RCA RTD155 System Logo
Question about RCA RTD155 System
How can I set up the speaker distance in the setup menu? I get to that point buy am unable to change the numbers that are shown.
Posted by whvernon on
What is the problem for no spark on the points
If after u change timing belt it is cos of u dont setting a timingbelt very well need to set a timing belt with it mark of pully as it manual shown..if it setup good check ur contack poin.when u swith on main suis there is a 12v will apear at positif terminal at that contact poin.than adjust it gap of contact poin with filer guige within ur disributur is shown at piston number one.after doing all this setup..put itlike normal ang try starts a engine..if no have fireing..change ur ignition coil our need a wiyerman to help..
3answers
No sound or power
IF ALL WIRES ARE CORRECTLY BEEN SETUP OR INSTALLED THEN THE NEXT STEP IS TO CONFIGURE THE SYSTEM TO WORK ON ALL SPEAKERS...
Before the setup of the speakers' channels
  • Press the SURR. button on the remote to select multichannel surround mode before adjusting the speaker settings.
  • In case of sound distortion, press and hold the SOUND button to select another transmission channel for the wireless rear speakers.
Setting Speakers' Channels
  1. Press 060227073157_11231.jpg to stop playback, then press SYSTEM MENU.
  2. Press 060227073234_11234.jpg repeatedly to select { Audio Setup Page }.
  3. Press 060227073211_11232.jpg060227073221_11233.jpg to highlight { Speaker Setup Page }, then press 060227073234_11234.jpg.
  4. Enter its submenu by pressing 060227073234_11234.jpg.
  5. Press 060227073211_11232.jpg060227073221_11233.jpg to highlight one of the options below at a time, then press 060227073234_11234.jpg.
    • { Speakers Volume } – Volume level setting for individual speakers (-6dB – +6dB).
    • { Speakers Delay } – Delay times setting in relation to the listening position/ distance for centre and surround speakers.
  6. Press 060227073245_11235.jpg060227073234_11234.jpg to adjust to the setting that best suit your surround sound needs.
  7. Press OK to confirm.
Notes:
  • 1 ms increase/decrease of delay time is equivalent to 30 cm change in distance. Use the longer delay time settings when the rear speakers are closer to the listener than the front speakers.
  • The test tone will automatically be generated to help you judge the sound level of each speaker.
On a sony str-dh710, is there any difference in the amp. level between setting the distance levels and the db levels? Also using the Video 2 input on the front of the reciever I'm not able to get any...
.. or read the manual about setup and getting multichannel audio from 2-channel sources. Calibration and Selecting a Sound Field.
Distance is linear spatial separation of two points. dB is audibility, sound pressure level, volume. The distance setting affects how the various channels are delayed to arrive at the primary listening position at the appropriate time to provide a plausible sound field. Simply making one or more speakers louder or softer will not affect the spatiality of it.
How to set the decimal place to 3 places on a casio fx 300ms calculator
Decimal Point and Separator Symbols
You can use the display setup (Disp) screen to specify the symbols you want for the decimal point and 3-digit separator.
• To change the decimal point and separator symbol setting, press the MODE key a number of times until you reach the setup screen shown below.
Display the selection screen. (Disp) 1.
Press the number key ( 1 or 2) that corresponds to the setting you want to use.
1(Dot): Period decimal point, comma separator
2(Comma): Comma decimal point, period separator
2helpful
Sony STR 1200 audio-visual sync
Yes it can be fixed.
Enter the speaker setup menu and toggle till you get to the selection for speaker distance. Assuming that you have your speakers properly positioned for correct reproduction of 5.1 surround sound, decreasing the setting for speaker distance will help. Start with 3-4 feet closer from the current setting. This enables the on board DSP (digital signal processor) to delay in milliseconds, the sound output for closer distance settings. It can also advance in milliseconds as well for further distance settings FYI.
Onkyo DV Sp500 DVD player set for US region but i Have DVDs from Australia - is there a code to unlock the player or do i need to purchse a new one?
icon_minipost.gifRegion code hack posted by Victor Lazlo, July 14 2003:
Steps to change Region code:
1. open setup menu (with setup key)
2. select menu point 'General' (dt. 'Allgemein')
3. select sup-menu point 'Setup-Menu Mode' (dt.Setup-Menü-Modus)
4. at 'Setup-Menu Mode' select 'basic' (dt. Einsteiger)
5. confirm 'Basic' sellection with 'Enter' key
6. now push 'Display' key at your remote control, the present regent code will be displaid
7. to change the region code push 'Condition Memory' key (COND.M) at your remote control, afterwards a number key representing the region code you want to select
8. after a successful change, the disply of ther regional code will disappear
9. if pressing the 'Disply' key again the changed regional code will be shown.
Remark: Macrovision copyguard in gerneral will be switched off after that modification
refer to:http://www.videohelp.com/dvdhacks
42helpful
2answers
Centre input active
Go to..
Menu / Setup / Source
Scroll down and Highlight Center Input, And select Off.
If it dont work first time round, Disconnect all Audio/Video leads from TV, and try again.
Pioneer VSX-1018AH-K 7
Check if Zone 2 is 'On' if it is set it to 'Off' using the front panel button. Hitting the 'Recieiver' and 'Setup' buttons is the correct way to set the system up.
1helpful
Mic
First, be sure to have the latest software from logitech's website, and the latest MSN.
Then perform the following:
Execute the audio and video setup procedure within MSN Messenger 7.5. This procedure will allow you to assign an audio input and audio output device, as well as assign the video device of your choice to work with MSN Messenger.
1. Launch MSN Messenger and select the “Audio and Vide Setup” option from the “Tools” menu.
Figure 1
2. Click “Next to begin the setup process
Figure 2
3. In the “Speaker Setup” window, select the output device you would like to use with MSN Messenger. This step is specific to speakers or headphones. If your speakers or headphone device is connected to your computer, select the device by using the drop down menu provided. You can also set the desired volume level and click “Play Sound” for an audio sample. Once you are comfortable with the your selected options, Click “Next”
Figure 3
4. In the “Microphone Setup” window, select your desired input device from the drop down menu provided. This selection will be specific to a microphone connected to your computer. If your Logitech video camera has a built-in microphone, this option will be presented as “Logitech Mic” with your camera model name in parentheses as shown below. If you have an external headset device connected to your computer which hosts a microphone, select the devices name or model number in the drop down menu. Once your device is selected, adjust the microphone volume level to your preference and click next.
Note: the microphone volume level may need to be tested in order to find a comfortable listening level for you contacts. As a starting point, try setting the level midway and adjust when necessary by re-executing this procedure.
Figure 4
5. In the “Webcam Setup” window, select the video device you would like to use with MSN Messenger. Once selected you should see a display sample in the window provided. You can also click the “Options” button to make camera specific adjustments. Once completed, click the “Finish” button to apply your changes.
Figure 5
6. Once you have completed this process, MSN Messenger should now know the audio input (microphone) audio output (speakers or headphones) and video device (webcam) to use when engaging in an audio and or video conversation.
2answers
Zone 2
I am sure this isn't it, but if all components are connected digitally Zone 2 won't work. It only allows analog connections, so anything attached via HDMI, etc. will not be able to be output to Zone 2.
Top RCA Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a RCA Audio Player and Recorder Expert? Answer questions, earn points and help others
