Question about Hayward Pool & Spa
• The low-pressure switch senses the refrigerant pressure in the sealed refrigeration system to protect against certain conditions that could be detrimental to compressor life. The switch turns the heat pump off in the event of loss of refrigerant, fan motor failure, evaporator freeze-up, or airflow blockage. The heat pump will automatically reset the switch after the system pressure rises to the
normal operating pressure. The display will show "LP", if this switch is tripped.
For more info, look at page 7 on this manual:
http://www.hayward-pool.com/pdf/manuals/Manual280.pdf
Either you need to defrost the coils, clean the air-flow chamber, get a new air-flow switch or you are running low on refridgerant.
Posted on Dec 09, 2010
Dec 06, 2014 | 2002 Ford Expedition
Mar 23, 2013 | Rheem 40 Gallon FVR NATGAS Low WATER...
Mar 05, 2013 | Water Heaters
Aug 16, 2012 | Refrigerators
Jul 29, 2012 | Water Heaters
Mar 05, 2010 | Washing Machines
Feb 15, 2010 | Mr. Heater MH125KT Utility
Aug 21, 2009 | Rheem Water Heaters
Jul 08, 2009 | Pentair Minimax NT Heater
Jun 23, 2009 | Rinnai Vent Free Gas Heater/: 6,000 BTU...
393 people viewed this question
We need to know what model heater this is in order to help.
