While installing MTK driver for lg GX200 on my PC whose OS is windows 7, it gives error "The version of this file is not compatible with the version of winows you're running. Check your computer's system information to see whether you need an x86 (32-bit) or x64 (64-bit) version of the program, and then contact the software publisher.
Posted by 9211pawan on
Anonymous
    New Friend:
MTK driver for LG GX200 is not installig on Windos7.Needs remedy.
Posted on Aug 13, 2011
James William
    Welcome Back:
    Visited the website for 2 consecutive days.
    Problem Solver:
  • 9 Answers
If you want to reinstall the operating system or upgrade your device, you can use a flash file. This file helps to get back your phone in factory format. It can fix software issues, Boot loop issues, IMEI issues, and dead issues. These files are unique for every phone.
https://firmwareflashfiles.com/micromax-d303/
Posted on Jan 14, 2021
I've just purchased a new windows 7 computer with
1) Download the USB driver for your phone here: http://www.lg.com/hk_en/support-mobile/lg-GX200.
2) Install the driver and reconnect your phone via USB.
3) On your phone's status bar, choose the option "connect as a media device" to make sure the pc can now see the phone.
4) Disconnect the phone from the pc.
5) Now, to connect the phone as modem, reconnect your phone to the pc via USB.
6) Go to your android phone's settings, choose "wireless and networks, then "more," then "tethering & portable hotspot."
7) Check the box that says "USB Tethering."
It should be working now!
Sep 28, 2013 | Cell Phones
I used twinkle cam successfully in windows xp. I have upgraded to windows 7. How do I get the driver or will anything work?
According to http://www.chicony.com.tw/download/di/driver.asp , the available drivers were written in 2004. Chicony has stopped supporting their cameras for newer Windows OS versions. I suspect they never made a 64-bit version of the driver for XP 64-bit.
If you had the 32-bit version of Windows 7, you might be able to use the compatibility mode to install the driver. To check your version, click on Start > Control Panel > System and Security > System. Look for your Windows version and check if it says x64. If you see that in the description, you have the x64 bit version. Otherwise, right-click on the driver file from the above site (after extracting the files from the zip file). Choose Properties and the Compatibility tab. Check the box for always Run this program in the compatibility mode and set it to Windows XP in the drop-down menu. You may need to repeat this on the camera software as well.
If you have a 64-bit version Windows Home Premium, you may be better off upgrading to Windows 7 Pro or Ultimate. Then you can download and install Virtual PC and the XP mode, if your hardware can handle that software. This gives a virtual version of the 32-bit version XP that will run your camera. (The CPU needs to have virtualization support and it has to be enabled in the BIOS. Then you need enough memory to give the virtual XP at least 512MB -1GB of memory.) If you already have Windows 7 Pro or Ultimate, just use XP mode. Other virtual PC software exists but they require a licensed version of XP. (If you can find a valid license.) The only issue I've found is that files saved to the C: drive in one OS can't be accessed by the other OS. You have to transfer the files with an external drive, flash drive or burn the file to optical disc.
Dual boot systems with XP and Windows 7 can be set up if you have the XP license. Then pick the OS you need when you boot up the computer. This requires you to repartition the hard drive or have two bootable hard drives. Make sure to back up before partitioning the drive.
I wish that I had better news for you.
Aug 22, 2013 | Chicony TwinkleCam DC2110 Webcam
THE MITSUBISHI CP8000DW DRIVER IS DISCONTINUED HOW CAN I FIND THE DRIVER?
What OS is your computer running? I found the drivers for supported OS versions here: http://displays.mitsubishielectric.eu/resources/product/CP8000DW . The direct links are listed below. (All are .zip files so you will need to unzip them.)
Mac http://displays.mitsubishielectric.eu/files/library/files/DISCONTINUED/PRINTERS/cp8000m_macos.zip .
Win95-98 http://displays.mitsubishielectric.eu/files/library/files/DISCONTINUED/PRINTERS/cp8000dw_win95-98.zip .
Win NT and Win2K
http://displays.mitsubishielectric.eu/files/library/files/DISCONTINUED/PRINTERS/cpd8000n_wnt4_0.zip .
If you have a newer Windows OS, you can try the compatibility mode. (The NT driver will likely work in XP. If you have Vista or Win7 32-bit OS, it's possible they will work but maybe not. If you have the 64-bit version, the above files will not work directly.) For executable files in Windows, right click on the .exe file and choose properties. Select the Compatibility tab and check Always run this program in the Compatibility Mode. Select the appropriate older version of Windows. Then click Apply. Close the Properties window. Then right click again on the file and choose Run as Administrator (required for Win7 and Vista).
To check if you have the 64-bit OS, click Start > Control Panel > System and Security > System (for Win7). In Vista, the steps may be slightly different. If the version name ends with x64, you have a 64-bit OS. Otherwise, you have the 32-bit version.
If you have a 64-bit OS, you need a 32-bit OS for a work-around. This can be a true second computer, a dual boot system (2 partitions with different OSes loaded), or a virtual computer with an older version of the OS. If you have Windows 7 Pro or Ultimate, you can install a virtual XP computer for free. Go to microsoft.com and download Virtual PC and the XP mode program. Install them in order. Then install your printer under XP as if it were the only computer running. (Note some computer hardware limits may stop you from using this option.) There are other virtual computer programs (VMWare, Parallels). However for the other virtual computer programs or the dual boot or second computer options, you need a licensed copy of the older OS.
I hope this helps.
Oct 03, 2011 | Mitsubishi Color Printer 8000DW Thermal
Icannot load the driver for Targus acp50us. i am running Windows 7
Do you have the 32-bit version of Windows 7 or the 64-bit version? To identify your version, click Start > Control Panel > System and Security > System. On the line that gives the OS version, if you see x64, then you have the 64-bit OS. If you do not see these extra characters, then you have the 32-bit version.
I suspect you have the x64 version of Windows 7. Targus does not have drivers for Windows 7 x64 for the ACP50US. Targus only supports the ACP45 and the ACP51 docks under the 64-bit OS.
If you have the 32-bit version of Windows 7, download the driver from http://www.targus.com/us/download.aspx?regionid=&sku=acp50us&PageName=&productCategoryId= . This is the Vista (and XP) driver. You may need to use the compatibility mode to get it to work. Right click on the executable file and choose Properties. In the Compatibility tab, choose "Run this program in the compatibility mode". Select Vista or XP in the drop down menu. Then right click on the installer again and choose Run as Administrator.
I hope this helps and I wish that I had better news for you.
Aug 18, 2011 | Targus ACP50US Docking Station
Does the Design Studio for Plastic Canvas work with Windows 7? I bought the item on Amazon, and the description stated Windows 95/98 and later, but the box only states Windows 95/98. The seller could not...
First what version of Windows 7 are you running? Click on Start > Control Panel > System and Security > System and read the title of your OS. If it ends with x64, you have the 64-bit OS. Otherwise, you have the 32-bit version. Next which version of Design Studio do you have? If you have version 2.0, that is compatible with XP and Vista (not x64).
If you use a 32-bit version of Windows 7, you may be able to get it to work with the compatibility mode. Right click on the installer on the CD and choose Properties. In the Compatibility tab, set the "Run this program in the Compatibility Mode" and choose an older version of Windows (try XP first). Then right click again on the installer and choose Run as Administrator.
However, it will not work with the 64-bit version due to unsigned drivers and other issues.
There are workarounds if the program doesn't work in the compatibility mode. You need an older version of Windows running. This could be on a physical second computer, a dual boot system or a virtual computer. If you have Windows 7 Pro or Ultimate or upgrade to one of them, you can use a virtual version of XP for free. Download and install Virtual PC and the XP mode from Microsoft in order. Then install your Design Studio in the XP "machine" as if it was your only computer. The only restriction is that you can not share your printer or files under XP mode and Win 7 at the same time. You will need to uninstall the printer and reinstall it under the other OS or transfer the files to external media to share them. Other virtual computer programs are Parallels and VMWare. For these virtual computer, the dual boot, or the physical second computer option, you will need a licensed version of the older Windows OS.
The documentation and an update are available here: http://www.plasticcanvassoftware.com/ . The update is in the Customer Service section.
I hope this helps.
Aug 16, 2011 | M & R Technologies Plastic Canvas Design...
Sonic the Hedgehog CD PC version Windows 7 error. After installing the original gold colored Sonic the Hedgehog CD, and the patch for the program, Sonic CD loads the intro screen, then freezing, and a...
Hi, welcome to FixYa!
Forgive me, but I remembered that Sonic the Hedgehog a rather very old program, which is designed to be running in Windows 9x/ME. I bet that's why it's demanding an MCI driver because it's not compatible with Windows 7.
There are 2 solutions for this.
First choice is you can try to use compatibility mode to run this program. Right-click on the .EXE file of the games (or you can use also right-click on the shortcut on Desktop or Start menu), then go to Compatibility tab, check "Run this program in compatibility mode for", then choose "Windows 98 / Windows ME".
Second choice, you can use VirtualBox, install Windows 98SE or ME on it, and then install the DirectX, remember to install VirtualBox guest addition as well, configure Shared Folder so your Virtual Machine can access to your host OS, then install the game and played it inside your Virtual Machine.
I hope my solutions are working. Thanks for using FixYa!
Jul 06, 2011 | Computers & Internet
I have lost my software for Epson Perfection 1260 Scanner. I need to install in my new computer with windows 7. How?
go onto epsons website and download the driver or the installation file/ folder then process with any insruction enjoy
Dec 18, 2010 | Computers & Internet
I need the software to run it.
The manual and driver for supported OS versions are here: http://www.dxgusa.com/downloads . The manuals for all of their cameras are listed first and then the drivers. They are listed in order so the DXG-572V driver is in the third line, third from the right of the driver section.
The driver may not have been updated from the original which for Windows XP/ME/2000/98SE. In Windows Vista 32-bit the driver may work or the correct driver may be in the OS. For Windows 7 32-bit, use the driver built into the OS. (Microsoft's compatibility center provided the information.)
With the 64-bit versions of these newer versions of Windows, the compatibility is unknown. However, the driver from the DXG site will probably not work without the compatibility mode, if it works at all. For compatibility mode, right click on the exe file and choose Properties, select the Compatibility tab and set it to run as Compatible with an older version of Windows. Then right click and Run as Administrator. Otherwise, keep it on a computer with the older OS, use a dual boot with the older OS or a virtual computer with an older version of Windows. With Win7 Pro or Ultimate, you can use the XP mode for a free virtual computer. (Download and install Microsoft's Virtual PC and then XP mode; install the camera to the virtual computer.) All other methods will need a licensed version of an older version of Windows. The only issue with the virtual computer is that files can't be shared between the two computers directly. Put them on external or optical media to share them with the real computer.
I hope this helps.
Dec 14, 2010 | DXG Technology DXG-572V Digital Camera
MTK 6218 USB EXTRECTED DRIVER NOT INSTALL
i cannot install mtk gprs usb driver for hitech pc suite. it is not compatible for window xp. how did i install to window xp?
Sep 06, 2010 | Microsoft Windows XP Professional With...
I need audio sound driver for windoes 7 ihave lenovo 3000 g430 4152 38q model
I think that the audio driver will be automatically installed by the OS. Try to make Windows updates. If not, the drivers should be on Lenovo 's website
Dec 29, 2009 | Lenovo 3000 Y410 Laptop
Computers & Internet Logo
394 people viewed this question
Muntejaya Ginting
Muntejaya Ginting
Marvin
Marvin
