Question about Panasonic CQ-VD7003U Car DVD Player
How to reset security code on panasonic cd player CQ-VD7003U
Posted by socomsjay12 on
Wilson Martinez
  • 171 Answers
ID-CODE
ID Code Setting
Prior to operating this unit, it is advisable to assign a 4-
digit ID code for security. Once the ID code has been set,
the unit cannot be operated if the main power supply is
disconnected then re-connected. It is electronically locked
so that a thief cannot use the stolen unit unless that person
knows the code you have set.
The ID code operation must be performed only by the
person to whom the unit belongs.
Generally, it is not necessary to enter the ID code each
time when using the unit if it has not been disconnected
from the main power supply (car battery).
to 4 digits numeric code
default: none
How to set your ID code (for the first time)
q Enter an 4 digit ID code.
w Enter the same 4 digit ID code again.
How to change your ID code
q Enter the preset (old) 4 digit ID code. If the wrong ID
code is entered, a new ID code cannot be registered.
w Enter a new 4 digit ID code.
e Enter the new 4 digit ID code again.
How to cancel the known ID code
code is entered, it is not possible to cancel the ID code
function.
w Touch and hold until "COMPLETED!" is displayed.
The ID code canceling procedure is completed.
The unit now works without an ID code.
Note:
¡Should your unit ever require service, cancel your ID
code before sending for repair.
¡The ID code setting cannot be eliminated even by the
memory clear function.
¡The inputted code is not displayed for your security.
0 9
Caution
¡Record your registered ID code and keep it in a
secure location. (Fill in the ID code memo (a
page 46).) If you forget it, you will be unable to use
the unit. In case you forget the ID code, please
consult your nearest Panasonic Service Center.
Posted on Dec 10, 2010
Shirley Serrine
    New Friend:
It worked although boyfriend had to hold down right track (fast forward) button. Each time I did it myself, nothing happened and I tried at least a dozen times. Once you get your stereo working again, change code under "user" and REMEMBER it. The old code will already be entered so you just have to enter new code twice to save it.
Posted on Aug 24, 2018
No puedo desbloquiar stereo panasonic cq-vd7003u
Try to contact at " [email protected] " and send us details about serial and model radio.
Feb 28, 2011 | Panasonic CQ-VD7003U Car DVD Player
What harness can fit a Panasonic CQ-VD7003U
you can probably get a harness at pacparts.com.
Jan 19, 2011 | Panasonic CQ-VD7003U Car DVD Player
I one problem I need the code CQ-VD6503u car DVD player please
Basically iniorder to unlock the device hold down the right track button and press the little reset button with a paper clip, continue holding down the right track button until the device has reset.
Also let me know from where did you purchase the product or have you found it.
Jun 08, 2010 | Panasonic CQ-VD7003U Car DVD Player
Tengo una panasonic CQ-VD6503u car DVD player y necesito el codigo para debloquear por favor
Hi
With due respect to your language can you please post your problem in english so that it will be easy to understand your query and reply accordingly.
Thanks for contacting fixya.com
Jun 07, 2010 | Panasonic CQ-VD7003U Car DVD Player
Park brake code for cq-vd7003u so passenger can watch while car is moving
there isw a wire that goes to the park brake switch from the stereo, disconnect this wire and you can use the dvd function when moving, but it is probably illegal to do so.
Apr 28, 2010 | Panasonic CQ-VD7003U Car DVD Player
I need 4 digit codes for a panasonic cq-vd7003u
i have heard that if you hold down the fast forward button for 7 seconds it will reset it
Feb 28, 2010 | Panasonic CQ-VD7003U Car DVD Player
Lost security code for my panasonic VD7003U DVD player for my car
call the panasonic costomer service they should have the code.
Feb 02, 2010 | Panasonic CQ-VD7001U Car DVD Player
Panasonic cq-vd7003u ipod video trouble
The problem is that the panasonic cq-vd7003u does not support that function which sucks cuz i have one 2 the slightly newer verision PANASONIC CQ-VD7005U does have that feature. so sorry.
Mar 30, 2009 | Panasonic CQ-VD7003U Car DVD Player
How do i turn off the camera mode in my car stereo panasonic cq-vd7003u
go to the panasonic web site and get the manual for your car stereo its free and it will show you how to run your system
Jan 29, 2009 | Panasonic CQ-VD7003U Car DVD Player
Security code.
its Easy!!!!!! Hold the right track button to the right or 10 secs and it works!!!!!!!!!
Sep 28, 2007 | Panasonic CQ-VD7003U Car DVD Player
Panasonic CQ-VD7003U Car DVD Player Logo
1,390 people viewed this question
Top Panasonic Car Audio & Video Experts
xxxxxx xxx
Marvin
Marvin
Michael Thomas
Michael Thomas
Are you a Panasonic Car Audio and Video Expert? Answer questions, earn points and help others
