Nikon N65 35mm SLR Camera Logo
A
Anonymous Posted on Dec 10, 2010
The batteries are dead on my N65, but when I pushed the button that pops the flash up, nothing happened. Wondering if that is because of the batteries or if the flash is stuck/broke?
Anonymous
Level 3:
  • Master 747 Answers
  • Posted on Dec 10, 2010
Anonymous
Master
Level 3:
Answers
747
Questions
0
Helped
177260
Points
2087
Battery is needed to unlock the catch then the internal flash will pop up. These cameras are programed to automatically pop up in certain modes so there is a little electric switch used not battery no switch. Don't leave the dead battery in the camera or you'll end up with more problems then just replacing the batteries.
Lenovo thinkpad t400 laptop wont open
try changing the keyboard because switch is on keyboard and use adapter to plug and test
Will not power up
If you tried to reset it and nothing happened, the battery may be dead. This happened to my daughter's Garmin GPS twice. I replaced the battery and bingo! I never understand why the unity needs a battery even when connecting it to the car's power cord...
How can i turn the flash off of my nikon n65 camera?
In the PSAM modes the flash won't pop up on its own. In the AUTO and vari-program modes, you can set the flash mode by turning the command dial while pressing the flash sync mode button (marked with a lightning bolt symbol). Select Flash Cancel (lightning bolt in a circle with a slash through it).
If you need a manual, you can download one at
http://butkus.org/chinon/nikon/nikon_n65/nikon_n65.htm
Hello, My 5yr old IBM R52 laptop will not power on.when i press the power button, nothing happen... it wont start/on.. also when i plug the adapter WITH battery,then battery going into charging mode,but...
bull 5 years, you bought with lies of amazon. 2008 made is 10 years to 2018. and all batteries are dead, CMOS and big one
worse big one shorted,
or is owner ship duration? 5
rule one remove that relic old huge battery first and run on AC power pack alone(even forever)
what you did is backwards, totally battery is the last test after the whole PC runs perfect again , see?
lenovo R52-nnnnn NO nnnnnn told. sadface.
try are
ThinkPad R52 Series
(MT 1846,1847,1848,1849,1850,
1858, 1859, 1860, 1861, 1862,
1863, 1870
12 PC based off R52, laptop.
still screen dead right, say screendead or black %100
say of fan blowds
tell beeps or flashcodes of any LED
or text errors to screen
and if BIOS is dead.
if all that dead that is power failing
we push the power button for 10 full seconds and release
that is the intel super secret safe reset.
still dead 100%
battery big still out, keep it out.
and AC pack disconnected for overnight
this is the HARD power reset.
this reset undoes power surge and latchup events.
still dead try new AC power pack did you use the wrong pack
shine flash light on screen see data CCFL tube are dead.
as all are this old frankly , die at 20,000 hours many do;
power pack 16vdc 72watts 4.5amps, only
wow free schematic leaked out,whooo hoooo
https://manualmachine.com/lenovo/r52/8197122-schematics/
One of the handsets is flashing "Warning Check Battery" It is a mi6896.  We have lost two of the handsets.  We don't know how to use the "Find Handset" feature on the base unit (the manual...
Find handset works by causing the handset, or handsets to beep when you push the button on the base unit, and until you find the handset and push the off button. If the handsets do not beep the batteries are probably dead.
We have a handset that flashes "Charging", and later, "Connecting", but it never connects. When the handset is removed from the charger the handset shows "Place in charger". By process of elimination I have determined that the handset has a problem. The problem is NOT with the battery OR charger. I hope this info helps you.
-Vector721
1helpful
Uniden 900 MHz EXS 9110 is dead
Sound to me like you just need to replace the battery pack. Radio shack is a great place for phone batteries. If not, try www.batteriesplus.com
Good luck.
Flash
You might not have your lens set to the minimum aperture setting (the largest number) if it is a non-G lens.
1helpful
My laptop won't turn on
Charlotte
Can you remove the battery? If so pop it out and leave it out for a couple of minutes then pop it back in and see what happens.
Regards
Nick
Top Nikon Photography Experts
Tony Parsons
Tony Parsons
Pallikonda Nisha
Level 1 Expert
Are you a Nikon Photography Expert? Answer questions, earn points and help others
