Question about Vehicle Parts & Accessories
Will the excalibur touch remote work with another excalibur alarm i dont have the alarm model number but do have the alarm that i have on my car remote fcc # and it is a remote start alarm too the fcc number is elvntrbb
Posted by keithsuggs on
Alan H
  • 139 Answers
The Touch remote can be used with any Echo compatible systems. These systems can be identified by their model numbers. Systems ending in E, EDP and EDPB are Echo compatible.
Posted on Dec 12, 2010
Had to disconnect battery and now no features on remote work
1991 honda accord security light flashes car will not turn on security light off car will turn on how can i disengage security system
May 23, 2010 | Excalibur AL1810EDP Remote Start Alarm 2...
Need instructions to program and operate my Omega Excalibur K9 car 3-button remote entry.
Your best bet for this would be to go to the Omega website. Be sure you ahve your make and model number of the alarm. Good luck and please rate. Use the link below to retrieve your manual.
www.caralarm.com/manuals.asp
Mar 15, 2010 | Vehicle Parts & Accessories
Only one of my my k-9 mundial keyless work the other seems fine but wont activate.
Try to reprogram the remotes to the alarm. Have your vehicle key and both remotes ready. The way to do this is as follows:
1. Turn ignition key to run position.
2. Within ten seconds push the valet button 5 times.
3. The siren will give a chirp, indicating that you are in programming mode.
4. Press the large button on the first remote. A chirp will be given as confirmation.
5. Press the large button on the second remote. A chirp will be given as confirmation.
6. Turn off ignition and remove key. Alarm will give long chirp indicating exiting program.
7. Try remotes. Both should be working.
For the next 48 hours, every time the vehicle is starting the siren will chirp indicating that remotes have been programmed. After 48 hours this feature will turn itself off. Also keep an eye on the alarm light as it will also blink the number of times as remotes are programmed every time the ignition is turn on.
Hope this information helps. Please rate. Thank you.
Mar 04, 2010 | Excalibur. K9-MUNDIAL-SS Entry Level Auto...
Trying to program a new remote to my car alarm ''excaliber'' k9 remote
turn key to on position push valet 5 times then hit lock on the remote
Dec 26, 2009 | Excalibur. K9-MUNDIAL-SS Entry Level Auto...
Excalibur car alarn
i have a Excalibur AL1830EDPb Remote Start Alarm 2 Way. I only have a range of about 60 ft from from the car, should this not be about 3000 ft
Jul 26, 2009 | Excalibur AL1810EDP Remote Start Alarm 2...
Vehicle Parts & Accessories Logo
293 people viewed this question
Top Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Lawrence Oravetz
Are you a Vehicle Part and Accessory Expert? Answer questions, earn points and help others
