Biostar G41M7 Motherboard  Intel Pentium Dual Core E5300 Processor Bundle (G41M7 WBX80571E5300) Logo
A
Anonymous Posted on Dec 10, 2010
Changing FSB on G41M7? FSB is set at 200 and although not grayed out, will not change. Disabled EIST and C1E but still no change. Updated to latest 8-3-2010 bios and now help. Searched web and seems everyone else has no problem. G41M7, Celeron E3300, 2G 6400 memory (800 speed)
1 Related Answer
Anonymous
  • 20 Answers
  • Posted on Sep 14, 2009
SOURCE: setting yp memory
Here is some great PC solution by Some FIXYA EXPERT. Get any kinds of PC solution from bellow.
  1. Intel MotherBoard
  2. Mercury Motherboard
  3. Gigabyte Motherboard
  4. MSI Motherboard
  5. P5GC-MX/1333 Motherboard
  6. ASUS Motherboard
  7. IBM
  8. Packard Bell
  9. via
khandan19
System reguirements to inrease ram memory
Ram Memory typically operates at half of the frequency rate, ('Speed'), that the Processor's -> FSB does.
Your motherboard supports Processors that have either a 400MegaHertz Front Side Bus, (400MHz FSB), or 533MHz FSB, or 800MHz FSB.
(Northwood Core for 400MHz FSB. The rest is in the other solution I provided)
Processor has a 400MHz FSB?
You can use DDR Sdram ram memory that is 266MHz.
(PC2100)
Processor has a 533MHz FSB?
You can use DDR Sdram ram memory that is either 266MHz, Or 333MHz.
(PC2100 and PC2700 respectively)
Processor has an 800MHz FSB?
You can use DDR Sdram that is either 266MHz, or 333Mhz, or 400Mhz.
(PC2100, PC2700, and PC3200, respectively)
NOTE*
When using a processor that has an 800MHz FSB, and using PC2700, (DDR at 333MHz), the PC2700 ram memory will run at ->
320MHz.
JEDEC has set the voltage requirements for DDR Sdram at 2.5 Volts.
'Performance' ram memory that is DDR Sdram may use higher voltages.
Not recommended unless you know how to overclock.
Although the motherboard, and the ram memory module may have SPD, it doesn't always work,
http://en.wikipedia.org/wiki/Serial_presence_detect
A lot of times you are faced with going into BIOS Setup, and changing the ram memory voltage, IF BIOS Setup has this feature.
This is why I say overclocking experience helps tremendously.
You want Low Density, Unbuffered, Non-ECC, and a CL of 2.5 for PC2700, and a CL of 3.0, (3) for PC3200.
[Why would anyone want to run PC2100> Lol! ]
For additional questions please post in a Comment.
Regards,
joecoolvette
Cubase 4
During your computer's boot sequence, watch for a notice telling you which key to strike to ENTER SETUP. This will take you to your BIOS management. Find and disable Intel SpeedStep, C1E, or EIST, or related PowerNow! settings on AMD processors. These power saving settings are designed to slow down or shut down one or more cores of multi-core processors during times when the operating system thinks that the processing power is unnecessary, but running advanced DAW software such as Cubase draws power at very near the full system capacity, and it takes a long time to reboot the temporarily suspended processor cores. During this core reboot lagtime, Cubase is often deprived of the processing power needed to route audio signals through its complex internal bussing system (Steinberg's patented VST system link), and this power loss causes it to crash. If you disable the SpeedStep settings in your BIOS, you may notice a very gentle rise in your electric bill, as your computer's processor will be running at full capacity all the time, but you can always re-enable SpeedStep when you're not planning on recording anything.
2helpful
2answers
I have a Question for upgrading my machine. I havent had the chance to dabble with Dual-Processors.... This will be my first time. Q: Is it possible to utilize a Xeon 2.66GHz x3330 Processor and a Pentium...
You can only mix the same family processors with different stepping and speed. Pentium D is not in the same family as a Xeon. So no, you can not. For as long as the processors are in the same family, you can mix dual core with quad core and even different speed.
2answers
What are the compatible processor for asus p5p800 mx
Asus P5P800-MX Motherboard Features
64bit CPU support
64-bit computing, the next generation technology to replace current 32-bit architecture, delivers advanced system performance, faster memory access and increased productivity. This motherboard provides excellent compatibility and flexibility by supporting either 64-bit or 32-bit architecture.
Intel EM64T
Intel EM64T (Intel Extended Memory 64 Technology) allows processors to run newly written 64-bit code and to access larger amounts of memory, which delivers exceptional graphic performance and higher data processing speed. Digital media applications can take advantage of Intel EM64T in high quality video and audio processing as well as 3D rendering.
Intel EIST
Intel EIST (Enhanced Intel SpeedStep technology) automatically adjusts Intel 64-bit processor voltage and core frequency according to system performance demand, establishing a self-managed, lower-power consumption, less heat and quieter environment. Combined Intel EIST and ASUS Q-fan technology (adjusts fan speeds according to system loading), this motherboard provides excellently quiet, cool and efficient platform for Intel lovers.
Intel 865GV chipset
Leveraging the Intel 865GV chipset to support P4 CPU on 800MHz FSB, Dual-channel DDR 400 memory, Intel Hyper-Threading Technology, and a full-range of advanced features, P5P800-MX really delivers a full-value, high-performance solution for today's most demanding tasks.
Intel LGA775 Pentium 4 CPU
This motherboard supports the latest Pentium 4 CPU from Intel in LGA775 package. With 800MHz FSB, 1 MB L2 cache, Hyper-Threading Technology and core-speeds up to 3.6GHz and beyond, Intel's LGA775 Pentium 4 is one of the fastest desktop processors to date.
In setup
Here are the settings.
The fine clock ratio stayed at 0.5 after I loaded optimized defaults.
Robust Graphics Booster___________ [Auto]
CPU Clock Ratio ____________ [8]
Fine Clock Ratio ____________[0.5]
CPU Host Clock Control_ [Disabled]
CPU Host Frequency (MHz)__________ [333]
PCI Express Frequency (Mhz)_______ [Auto]
C.I.A. 2__________________________ [Disabled]
System Memory Multiplier (SPD)____ [Auto]
DRAM Timing Selectable_______ SPD __ [Auto]
Performance Enhance = [Turbo]
CAS Latency Time________________ Auto (7)
Dram RAS# to CAS# Delay_________ Auto (7)
Dram RAS# Precharge Delay_______ Auto (7)
Precharge Delay (tRAS)__________ Auto (20)
ACT to ACT Delay (tRRD)_________ Auto (4)
Rank Write to READ Delay________ Auto (5)
Write to Precharge Delay_________ Auto (10)
Refresh to ACT Delay______________ Auto (60)
Read to Precharge Delay__________ Auto (5)
Static tRead Value_______________ Auto (6)
Static tRead Phase Adjust________ [Auto] (0)
CPU/PCIEX Clock Driving Control [800mV]
CPU Clock Skew Control [normal]
GMCH Clock Skew Control [Normal]
System Voltage Control____ [Manual]
DDR2 OverVoltage Control__ [normal]
PCI-E OverVoltage Control_ [normal]
FSB OverVoltage Control___ [normal]
(G)MCH OverVoltage Control [normal]
CPU Voltage Control_______ [1.25]
Limit CPUID Max. to 3.....................: [Disabled]
No-Execute Memory Protect............: [Enabled]
CPU Enhanced Halt (C1E)................: [Disabled]
C2/C2E State Support....................: N/A
x C4/C4E State Support..................: N/A
CPU Thermal Monitor 2(TM2) ...........: [Enabled]
CPU EIST Function.........................: [Enabled]
Virtualization Technology................: [Enabled]
Integrated Peripherals
Legacy USB Storage Detect___________________[Enabled] *Note* Must be enabled to flash from USB
Hope this Helps, Please Rate My Response! Thanks!
PREM
AOpen ax4bs upgrade bios to up fsb?
Hi PapaFreeBird,
Go Lynryd Skynrd!
I'm only fairly knowledgable on this board, but I am virtually certain that you are chipset limited at the 100Mhz level. I don't think there is any way to work around it, short of upgrading the board.
I know this isn't what you hoped to gear, but I think you'll probably be pretty happy with the system anyway, at least until you save up for a new MB.
I hope this info is helpful. If you feel it is appropriate, I would appreciate a Fix Ya rating on this solution. Good luck!
Bob
Overclocking past 2.7GHz with Q6600 GO step
Please check BIOS update from mainboard manufacturer website it there has a solution for overclocking and others. Else don't push your motherboard so hard, you might get extraneous problem.
Can't use compatible ink
You need a chip-resetting tool.
Or use the printers software utilitie changing ink cartridge, some printers insist that you go into your printer software/program. to inform or communicate with the printer, that you are changing a Cartridge. then the printer, will move the printhead to the desired position, to remove the cartridge.
When the new cartridge is installed, the printer is set to look for new changes. make sure you,ve inserted the cartridge fully into it,s slot ( holder ) push until you get a slight click.
If you,ve disabled Status monitor, then your printer cannot output the Cartridge Status. ( empty-Full )
mike @ Compurepair.
Top Biostar Computers & Internet Experts
 Grubhead
Grubhead
Grand Canyon Tech
Grand Canyon Tech
Are you a Biostar Computer and Internet Expert? Answer questions, earn points and help others
