Question about Adaptec APD-29160 MAC 64 BIT PCI SCSI ADAPTER 1870600 1870600 (APD29160)
Hi.. please help... After installing scsci card im getting message as bios not installed. It says that scsi bios not installed and that in device manager both scsci card and tape drive are installed properly... I checked the cables and all the connections and everythings looks fine...I don't know what the motherboard chipset is... only spec i can see is from the host adapter and scsi devices... host adapter - Adaptec AHA 2940W/UW os:xp Tape drive - tandberg data
DUSHYANT SINGH
    Sergeant:
  • 369 Answers
Hi when you start the pc and goes to the scsi utilities and scans for device its not finding the device attached to it sioit gives you this message you can see if the terminator connect to the device is properly connected and its in its place ,also press CTRL+A to get into the adapter setting and in the scsi utilities section scan the devices if it finds it then check the id of the device how much its set to it should not be the same of the scsi card id .by default scsi card id is 7 but be sure.
Posted on Dec 10, 2010
Compaq presario 2594 us laptop , after boot-up get message ( operating system not found) tried recovery disc, will not formate hdd , will get this message in windows set-up , SET-UP...
I've gist had the same problem after flashing bios ...
go to BIOS and change the SATA mode to IDE. it worked for me.
original instructions:
also You have to turn OFF (disable) the boot from network. The error your seeing is result of the network boot rom not finding PXE server to boot from. Again, be sure to disable boot from network.
PLUS it seems if only 128 MB is showing as memory then the memory sticks might be damaged and not able to retain information/data to complete the installation process. Best take them out clean it properly & replace & try again. Nothing to do with BIOS!
Jun 11, 2011 | Compaq Presario 2594us Notebook PC...
I have 1 note book LG X120 with windows 7. when im trying to install Windows XP proffessional through a USB CD ROM its showing the following Message * To specify additional SCSI adapters, CD-ROM...
Hi lionking2022!
Since this is a USB CD_ROM, you need change some settings in the bios for it to be detected and the system will actually boot from it.
1. You enter your BIOS
2. Look for the tab that will contain IDE settings
3. Change it to AHCI
4. Save and Exit
You may know try to boot from cd-rom and install your windows xp.
After the setup or installation is finished don't forget to changed it back to SATA or whatever the setting was.
Hope this will help.
Thank you for using Fixya,
avf110686
Mar 24, 2011 | AGPtek USB External CDROM Drive For LG...
I am running XP Pro SP3 and have installed a SCSI card and software for the scanner. When opening the utility I get error #5 cannot confirm scanner connection. Please confirm scanner's connection and SCSI...
Hello, just check you have a scsi terminator fitted to your scanner as without one you can get all sorts of bus errors. Also, keep the bus length as short as poss.
n.b. some of the later scsi devices are auto-terminating, so check the spec of your devices, and by the way,. don't plug and unplug your scsi bus whilst it is powered up as this can cause the hardware to blow (it's not like a usb plug and play bus)
Hope this helps!
nicam49
Dec 29, 2010 | Konica Minolta Dimage Scan Dual IV Film...
Configure & install two scsi disks scsi disks in ML 150 G2
The SCSI driver is required to installed during the initial boot up for installation when additional drivers are asked .the new models dont come with a Floppy drive so an external floppy drive can be used .The detection of HDD s must be at the startup by the Bios os SCSI card.
Feb 24, 2010 | HP ProLiant ML150 G2 Server
Dell Power Edge 2500 SCSI BIOS ERROR
You need to make sure that all drivers are properly installed. This usually means that the chipset for your computer has not yet been installed. Please go to support.dell.com for all the drivers for your computer.
Dec 19, 2009 | Computers & Internet
Which scsi connection do I use to connect internal
Normally you SCSCI cable has 4 to 7 connectors the ribbon cable normally the last or next to last for a terminator is installed on the end of cable most DAT drive are self terminating so you may need to remove the terminator off the end cable.
The power from the power supply 4 pins to tape drive I assume you are talking about the DAT drive
When dealing with servers with SCSCI you have 7 devices per channel on the back side of the hard drive backplane you will be able to add the DAT drive cable or a standalone controller 68 pin ‘
Let me know if you need more help I can post some photos where two of my servers have DAT drive installed one for a Adaptec control and the other using controller of the back plane of hard drive array.
Dealing with SCSCI maters not what contoler you use
Dec 04, 2009 | Dell PowerEdge 2600 Server
Unable to boot to anything external.
Save yourself some trouble. Pull a CD/DVD drive out of another computer or just buy one. They are very cheap. Connect the CD/DVD drive to the server and install the OS as usual.
If you are lucky WS2008 will already have a compatible SCSI/RAID driver. Otherwise, you will need to press F6 and install the driver from the floppy.
If this helps please vote for my solution.
Sep 07, 2009 | Dell PowerEdge 2600 Server
The bios is not installed
Go to BIOS, under Advanced > PCI Configuration. Disable Onboard ATA device if you're not using RAID. Also, make sure under Boot Menu that Other boot device do not show SCSI/Onboard ATA.
Hope that helps.
Mar 02, 2009 | ASUS P4P800-E Deluxe Motherboard
Dell Precision 670 throws "BIOS not installed!" message
i think this means that the harddrive needs to be refoarmated as the bios sees no logical drive in which the boot.ini file resides
Sep 01, 2008 | Dell Precision Workstation 670 PC Desktop
Rathwynn
Hey there
The most common cause is that setup does not have the driver for a SCSI device or is detecting storage devices in the wrong order, such as that CD-ROM drive first.
Press F6 when setup first starts and provide a driver for the mass storage device that will hold the operating system files.
Check to make sure all adapters and controllers are working properly.
Check power to all devices. Reseat adapters and controllers.
For SCSI devices ensure:
1. The SCSI cabling is properly installed.
2. SCSI devices are terminated.
3. SCSI devices are correctly addressed. And
4. The BIOS correctly recognizes all SCSI adapters.
Also, be sure the SCSI boot drive is addressed as 0.
Check the manufacturer's recommedation for configuring SCSI adapter and Hard Disk Drives. Try replacing the adapter before replcing the drive(s).
For EIDE Drives:
1. Check the controller.
2. Ensure file I/O and disk access are set to standard. And
3. Ensure that the system drive is the first device recognized by the controller.
For IDE and ESDI drives:
1.Check the cabliing and controller.
2. Check the Drive setup in the BIOS for master/slave relationships. And
3. Ensure the drive is properly recognized in the BIOS.
Gimme acknowledge by rating me.
thanx
Romy
Aug 05, 2008 | Intel Motherboard
Computers & Internet Logo
248 people viewed this question
Top Adaptec Computers & Internet Experts
John Dio
Level 1 Expert
Robert Graf
efs_perpends
efs_perpends
Are you an Adaptec Computer and Internet Expert? Answer questions, earn points and help others
