Question about RTO THERMAL DYNAMICS CUTMASTER 52 PLASMA CUTTER 1-5130- 1
The exclamation point, the red dot, keeps popping up and it is also red on 85-5.9 and only air is blowing out
Posted by kyle_rusnak on
Anonymous
    New Friend:
Try and replace the swirl ring. We had the same problem and it fixed it. They cost around 35 bucks
Posted on Dec 20, 2010
Problem with heating up and staying heated.
Thermostat is sticking or heater core is blocked.do not keep running it or it is going to ruin the engine. It is running hot regardless if is blowing cool or hot air. Do not keep using the car.
Apr 16, 2017 | 1997 Oldsmobile Bravada
Problem heating up and staying heated.
the heater has went out of it or something is keeping it from trying to get it to warm up
Feb 08, 2014 | 1997 Oldsmobile Bravada
My cooler was working great and now it is not blowing any cold air inside the cooler. The fan is working but is blowing cold air into the car. What am I doing wrong. ??? Thanks.
Bear in mind that these coolers can also warm, depending on the orientation of the power cord connection. One end of the power cord has an arrow, the other end has a blue dot on one side and a red dot on the other. For cooling, connect power cord ends so that the arrow is on the same side as the blue dot. If the arrow is on the same site as the red dot, the cooler becomes a warming device, venting cold air outside the cooler and into the car. Could that be the problem?
Aug 02, 2011 | Koolatron P-85
Precedure on flushing brake line in my dakota
The best way to really flush out the brake lines it to thoroughly bleed the system in the normal manner. You could disconnect the brake lines at all the possible points and blow them through with alcohol and then blow them dry with air, but the bleeding method is quite adequate, you should use at least a pint of brake fluid and ensure that you bleed each point until clear new fluid comes out of each bleeder point. Always keep the reservoir fill to avoid getting air into the system. This is something that should actually be done at least every two years as routine service and do not be lured ito discussions about DOT 3 and DOT 4 fluids. DOT 4 has replaced DOT 3 fluid as a superior upgrade to the older outdated fluid. Silicone fluids are available you would need to clean out and overhaul you complete brake system to use them. They are not compatible with Glycol based fluids.
Jun 03, 2011 | 1999 Dodge Dakota
I have air suspension warning light on a daf cf 85 and keep blowing fues number one
EBS red warning beeping on screen, lazy breaks, any suggestions please?
Sep 22, 2010 | Daihatsu Rocky Cars & Trucks
Does not cool
Check you power line.
It should have a blue and red dot on it.
For cooling line the blue dot up with the arrow on the conector.
For warming change to the red dot.
If the unit is not working at all, it could be the fuse in the power plug.
If still not working, it could be a problem in the exchanger element.
Dec 01, 2009 | Koolatron P-85
Blue and red dots on all copies (dell3110
Sounds like your imaging drum, transfer rollers, or transfer belt could be contaminated. Using canned air, I'd try and blow out any sort of toner residue on these parts. They can often show up as dots or splotches when found on said parts.
May 27, 2009 | Dell 3110cn Laser Printer
RTO THERMAL DYNAMICS CUTMASTER 52 PLASMA CUTTER 1-5130- 1 Logo
391 people viewed this question
Top RTO Welding Tools Experts
Bill Boyd
ray gallant
Are you a RTO Welding Tool Expert? Answer questions, earn points and help others
