Question about LaCie Big Disk External USB 2.0 1TB Hard Drive
My lacie hdd 500GB, i forgot the password to get into the online interface someone please tell me what the defult might be and if there is a way to reset the password if it is not the defult without loosing all the data!
Posted by mmagrath11 on
Anonymous
    Sergeant:
  • 269 Answers
-Turn the drive off
-When pushing the power button to switch the drive ON, keep holding the power button until the blue LED of the power button starts to flicker and then release the button.
-Then, after 1 or 2 seconds the button's LED should flicker with another rhythm.
-Push the button again. After a few seconds, the LED will flicker again but with a third different rhythm. Release the button. -If the drive turns off then the power button was held in two long during the last step, please try again if the drive powers off.
The product should now be reset to its factory default settings.
In the logon window that opens, type:
    User Name: admin
    Password: admin
(This user name and password is the factory default; if you have already created a user, input your user name and password. This is the administration logon and you can change it for more security if you choose.) The NAS Administration page will open in your default browser.
Posted on Dec 10, 2010
Menu password
I forgot my password ( DVR - HONEYWELL )
MODEL - HRDP8D250 ?
Mar 23, 2014 | Honeywell HRDP16D500 16Channel DVR 500GB...
LaCie Rikiki USB 3.0 connection broken
Can you open the case and remove the HDD? I looked at the specs on the device and I didn't see what interface the drive is, I would assume it's a SATA, I don't know for sure. Can you ID it? You can get a USB 2.0 to IDE/SATA Adapter: http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=3276554 You can remove the HDD, here are some examples : http://www.ultraproducts.com/applications/category/category_slc.asp?CatId=2781&name=2.5
>>>>I found the specs on the HDD inside, it is a SATA, (samsung hm500ji) : http://www.newegg.com/Product/Product.aspx?Item=N82E16822152168 , You can use the adapter to remove data and erase HDD and return for replacement under warranty.
Dec 19, 2012 | LaCie 500GB Rikiki USB 3.0 Portable Hard...
Help is it possibol to upgrade lacie big disk extreme 500gb to 1tb or 2tb. thanks. FC
Maybe. If the current disk-drive has an IDE interface, then your 500GB disk-drive already is the largest IDE disk-drive ever produced. Or, if the current disk-drive has a SATA interface, then the sky (or the thickness of your wallet) is the limit.
Nov 15, 2010 | LaCie Big Disk Extreme 500 GB Hard Drive
Having a similar problem with the La Cie 500gb. Powerbook G4.
The problem that has been inherent with all LaCie external harddrives, is the interface in the case itself.
Interface:
All external harddrives have a Style of harddrive that is used in a laptop, or one that is used in a desktop computer.
Laptop harddrives are 2-1/2 inches across in width.
Desktops are 3-1/2 inches across.
Your LaCie will have a 3.5, (3-1/2) inch desktop style harddrive, inside the case.
There are two main Types of harddrives.
IDE and SATA. (There is also a newcomer. SSD. SSD isn't being used in LaCie external harddrives at the moment, to my knowledge)
Your LaCie will use a SATA harddrive inside it.
This is an example of an average SATA harddrive,
http://en.wikipedia.org/wiki/File:Hdd.jpg
The photo of this harddrive is tilted at an angle, that doesn't readily show the interface connection, but it helps to explain.
At the bottom of this harddrive in the photo, and to the left, is the interface area.
Viewing the harddrive, look at the four metal pins on the extreme right of the harddrive. To the left of these pins is the Jumper pin area. (Has a white jumper on two of those pins)
To the left of the Jumper area is an opening, and to the left of that, is a long slot. The first small slot area is for the 7-pin Interface cable.
(Data cable) The next slot to the left, is for the 15-pin power cable.
This 7-pin Interface mates up to socket holes in a connector, of the case of the LaCie external harddrive.
It is this interface connector, inside the LaCie external harddrive case, that is the problem.
Solution?
Buy a quality, in-expensive External Enclosure, take the harddrive out of the LaCie, and install it in this enclosure.
Examples of 3.5 Sata External Enclosures,
http://www.tigerdirect.com/applications/category/category_slc.asp?CatId=2780&name=3.5-eSATA-enclosure&Nav=|c:2778|&Sort=0&Recs=10
(From $15 to $35, is a good range for a decent external enclosure)
Jul 22, 2009 | LaCie External USB 2.0 500GB 7200 RPM 500...
LaCie 2d 500GB isnt recognized
Has the drive been formatted? Before using a hdd it has to be formatted. In Windows XP you have choices of FAT 32 or NTFS format. Hope this helps.
Dec 17, 2008 | LaCie 500GB d2 Quadra 500 GB USB 2.0 Hard...
Is my LaCie External USB 2.0 500GB fried/dead???
You're not missing any step at all, because with SATA hard drive if its really working your computer should
automatically detect it and since this hard drive suddenly stop working there's a possibility that its already
fried but if you want you can try this hard drive again to a different computer and if still not detected by
second computer its already dead.........
Nov 07, 2008 | LaCie External USB 2.0 500GB 7200 RPM 500...
LaCie 500GB external HDD stoped working ?
It sounds like its an internal problem with the pcb board inside,which may not be an actual problem with the hdd it self but the mother board.my advice would be to change the board that links between the hdd and the usb cable.
Jul 19, 2007 | LaCie (300728U) 250 GB Hard Drive
Open Questions:
LaCie Big Disk External USB 2.0 1TB Hard Drive Logo
1,816 people viewed this question
Top LaCie Computers & Internet Experts
Ekse
ChinthakaJ
ChinthakaJ
Marvin
Marvin
Are you a LaCie Computer and Internet Expert? Answer questions, earn points and help others
