Question about HP Color LaserJet 2600n Printer
How do I fix ink that is bleeding on both sides of paper when printingon an hp laserjet 2600n?
Lance Hill
    Genius:
  • HP Master
  • 1,739 Answers
An on-line illustrated version of the manual guidance on print quality settings can be found here:
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00316826&tmp_task=solveCategory&lc=en&dlc=en&cc=us&product=445987#N1323
Thihs may or not be helpful in identifying your particular problem. If you have not already done so I suggest you lok at updating your driver as well as downlaosing the HP Diagnostic Tool for you particular operating system:
Trust this is helpful. Don't forget to vote. :)
Posted on Dec 11, 2010
Testimonial: "Thank you for your help! It fixed the problem. And also thank you for the very quick response!!"
My HP Color LaserJet 2600n is printing with small black dots on the left side of the paper. The toner and ink was recently replaced. Is there a plausible reason for this? Thank you!
Could be toner build-up on the fuser sleeve. Pull out the fuser and check the rollers for spots.
Try running cleaning pages before replacing fuser.
Jul 28, 2011 | HP Color LaserJet 2600n Printer
I have the Hp 2600n color laser jet and it when i print anything it just repeats all the way down the page like the ink is bleeding
When the printer is repeating text, ghosting, it's usually caused by the fuser. The best way to fix this problem is to replace the fuser in the printer. Depending on how much toner you have left and the price of a new fuser, it might be more cost effective to buy a new printer.
Feb 22, 2011 | HP Color LaserJet 2600n Printer
Crease down the left hand side of the page black marks and hole in paper
Run cleaning page until excess ink is cleaned. Dont let cartrages run below 7 percent CK paper type settings
Jul 10, 2010 | HP Color LaserJet 2600n Printer
Blue all over transfer belt when paper prints hp printer 2600n
the blue ink is leaking, you have to clean the transfer image. and buy all four toners a new
unaasp192
Apr 11, 2010 | HP Color LaserJet 2600n Printer
My 2600n is ghosting when printing black and labels are not printing correctly, the ink does not stick to the label, any ideas?
Sounds like a fuser problem.
Check the hp website, there was a firmware upgrade for fixing problems.
This may help, but you may also have a more involved problem...
Check print out on plain paper, and print the configuration page.
Dec 18, 2009 | HP Color LaserJet 2600n Printer
PAPER JAM AT TOP OF COPIER
top of the printer do not come off. it is clipped to the sides.
to access the output paper path, you need to remove all of the ink cartridges.
Jan 05, 2009 | HP Color LaserJet 2600n Printer
I have a HP 2600n Laserjet... When I print a sheet my red toner seems to bleed in the paper that I am printing on...
Try doing a few calibrations.If this doesnt work then change the Magenta cartridge. It sounds like the cartridge is faulty.
Jan 03, 2009 | HP Color LaserJet 2600n Printer
In printing a black shed all the paper
May 18, 2008 | HP Color LaserJet 2600n Printer
HP Color LaserJet 2600n Printer Logo
717 people viewed this question
efs_perpends
efs_perpends
Muntejaya Ginting
Muntejaya Ginting
