HP DeskJet 940c InkJet Printer Logo
Posted on Dec 11, 2010
When i turn on printer the x button flashes and wont print
Flashing green start button konica minolta bizhub 250 and wont print
what doe the screen say????????????????? open close front door power completely off and on
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
3answers
Hl1440 drum indicator flashing
ok turn it off take the toner out clean all the terminals put them back in make sure everything is closed properly turn the machinie back on and let me no what happenes then
Lp2844 wont print, just added a new roll and continusly feeds through without stopping till i disconnect the power?
  • Turn the printer off.
  • Remove the roll and re-fix it.
  • Press and hold the green power button.
  • Turn the printer on and release button after the first flash of LED light.
  • The printer runs a self test print.
  • Turn it off and then on again.
  • Now you can print.
Thanks!
2helpful
2answers
How to stop printer from printing an extra sticker when it prints?
Hi
  • Press and hold the green power button and turn on the printer.
  • Release after first flash of led light.The printer will run a test print.
  • Now print!
Hope it helps.Thanks!
1helpful
Hp deskjet 948c. What Do The Button's Do
buttons and lights The HP Deskjet printer buttons let you turn the printer on and off, cancel a print job, or resume printing. The lights give you visual cues about the state of the printer
sayurisan20_33.jpgcancel button
print cartridge status symbol and light **The light above the Print Cartridge Status symbol flashes when a print cartridge is low on ink or incorrectly installed.
sayurisan20_35.jpg resume button and light
**The light above the Resume button flashes when an action is required such as loading paper or clearing a paper jam. When the problem is fixed, press the Resume button to continue printing.
sayurisan20_36.jpg power button and light **
The Power button turns the printer on and off. It takes approximately five seconds for the printer to turn on after you press the Power button. The green light above the Power button flashes when printing is in progress. Caution! Always use the Power button on the front of the printer to turn the printer on and off. Using a power strip, surge protector, or a wallmounted switch to turn the printer on and off may cause premature printer failure
1helpful
Flashing red light wont print last cou[ple of days printing black lines every now and then and now wont print tried putting new roll in still wont work
Autosence your printer by turning it off and then hold down the feed button while turning it on and release feed button when light flashes red.
3helpful
Canon Pixma iP2000 wont print black ink?
Canon IP 2000 / reset
1. Turn off printer
2. Hold down Resume button and press Power button.
3. Keep holding down Power button and let Resume button go.
4. Press Resume button 2 times then let BOTH buttons go.
5. Green lights will flash and then stop blinking.
6. When green lights are solid, press the Resume button 4 times.
7. Press the Power button and the printer should turn off, if not,
press the Power button once more.
8. Your printer should respond as normal..
Power button flashing on-off, not printing
My D1660 printer's on/off button won't quit flashing. It's connected to my laptop.I've tried to turn it off, but it won't respond. Now there's a beeping from my laptop to go with it.
Wont Print
it has a paper jam. just press the paper feed button.
2helpful
2answers
5 amber flashes
Operator error.
Press printer's RESUME button.
If this doesn't clear the error, cancel printing and turn the printer off and then back on.
When press Resume button, ip3000 not responed(not print)
k24674
Grand Canyon Tech
Grand Canyon Tech
