Question about Toro Lawnmower 20099 Mower Mowers Lawn
How do I remove the blade holder disk from an old Victa lawnmower?
Posted by Gerald Sabel on
Where can I purchase blade bolt set CA09164 and felt caps and washer set CA09028S for old toe cutter victa lawnmower?
i am sure that the bolts come with the blades as sets and there hasn't been a change since victa started
Talk with a mower shop as they have a selection of bolts and kits
Mar 29, 2017 | Garden
I have recently been given a Victa Catch and Release Lawnmower,but no manual. How much oil do I put in before commencing use. And How do I drain dirty oil?
Victa catch and mulsh ?
search pops these up as 4 strokes
which model and a internet search gets you its user manual
start with 600 ml oil and top up as required
try not to over fill
look for drain plug up under blades or on the side of motor
Nov 06, 2016 | Garden
Victa lawnmower manual 460 Pro
You want a manual for a victa or are you looking for an answer regarding a victa? If you want a manual then a good lawnmower dealer can probably help, if not you can try www.buyamower.co.UK or f.g.adamsons
Oct 14, 2014 | Garden
Lawnmower manual FOR A VICTA TWO STROKE
With a Victa lawnmower you must be an Aussie!! Try Retrevo Manuals.com A bita dicken around but shift hot for all sorts of directions
Jan 04, 2014 | Sewing Machines
My electric lawnmower sometimes does not start, just humms. Then I TURN IT OVER, AND TURN THE BLADE A LITTLE BIT. the blade feels hard at first but soon feels loose. then it wil start as normal
The lawnmowers electric motor has a bad spot on the armature. You need to replace the electrical brushes that contact the motor. If you are lucky you may just need to clean them and reinsert them in to brush holders.
Nov 25, 2013 | Electric Lawn Mower
I have a problem with my ride on mower. we need to replace the belt that drives a twin cutting disks on a Victa 4013TX but cannot find any diagrams to help.
4013 HT is a Victa with a 13hp briggs and stratton engine normally with a twin blade 40in deck. These were badge engineered Noma mowers and essentially equivalent to murrays made at the same time. Check diagrams for murray decks to find one with the same deck configuration.
Jan 08, 2011 | Garden
Looking for a victa pro 12 ride on mower parts catalogue
what year? and if you can post a picture it can be more helpful. Victa ride ons were made by other manufacturers with Victa stickers on them.
Oct 02, 2010 | Briggs & Stratton Garden
My victa statesman lawnmower turns over then dies
first thing to do is take gas tank off and clean it good, remove gas line & blow out. you must remove carb. & give it a good cleaning, blow out all passages, you may need a new carb. kit.
Dec 14, 2009 | Garden
Replacing lawnmower blades on 38 inch yardman
Need to plug spark plug [for safty]. Install 2x4 blocking between blade and chassy,use clamps.Coat threaded area with wd 40 and torque in clockwise position,not counterclockwise to remove old blade and install new turning bolt counterclockwise or [unscrewing direction].
Please rate. Thanks jj505
Mar 28, 2009 | Mtd Products Yard Machines 158CC Tiller
Victa lawnmower
how do you replace the zip cord on a victa tornado last years model
Oct 12, 2008 | Garden
Toro Lawnmower 20099 Mower Mowers Lawn Logo
397 people viewed this question
Top Toro Garden Experts
Dennis Key
Dennis Key
Marvin
Marvin
dannydoesita
Are you a Toro Garden Expert? Answer questions, earn points and help others
