If you are referring to the "touch pad" on Laptop/notebook, if the touchpad on your laptop is not working and is unresponsive, it's not broken, you or someone else has accidently deactivated it with the function key.
Then you can try this,
Most laptops (if not all) come with a function key. The function key is labelled "Fn" and usually stands out from the rest - either the "Fn" is in a different color or the key as a whole. The function key works in conjunction with other keys on the keyboard especially the ones in the top row marked "F1" to "F12". The combination of function key with these keys lets you perform various tasks quickly such as shutting the screen, putting the computer in sleep mode, switching the wireless connection on and off etc.
By keeping the function key pressed and then hitting one of the keys ("F1" to "F12"), activates a task. You can activate and deactivate the touchpad by using the function key with the "F8" key.
Hope it helps.
To access Mouse Properties, select Start - Control Panel - Hardware and Sound -Mouse.
Use Mouse Properties in Windows to customize settings for pointing devices, such as button configuration, click speed, and pointer options.
