE
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Probably you have a clogged water pump clean it if not clogged then you have to know how to check if you have voltage to it, do so if you have 120 volts then it's your water pump http://www.appliancepartspros.com/whirlpool-washer-drain-pump-280187-ap3953640.html
