Question about GE Refrigerators
My GE Refrigerators (Model: PSS25MGNACC) is accumulating ice on the back panel in the freezer, and when the ice is thick enough, the freezer becomes not cold enough. We have to shut down the power and let the ice melt, and the freezer becomes cold again. But this only last a few days as new ice will buid up again. What could be the problems?
Posted by yanzhangliu on
ray gallant
    Top Expert:
  • GE Master
  • 68,585 Answers
Auto defrosting heater or timer has possibly failed . call for a repairman to test the machine
Posted on Oct 16, 2017
5 Related Answers
Sea Breeze
John Tripp
  • 4656 Answers
SOURCE: Ice melts water drips out of icemaker & freezes in a column
If your model is doing that I would consider looking at the defrost components. Look inside back of freezer for frost building a thin layer on the rear wall. If yes then unplug and remove the rear panel in back of freezer and defrost with a hair dryer. You have and air circulation problem or a defrost problem. Sounds like it's trying to defrost but we need to have a look at the evaporator coils in the rear behind that cover. First let me know what you find and we will go from there, Thanks Sea breeze
Posted on Aug 18, 2009
Anonymous
  • 290 Answers
SOURCE: Frost buildup in ice-dispenser tube
Open the freezer door and look down the ice chute while you shine a flashlite up the dispenser cute from the outside. If you see light around the chute door, it needs to be replaced. The problem you describe is almost always air laekage around that flap. Post back if you need more help.
Posted on Oct 20, 2007
woodchuck789
Charles T Nevin
  • 4070 Answers
SOURCE: GE side by side leaks water from icemaker tube
Your drain tube may be stopped up with ice at the upper end because it drains too slow because it's stopped up at the lower end in the evaporator pan under the unit at the floor. It can get dust and mold in it. Once you get the ice out at the top a little pressure with a turkey baster will usually clear it out. Flushing it out with hot water and clorox may help.
Make sure it drains quick enough to prevent refreezing. . The drain should be located below the evaporator coils on the lower back of the freezer.
Posted on Aug 17, 2009
heatman101
D. Floyd Kolb
  • 43501 Answers
SOURCE: My G.E Adora refrigerator freezer
Check out these tips...they can help you figure out whats going wrong with yourrefrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
heatman101
Posted on Sep 18, 2010
woodchuck789
Charles T Nevin
  • 4070 Answers
SOURCE: Amana Side By Side -
It sounds like you have a defrost problem.
DEFROST PROBLEM
The evaporator coil behind the cover on the back wall inside the freezer will ice up under normal conditions. Every 8 to 10 hours for around 20 minutes the defrost timer (or in most newer models the electronic adaptive defrost control) will turn the defrost heater on to melt the built up ice. There is a defrost thermostat which prevents the heater from overheating the freezer by breaking the heater circuit when the temp reaches close to 32 degrees F. The entire cooling system shuts off during the defrost cycle and starts back when the timer advances through the cycle.
If this ice is not melted it will continue to build up until the air can't flow over the coil to circulate the cold air through the freezer and into the fridge. The temperature change in the fridge is usually noticed first followed by the freezer.
If the defrost thermostat is bad, it can prevent the heater from coming on OR it won't turn the heater off when it gets too warm. It is clamped to the evaporator coil at the top to sense the temp. If it appears to be misshapen it is bad.
With an ohm meter it should show continuity when cold and none when warm.
You can also bypass(disconnect the two wires plugged into it and twist them together) the thermostat to see if the heater comes on then. If it does then you know the thermostat is bad and needs replaced.
The defrost heater is located on the evaporator. It is in a tube which is at the bottom and can also go up the sides of the evaporator. On some types you can see a burnt spot if it's bad. With an ohm meter it should show continuity from end to end when disconnected from the wiring in the freezer. You can also test the wiring for voltage when it's in the defrost mode.
If you have a defrost timer you can test it. It can be located under the fridge behind the kick panel on the front. Some are in the fridge with the controls at the top. You can turn the defrost timer till it clicks and everything shuts down. The heater should now come on. If it does, replace the timer because that means the timer is not running. If it doesn't, check the heater and defrost thermostat. Turn the timer again till everything starts back up to end the defrost cycle.
If you have an adaptive defrost control instead of a timer, replace it if the heater and thermostat test good. It is located in the fridge with the controls in some models and on the back in others.
Posted on May 27, 2011
I have a sheet of ice in the bottom of freezer compartment and frost. any suggestions
You either have a defective water control valve that allows water to seep into ice maker while the water control valve is off or your defrost drain found behind the rear panel in the back of your freezer.has become clogged. Click Here=> Leaking Refrigerators Just What may Be Happening If the dual water control walve is causing this the only way to fix the problem is to replace the water control valve. Much more on this page=> Leaking Refrigerators! This is a common tip so I will be placing this post and add as we go new ideas listed in Sea Breeze Tips Section. If you run into any problems along the way of repair please let me know, Thanks, Sea Breeze
Feb 12, 2012 | GE Refrigerators
Ice maker leaking
Are you sure it's the ice maker that's leaking? We have this model & ours accumulates a HUGE iceberg in the bottom of the freezer, but the water seems to be coming out of the back, at the bottom of the back panel, where the vents are.
Jun 29, 2010 | Maytag MSD2732GR Side by Side Refrigerator
Frost on back of freezer does not seem to be cool enough
Sounds like a defrost issue. The frost is caused because the defrost element heater is not working. Ice accumulates in the coils and blocks the air flow in to the freezer/refrigerator. GE refrigerators have an element heater behind that back panel under the evaporator coils. They are quite simple and inexpensive to replace. Use a hair dryer to defrost the coils to make the swap easier.
May 23, 2010 | GE 23.1 Cu. Ft. Side-by-Side Refrigerator...
Aug 17, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
I have a ge profile side by side model 25 serial number gss25tgmfww. last night it was left open for about 3 hours and when noticed, closed back up. still cool in the morning enough to keep food semi...
Maybe a 50/50 chance problem solved . A lot of frost , would probably be a defrost problem beginning though . I would remove the heater and check for continuity while disassembled .If heater is bad (most common problem with GE, not the only,but most common)Pt # WR51X10055 .Also make sure both fans are working , especially fan in freezer (may have to push lite switch in to check , or just listen .
Aug 02, 2009 | GE GSS25LGM Side by Side Refrigerator
Jenn-air fridge
is the defrost drain blocked(ice on freezer floor)
Jun 11, 2009 | Jenn-Air JCD2389G Side by Side...
There is always water accumulating under the freezer door on our side by side, we tried defrosting it but didnt help
SOUNDS LIKE YOU HAVE A CLOGGED DRAIN ON UR FREEZER,SIDE THE WATER COMES FROM WHEN THE FRIDGE GOES INTO DEFROST MODE, SNCE THE DRAIN IS CLOGGED THE WATER FINDS IS WAY SOMEHOW, RUNNING TO THEBOTTOM OF IT FREEZER ICING UP FOOD OR METAL RACKS,
GO ON THE FREEZER SIDE AND ON THE BACK PANEL REMOVE THE PANEL SCREWS AN YOU WILL SEE THE COIL LOOKS LKE A ALUMINUM GRILL.......KIND OF.....AN AT THE BOTTOM OF THE PANEL YOU WILL SEE A ALUMINM PLATE ON IT THERE WILL BE ICE, TAKE A BLOW DRYER AN MELT IT ALL, ONCE U MELT IT MAKE SURE THE DRAIN HOLE IS CLEAR,A CHEAP WAY AN EFFECTIVE IS TO TAKE A PIECE OF COPPER WIRE WRAPPED AROUND THE HEATHER ON THE COIL AN RUN ABOUT 2-3 INCHES INTO THE DRAIN....HEAT TRAVELS TRU COPPER WON'T BURN IT WILL JUST NOT LET THE WATER BECOME ICE AN CLOGGED AGAIN, I DONE IT MAY TIMES AN HAD NO MORE PROBLEMS ON DIFFERENT UNITS. GOOD LUCK! LEAVE SOME FEEDBACK.
May 28, 2009 | GE Profile 26.6 cu. ft. Side-by-Side...
TOO MUCH ICE
just switch off and melt the ice away with a hairdryer.
drain is behind the back panel inside the freezer
Dec 02, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
Freezer problem
check the gasket on door to make sure it seals good all the way around
Nov 08, 2008 | GE GSS20IEP Side by Side Refrigerator
Refrigerators Logo
48 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Mike McBirney
Level 1 Expert
gbob59
