Why are my photos coming out wet and grainy ? Its like the ink hasn't taken to the paper properly and the colours are weird too. Im using gloss paper and seem to have settings correct for example its set on 'best photo' and on gloss paper. Would it be that ink cartridges are low? But i printed out on normal A4 paper to see and the colours seemed fine.Could the paper im using be incompatable with printer but i wouldnt think that be the case. I was using canon paper and just started with another brand.Thanks.
Well, it would be good to know why the photos are not good quality... like blurry or bad color or? Are you using a good paper? I have great luck with Canon glossy, and love the matte paper from Staples. Matte is actually easier and all around better color saturation, I find. I guess that you are using too much saturation of ink... see if your dialog box for printer options has a way to make saturation less intense. Also, I assume you are using the same dialog box to choose the type of paper. That is important, since different papers absorb ink at different speeds and amounts. I hope that helps... keep trying!
Printing photos on ordinary paper do not come out well because the ink soaks into the paper like a blotter. I suggest you use semi-gloss or high gloss photo paper for best photo quality prints..
Most ink jet printers have a self cleaning you can do.
The fact that you're getting shades of green usually indicate that the red is not printing properly.
There should be something like a printer properties menu. Find it and adjust the colour controls to manual and reduce the magenta settings etc. Also make certain you have the right type of paper selected on your printer, to the one you are using.
all the dx /cx range do this when printed on the high quality settings you just have to let ink dry about half hour or use a lower seting when you print on gloss paper hope this helps
Download the proper drivers from hp.com - DON"T use standard Windows drivers.
When you have the proper drivers installed, you will find an "Advanced" tab in your "Printing Preferences" where you can set "Ink Volume" and "Dry Time".
Try using less ink and a longer dry time.
Also, make sure you're using photopaper that is designed for "INK JET PRINTERS".
(Laser Jet paper won't work).
Any photo that you print on glossy/semi-gloss paper will be wet as it emerges from the printer (especially ones requiring lots of ink).
You could manualy "catch" each one and set aside to dry, which should only take a minute or two.
Professional printers use a special drying powder and timed spray rig when printing on coated cover stock and glossy materials.
If your normal print looks OK, make sure that you are printing your pictures on the correct side of the photo paper. Most photo paper will only print properly on one side. If you print on the other side, the image looks very grainy and faded, and the ink will still be quite wet when it comes out of the printer.
its ok I solved it! I didn't realise that all the photo cartridge does is gloss over the colour picture produced by the colour cartridge. I simply had to replace the colour cartridge which had run out, so now its all working perfectly!!
