Question about Philips Magnavox 27MS343S 27" TV
We have a Philips Magnavox Model #TP3284C101 TV and plugged in a Durabrand DVD Model #DVD1002 player to it. It will only play in black and white on this TV. But when we plug the DVD player into another TV it plays in color. Is there a setting on the Philips Magnavox that we need to set? I tried Auto for the PAL and NTSC. I hooked the plugs up correctly because it plays on another TV just fine. I'm at a loss.
Posted by amdphoto on
specialistel
    Brigadier General:
  • 8,909 Answers
It sounds like you have a standard problem.
Is the TV you are using, that gives the black and white picture, the same as the other ie, both NTSC or PAL and both on RGB or Y-C or S-Video?
Check to see what is required and set the DVD player accordingly.
Hope that helps.
Posted on Dec 10, 2010
I have a Magnavox MWR20V6 and when I play a DVD it is only in black and white
Check your cables. Make sure the green, red, & blue, are in the correct order into the female connections on the back of your tv.
Nov 20, 2011 | Philips Magnavox MWR20V6 DVD Recorder/VCR
Have a Magnavox (31YA--??) DVD/CD recorder/player which due to moving and busy, I have NEVER installed; and have at the same time lost the manual. HAVE PLENTY of cords to match colored terminals; but "S"...
The S-Video "holes" the tv and the dvd player each have a S-Video.Hook it up with a one black video cable to the S-video to the hole in the tv and the other side to the S-Video in the dvd player.U have a RCA cable have 2 plugs lead each sides have 2 connections one RED,one White lead connections. Plug that RCA cable 2 connections in INPUT holes in the Tv ,and the other sides 2 connections one WHITE,ONE RED to the DVD player for sound.
Apr 03, 2010 | Philips Magnavox 50ML8105D 50" HDTV DLP TV
Only get 2 channels plus a blank av1 and av2
u can up grade ur ariel,use manal instal, or get freeview,freesat or sky
Jan 25, 2009 | Philips TP3284C 32" TV
Connecting to cable tv
if you have a cable that has 1 red 1 yellow and 1 white plug it will usually work plug the white cable into the white input and try alternating the yellow and red in the yellow input
Jan 01, 2009 | Philips Magnavox DVD/VCR Dual Player
Lost code book
I can not find codes for my tv.
Jan 05, 2008 | Philips Magnavox Learning Universal Remote
Instruction Manual
ask manualfox.com -they have it in their list!
Dec 30, 2007 | Durabrand DVD-1002 DVD Player
Quick Start Guide for Durabrand DVD 1002
place one end of the scartlead into av 1 or av 2  on back of  tv,
other end of scart to dvd player .
plug dvd player  in,and turn on dvd player it should detect the dvd and turn to dvd channel automatic .
Oct 23, 2007 | Durabrand DVD-1002 DVD Player
Magnavox mwd7006 dvd player hookup
if you are useing componet output and the pic is black and white you have them hooked up in the wrong order
The Cableguy
Oct 17, 2007 | Philips Magnavox MWD7006 DVD Player
Philips Magnavox 27MS343S 27" TV Logo
203 people viewed this question
Top Philips Televison & Video Experts
ThaMp3Doctor
ThaMp3Doctor
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
