SOURCE: my canon copier ir 2016j give an eror report code
- check the connector of the fixing film sensor.
- replace the fixing film sensor.
- check that the fixing film is not broken or out of place
SOURCE: we have canon copier ir 2016j, it started giving
Error code E007 on an ir2016 means that the fuser film has a fault. The fuser film is the black sheet that melts the ink into the paper on the final stage of the copy process. It more than likely has ripped apart. You will need to call a service tech for this one.
SOURCE: pliz help my copy is
This is the standard Canon error for the fixing film of the fuser assembly not rotating. The film is most likely damaged and will have to have the whole fixing film assembly replaced. It's not a job for the lay person to do. Best left to a technician. Good luck.
