Question about Avaya 5610 IP Phone
Hi, I want to know my phone (Avaya IP Phone) Mac address.
Posted by shineb on
Oliver Meilak
    Scholar:
  • 38 Answers
Press options then View IP Settings Press Right arrow once , Select Miscellaneous - Press Right arrow once and MAC address should be listed there.
Posted on Jan 03, 2012
4 Related Answers
Anonymous
SOURCE: Avaya 5610 IP Phone
Press mute reset (mute 73738)
Posted on Oct 21, 2008
Anonymous
SOURCE: How to configure Avaya's IP Phone 5610?
What IP did you give the phone? When it says discover, its looking for the call server, which it is not finding.
Which system is this on? If IP office, you may need to build an IP route in the system for that subnet.
Posted on Feb 15, 2009
Anonymous
  • 10 Answers
SOURCE: Avaya assighning New static IP address after IP address conflict
If you need to reconfigure the phone press "mute"RESET# where the alphabets correspond to the digits button they appear against on phone. E.g. for R press 7... and so on ..... then the phone will ask reset values? press # to reset and reboot the phone. Then key in the correct IP address for phone .... call server IP address ... router .. files server .... VLAN ID etc ....
If all the settings are done correctly ... and if the phone gets the reach ability to the call server it will work fine...
if you are unsure of these settings.... go to the menu and network options of any working phone and get the correct values from there
Posted on Apr 02, 2009
Anonymous
SOURCE: How do you reset an Avaya 9620 IP Phone to factory
Reset codes for phones: On all 96xx phones except for the 9610: To access Craft (the menu with the reset choices) from the phone, press the Mute Button + "CRAFT#" That's 27238# on the numeric keypad. This will cause the Craft Procedures menu to be displayed. Just scroll through the menu and follow the soft key prompts to get to reset or clear.
Posted on Nov 19, 2010
Testimonial: "Thanks dude, you rock! That is absolutely the correct answer."
Avaya 9620-ip phone DHCP conflict
Give it a static address OUTSIDE the DHCP scope.
Aug 21, 2012 | Avaya 9620 IP Phone
Hi I buy the new phone AVAYA 1616I, but it does not work, it always "finding router" can you help me onm this?
Hi tung_nd,
I see that your are having issues with your AVAYA, see details below.
* First find out the IP address of your Router.
*Inout that IP address in your AVAYA, this should make you AVAYA detect the Router or Network.
*once the Network is detected then you can set you AVAY for use.
Your AVAYA will need an IP address to connect to this will enable it for use, this should fix your concern.
Make sure that you have all the details that you need to be able to set up your AVAYA like the port number that it wwill be using in the aNetwork.
There will be 2 ethernet ports on the back of your AVAY one will be connected to the Router which should give the AVAY the power to turn it ON and the network connection to provide data transfer, the other ethernet port will be connected to your computer this is where the data from the router goes to if you have files that are shared in the network, and if you are running application from a Network.
I hope that this will be helpful regarding your query.
Have a nice day,
mvincentc
Apr 28, 2011 | Avaya 1616 IP Phone
My voice mail stopped working since BT changed its IP address. The PC where the Avaya Phone manager is installed is connected to the network through this BT router. How can I restore the Voice...
What was changed? The IP address of the phone system or the IP of the voicemail PC?
You just need to go into manager and change the IP of where the voicemail is in the SYSTEM>VOICMAIL tab.
Mar 23, 2011 | Avaya 5400 Series 5410 Phone
Commands for forwarding call to mobile phone
Link
Kindly refer to above link for Avaya Manual to know how to activate various phone features.
Thanks.
Apr 07, 2010 | Avaya 4610SW IP Phone
How do I get the phone mac address
Or Manually-
Pull the black stand off the bottom then remove the grey large plastic bit below the ethernet ports under there there is a sticker which contains the MAC address.
Regards,
Oliver
Feb 04, 2010 | Avaya 5610 IP Phone
Phone going to DHCP mode
You probably need to change the text file that gives the phone its information.
Get a new 46xxsettings.txt file from the avaya website and replace the one in your directory.
Sep 16, 2009 | Avaya 4610SW
Applying QoS to WNDR3300
You may stop what you are doing right now. Nothing you do will work regarding QOS and your Avaya IP phone?
Is this a hardware VPN, or a VPN remote phone? (vpn client on the phone)
Depending on what system you are connected to, an IP Office or a communication manager, there might be settings to do, but none of them are qos.
QOS is inserted on the LAN, once the packets leave the LAN and hit the open internet, there is no QOS.
You might be able to change the compression algorithm the phone is using, which might help.
Jul 30, 2009 | NetGear WNDR3300 - RangeMax Dual Band...
The phone is looking for the calsrv ip address, which it cant see. So it is trying to "Dsicover" it.
Go to another phone and press "mute"ADDR#
You can then see the ip address information and input it into the phone that is incorrect.
Mar 04, 2009 | Avaya 5610 IP Phone
Feb 13, 2009 | Avaya 5610 IP Phone
IP phone to IP phone through an IP trunk Issue
Is this an IP office? If so, maybe try to untick the "direct media path" box in the extension tab.
Jul 07, 2008 | Avaya 4610SW IP Phone
Avaya 5610 IP Phone Logo
3,847 people viewed this question
Top Avaya Computers & Internet Experts
Vincent G
Vincent G
k24674
ray gallant
Are you an Avaya Computer and Internet Expert? Answer questions, earn points and help others
