Question about Internet Avg AVG Security V8.0 WIN - 2 Year - 1 User Download Version for PC
Cannot display window internet problem in DNS
Posted by joseph chico on
dhnguyen
    Sergeant:
  • 281 Answers
1. start a DOS command prompt (run as administrator)
2. Type in the command:
ipconfig /flushdns
ipconfig /renew
Does it then work?
Posted on Feb 09, 2015
Carlos L. Glez
    Loyalty:
    Visited the website for 30 consecutive days.
  • Internet Master
  • 419 Answers
I think with this application can solve your problem NetAdapter Repair All In One
Posted on Feb 08, 2015
DNS connecting problem
Try restarting your DNS client setting
Instructions
    • 1Click the Windows "Start" button and select "Run." Enter "cmd" into the text box and press "Enter." This starts your Windows command prompt.
    • 2Type "net stop dnscache" to stop the service. It may take a few seconds for the service to stop.
    • 3Type "net start dnscache" into the command prompt and press "Enter." This restarts the DNS service on the machine. The DNS service restarts.
Or you Contact you Internet service provider they should provide you their DNS setting
tip
How to change your DNS (Domain Name Server) on your Windows computer. Faster...
Hi Thanks for looking.
Your ISP (Internet Service Provider) provide you with Domain Name Server which translates website names to language that computer can understand which is an IP address of the website. Faster the response from DNS the faster your website will load.
In this tip I will explain how to change your Domain Name Server (DNS) in order to speed up your web browsing.
Go to
Start--->Control Panel--->Network Connections
Please note that you may need to switch to "Classic view of Control Panel in order to see default view.
Right click on network connection that you are currently using and choose "Properties"From the list in box choose "Internet Protocol (TCP/IP) and click "Properties" below. You will be shown a window with two tabs and in General Tab you will have options to change your IP address (we don't want to touch this)and option to set DNS manually.
Click on " Use the following DNS address"Now you can change your DNS to whatever you like. I recommend "Open DNS" which is faster then most of default DNS's.
Ok to change your DNS to "Open DNS you need to type 208.67.222.222 in preferred DNS box and 208.67.220.220 in Alternate DNS box.Click OK and then OK again.
Bravo! You just changed your DNS.
slow internet, website will not load, speed up my internet, how to speed up my internet
on May 07, 2010 • Computers & Internet
NOT RESPONDING TO INTERNET
Let's try setting a static DNS server and see if that takes care of it:
1. Click on Start, choose Run, type in ncpa.cpl and press Enter to open Network connections window.
2. In the Network Connections window right click on Local Area Connection and then select properties.
3. Click Internet Protocol (TCP/IP) and then the Properties button in Local Area Connection Properties.
4. Choose Use the following DNS server addresses: and type in 4.2.2.1 for your Primary DNS (you can leave the Alternate DNS blank).
5. Choose OK/Close to the windows and test Internet Explorer
Let me know if that helps
Thanks & Regards
Anas K A
Can't get to websites that require a log on ; can get on to internet but any place i have to log on and give a password, it says internet explorer cannot display page; can't access email so don't email
got to run then type CMD enter a dos promt will show on the screen, type IPCONFIG, check your IP address if it istarts with 169 then that is APIPA a windows feature if threats are tryin to get in your system blocking any outside access to you system from any network, also check if the default gateway of your router or modem is detected, if not then try check conenction if all are ok from router to modem and if wireless is turned on thr router providing a signal to your computer for wireless, if all Addressess are ok and still you get page cannot be displayed type in the DOS promt ping 69.147.125.65 this is yahoo.com if this pings yahoo's ip address then your problem is with the DNS of your Internet service provider, try this to renew your DNS ipconfig /flushdns then ipconfig /registerdns to renew ur DNS on the systm if still fails ty a different browser and if all else fails call ur ISP provider posibble something on the internet service is wrong or downtime issue on the internet
Dns problem on windows 7
Manually assign a DNS address of 8.8.8.8, restart and try again. If this doesn't work, run an elevated cmd prompt with administrative priveldges - type in netsh int ip reset reset.txt then it will require a reboot. This will reset your windows network interface to defaults.
1helpful
4answers
Internet explorer not working
Check whether your internet connection is working properly or not. To check this ping to your DNS Server of your internet service provider. If you get a reply from the DNS Server then the problem is with your browser, if so then install another browser like Mozilla Firefox or Google Chrome. If you dont get a reply from DNS server contact your ISP and resolve the Issue with them.
2helpful
2answers
Cannot access server dns error occuring with internet explorer 6.0
make sure your dns setting is correct follow this :In the Windows Control Panel, >go to Network Connections.> Open 'Local
Area Connection' and select 'properties'.
Doubleclick on Internet Protocol (TCP/IP)
check or Select 'Use the following DNS servers'. Put the correct dns address in the primary
address window. Leave the alternate blank. Close all the Windows. Try
browsing again
Hi i have a sky router n need my secondary DNS?
If you are using windows, open Command Prompt. Type "ipconfig /all" without the quotations. This will display your IP and DNS address.
If your router is connecting to the internet successfully, you don't need to change DNS settings. For the PS3 you just need to know the SSID of your router and the WEP or WPA password if your network is secured.
Page can not be displayed
Understanding the information contained in an e-mail header. Although not all e-mail programs will display this information because of ... of the mail servers that the e-mail has passed through to get to your Inbox.
Windows NT 4.0 modem troubleshooting.
Install Modem - If the modem has not yet been installed you will get prompted ... provided by your Internet provider as well as a DNS setting if required.
Good Luck , please dont for get to vote/Thank You.
Internet Avg AVG  Security V8.0 WIN - 2 Year - 1 User Download Version  for PC Logo
Ekse
 Francisco Mauricio...
 Grubhead
Grubhead
