Question about Toshiba Equium 100 PC Desktop
System in safemode, restart windows normally doesn't cancel safemode neither does earlier configaration Help
paul7of9
    Genius:
  • 1,189 Answers
  • Hello info88784, "I've read your situation, and I suggest that you can do the following. "Restart the computer, once you see the "Prompt Screen" to Press F2 or Press F12, quickly "Tap! the [DEL]key, located at the top [Right]next to the Scroll Lock, and END keys." You will know if you done it correctly, when you see the {Windows Boot Manager} Heading on the screen; at the bottom of the screen, it will read "Recovery Environment." Note: The wording may differ depending on the type & model computer you have. Now, there will be a long list of "Options" to choose from, select the option that best describes; Try each to fix the problem: Startup Repair, "Repair My Computer, and System Restore; or next time, "Press the [F8] button the next time you "Bootup" and choose the more {Advanced Options} select whatt best decribes; " In the [Systems Recovery] windows, "Configure Last Known Good Boot!" Follow all the instructions, and I hope all goes well. "I would appreciate if you could find the time to give a "Helpful Rating, its my only reward," knowing I could be of assistance! Thanks alot, paul7of9
Posted on Dec 10, 2010
CANT LOAD WINDOWS,915GLM-V KEEPS RESTARTING
Remove any add-on cards or devices to determine if they are the cause.
Reseat CPU, RAM and cables to make sure that are no bent pins and they are properly connected.
Google "memtest" download the tool, burn the CD, boot your computer using to the CD and have it run at least two full passes to make sure your RAM is good.
Plug hard drive into a working computer, download and install Acronis Drive Monitor (Free) to determine if the drive is in good health.
Swap out the power supply with a known good power supply.
The two toughest things to test are CPU and Motherboard but if you elimiate everything else one of these must be the cause. Start with replacing the cheapest one first.
I hope this helps. Good luck!
Jul 08, 2011 | MSI 915GLM-V Motherboard
Ok my problem is that when me Compaq Armada M700 PC Notebook boots up it goes to where the login thing is supplsed to show up but it done show up it will just restart after a few secionds
Hi jonathan,
I see that you are experiencing an issue with windows booting up and that it just restartrs all of a sudden.
well something in windows may have got corrupted this can be one of the causes or a possible software added can also do this to windows depends.
What we can do is as soon as you power the system on keep on tapping F8, this should show you options like Safemode, Safemode with Networking things like I said once you see this windows or page select safemode then press enter.
Hopefully it boots in Safemode if it does then you can do a system restore on the machine to restore it at least to adat when it was working properly.
System restore can be found by Clicking on Start, then All prgorams, Accessories, then system Tools you will see system restore this will give you the option to restore back to an earlier time and date.
If the compute does not boot into Safemode then most probably you will need to get a windows recovery disc for the re installation of windows.
I hope this helps.
have a nice day,
mvincentc
Jun 12, 2011 | Computers & Internet
My computer says configure updates and then it automatically turns off
This will be a long process of troubleshooting and may end up of restoring your computer to a factory settings. You can try the steps below:
First is boot up to advance boot options, to do this follow the steps below: -Turn off your computer -After pressing the turn on button start tapping F8 key until you see the Advance Boot Option. -Try choosing Last Known Good Configuration if it fail try Safemode, Safemode with networking or safemode with command prompt, if one is successful use system restore to restore your computer to an earlier date but if it fails you'll need to use your Operating System Disc to use the repair option.
Here's how to access system restore incase you're able to access Last Known Good Configuration, Safemode, Safemode with networking or safemode with command prompt: Windows XP: Click Start, point to All Programs, point to Accessories, point to System Tools, and then click System Restore select Restore my computer to an earlier time then select a bold date on the calendar and click Next on the Confirm Restore Point Selection page, click Next. System Restore restores the previous Windows XP configuration, and then restarts the computer. Then click OK on the System Restore Restoration Complete page.
Windows 7 and Windows Vista: Click Start, point to Programs, point to Accessories, point to System Tools, and then click System Restore select Restore my computer to an earlier time then select a bold date on the calendar and click Next on the Confirm Restore Point Selection page, click Next. System Restore restores the previous Windows configuration, and then restarts the computer. Then click OK on the System Restore Restoration Complete page.
If you're on safemode with command prompt: At the command prompt, type %systemroot%\system32\restore\rstrui.exe, and then press ENTER, System Restore window will pop-up then select Restore my computer to an earlier time then select a bold date on the calendar and click Next on the Confirm Restore Point Selection page, click Next. System Restore restores the previous Windows configuration, and then restarts the computer. Then click OK on the System Restore Restoration Complete page.
If all the steps above fails you need to use the recover disc or the operating system disc to do a repair on your computer. Revert back in case you need steps for using start-up repair.
Note: If the steps above and start-up repair fail there's no other option but to restore your computer to factory settings.
Apr 21, 2011 | Acer Aspire AX1700-U3793A PC Desktop
Its not loading to windows, what should i do?
If its not loading to windows,check first what would be the error message or to make it more easier try to reinstall the Operating System of your machine, just access the recovery manager. Hope it helps. =)
AnEspera
Apr 18, 2011 | HP Pavilion dv6000z Notebook
I have acer laptop. wanted to set user password but i went to system setup and the computer locked, requiring primary master Hitachi HTS545025B9ALock please help!
did you set the hdd to be locked?or does it have a password?try to open bios settings>reboot.hit del>then restore to default settings... if this does'nt work;try to do the restoration system..just follow this steps;
1.Before system run hit f8 then click safemode, or read the manual of your machine of what key to hit entering for options.on my machine i usually hit f8 then click safemode 2.your windows start in safemode,then click start>all programs>accesories>system tools>then system restore... 3.Click restore my computer to an earlier time.then click next,select date to when your machine works normally or never unlocked,click next>then click next. 4.The system reboot;pls wait till the process finish..click ok and your done....
hope this help yopur problems...gudluck
Feb 09, 2011 | Acer Aspire 5500 5570-2609 Laptop
System does not restart automatically using restrat fuction. system hangs and has to be manually switch off and again switch on manually
Go to Start> Run > type " msconfig"> "ststem configaration utility" window will apear, select the tab "StartUp"., select "Disable All" and apply and OK. it will ask to restart wait till it restarts. if it is not restarting. do the same thing in "Safe Mode". if you dont know hot to go to safe mode. Just press "F8" key when booting. the menu will apear, select "Safe mode" do above method in safemode and restart. this method will work in most of cases. best of luck.
Jan 28, 2011 | Computers & Internet
Hello, I have an Acer Aspire 5532 and the battery died while it was unplugged. Usually I just plug it up and press the power button and it will ask if I want to load Windows (normally, safe mode, etc.). I...
hi,
Try the below steps:
Shutdown the computer and Restart it, as soon as it restarts keep on tapping F8 key, now select, "Last Good Known Configuration" and hit "Enter" key. It should take care of the issue. If not, then boot the computer to "Safemode", to do so, restart the computer and as soon as it restarts keep on tapping F8 key, now select "Safemode" from the Advance boot menu. If it is booting to Safemode, then perfomr a system restore to previous date. If nothing happens, then you have to perfomr a full system restore.
Jul 30, 2010 | Acer Computers & Internet
When cp is bootin up, it goes to welcome screen an then is black screen, stays black except the mouse arrow is showin' it bwon't boot up no further,can sombody please help, Jack
Restart the Notebook and keep tapping the F8 key to access the Windows advanced options.
select Safemode.
Once you are in safemode, follow the below steps :
  1. Log on to Windows as Administrator.
  2. Click Start, point to All Programs, point to Accessories, point to System Tools, and then click System Restore. System Restore starts.
  3. On the Welcome to System Restore page, click Restore my computer to an earlier time (if it is not already selected), and then click Next.
  4. On the Select a Restore Point page, click the most recent system restore point in the On this list, click a restore point list, and then click Next.
    Note A System Restore message may appear that lists configuration changes that System Restore will make. Click OK.
  5. On the Confirm Restore Point Selection page, click Next. System Restore restores the previous Windows XP configuration, and then restarts the computer.
  6. Log on to the computer as Administrator. The System Restore Restoration Complete page is displayed.
  7. Click OK.
Mar 14, 2010 | Compaq Presario 700 470024-192 Notebook
Can't start windows normally and restore points will not work
Start in safe mode as you have been doing,Once you get to the desk top,Click start>Run>Type Msconfig and hit ok or enter,When the configuration window opens,Select start up Normal and click apply,The computer will restart in normal mode.
May 18, 2009 | HP Compaq Presario SR1538X (PX799AA) PC...
The system is getting restart continously,while booting
  • 1. Got to your Start menu and select “Run” option.
  • 2. Type in msconfig command and click OK. The System Configuration Utility program will then open.
  • 3. Select the BOOT.INI tab located at the top of the System Configuration Utility window.
  • 4. UNCheck the box labeled /SAFEBOOT and click OK.
  • 5. When asked if you prefer to restart the PC immediately, or Exit Without Restart, choose to restart the computer manually.
  • 6. Your computer will automatically boot into Windows XP Normal Mode when you will restart it.
Dec 16, 2008 | Microsoft Windows XP Home Edition
Toshiba Equium 100 PC Desktop Logo
83 people viewed this question
Top Toshiba Computers & Internet Experts
Lee Hodgson
Lee Hodgson
Muntejaya Ginting
Muntejaya Ginting
k24674
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
