SOURCE: For SMC7904WBRA :: How to use Cable Modem on ADSL router/modem combo?
Did you have DSL prior? if so, was the MAC address cloned to the router? You may need to check that setting, its pretty common with this type of setup
Looks like your device does not support playing router for cable internet. Would recommend you get an actual router, or alternately if you have a computer with two network adaptors you could plug one into cable modem, plug other in to LAN side of router, then configure turn Windows Internet Connection service, will need to disable the DHCP service on the router. I highly recommend you get a real cable/dsl router to do this tho. Linksys 54g series has been one of my favorites. Router homepage on SMC site. http://www.smc.com/index.cfm?event=viewProduct&localeCode=EN%5FUSA&cid=1&scid=4&pid=1588
SOURCE: WLAN does not work
Can you try and reset the router once. I guess that should help . There should be a reset button behind the router and the reset procedure should be present in the manual
SOURCE: No internet connectivity after upgrade firmware
1,there is a reset button
2,press this using any pin with power
3,automatically restart
4,connect your router with pc
5,type 192.168.1.1 on the browser
username:admin
password:admin12 or admin
configure router
enable dhcp
