Polaroid PhotoMax Fun 320 Digital Camera Logo
Posted on Dec 09, 2010
Draiver polaroid digital 320 photo max - Polaroid PhotoMax Fun 320 Digital Camera
Anonymous
Level 1:
Habit-Forming:
New Friend:
  • Contributor 12 Answers
  • Posted on Dec 09, 2010
Anonymous
Contributor
Level 1:
Habit-Forming:
New Friend:
Answers
12
Questions
0
Helped
2038
Points
35
1helpful
2answers
How to download photos using windows xp
yes it has a USB I JUST DONT HAVE A DISC TO PROGRAM IT ON MY PC
Software compatibility
Unfortunately this sofware only works with windows 95/98, but if you use windows XP compatability wizard it should work. Go to this site for help on how to do it as I would have take up the whole page to type it. http://polaroid.custhelp.com/cgi-bin/polaroid.cfg/php/enduser/std_adp.php?p_faqid=1685&p_created=1001455215&p_sid=t-BCyfki&p_accessibility=0&p_lva=&p_sp=cF9zcmNoPSZwX3NvcnRfYnk9JnBfZ3JpZHNvcnQ9JnBfcm93X2NudD0xMjAmcF9wcm9kcz0wJnBfY2F0cz0wJnBfcHY9JnBfY3Y9JnBfc2VhcmNoX3R5cGU9YW5zd2Vycy5zZWFyY2hfbmwmcF9wYWdlPTEmcF9zZWFyY2hfdGV4dD1YUA**&p_li=&p_topview=1
Why does my Fun! Digital 320 camera hold more than 18 images?
The literature packaged with the Polaroid Fun! Digital 320 camera does indicate that the maximum number of images is 18. However, the actual number of images is, in part, dependent on the complexity of the scenes you are trying to capture. Scenes that are complex (contain a high degree of detail) require more space on the camera's memory chip. Photos of less complex scenes (not much detail in the photo) take up a lesser amount of the camera's memory, freeing up space for additional images to be stored.
Why do some of my pictures come out dark or with shadows?
Your Polaroid Fun! Digital 320 camera does not have a flash. If pictures are coming out dark, it's because there wasn't enough light in the surroundings when the picture was taken. Remember, it's important to take photos in brightly lit surroundings. When taking pictures indoors, make sure that the room has bright lighting. For best results, take pictures during daylight hours with a combination of indoor and outdoor light, preferably near a window.
What is included with the Fun! Digital 320 camera?
# Fun! Digital 320 Camera # Serial interface cable # 9-volt battery # PhotoMAX quick start guide # Polaroid PhotoMAX Image Maker Software CD-ROM
Why do my Fun! Digital 320 pictures come out blurry?
Blurry images can be caused by any or all of the following: * Distance/Focus range -- the Fun! Digital 320 has a fixed focus range of 3 - 6 feet (1.8 meters) for brightly lit indoor photography, 3 ft. (1 meter) - infinity for outdoor photography. For best results, make sure that the camera is at least 3 feet away from the subject(s) when taking pictures. * Camera/Subject movement -- This is a common cause of blurriness, especially in low-light situations (see Lighting below). Hold the camera as steadily as possible while taking a photo, or use a tripod (a tripod mount is located on the bottom of the camera). Avoid subjects that are in motion. * Insufficient lighting -- the Fun! Digital 320 is designed for taking photos outdoors or in brightly lit environments. Inadequate lighting can exaggerate camera movement and contribute to blurred, "muddied," or uncrisp images. * Lens condition -- Check the lens periodically for smudges. If necessary, wipe the lens clean with a soft, lint-free cloth. Do not use cleaning solutions or chemically treated tissues. * Enlarging images using software -- otherwise normal digital images can appear to become blurry and/or blotchy when over-enlarged in software. To see an image's "true" appearance, use the software's Zoom In or Zoom Out feature to view it at 100%.
Computer "hangs up" when displaying the Polaroid Album in PhotoMAX
This error or system hang-up is usually caused by: 1. the camera driver software attempting to read a corrupted photo; or 2. there are too many photo thumbnails stored in the PhotoMAX temporary storage area. In either case, the problem can be corrected by manually deleting the Fun! Digital 320 camera thumbnails from the Polaroid Album (using the Windows Explorer or My Computer icons). Follow these steps to delete the Fun! Digital 320 temporary files: Step 1 -- Locate the temporary photo files If you are familiar with Windows Explorer, simply browse directly to: C:\Program Files\Polaroid\PhotoMAX SE\Digital 320 If you are new to browsing the file system, follow these steps: 1. Double-click on the My Computer icon on the desktop. 2. Double-click on the C: drive. 3. Double-click on the Program Files folder. 4. Double-click on the Polaroid folder. 5. Double-click on the PhotoMAX SE folder. 6. Double-click on the Digital 320 folder. Step 2 -- Delete the temporary photo files Inside the Digital 320 folder, you will see many files, most of which will be bitmap image files. All of the bitmap files that start with dsc_ (example: dsc_005.bmp) must be deleted. To delete the files, you can either drag them into the Recycle Bin, or highlight each file by single-clicking on it and pressing the Delete key on the keyboard. To select multiple files at once, hold down the Shift key on the keyboard as you click on them, then press Delete. IMPORTANT: Do not delete the following files from the Digital 320 folder: * 320popup.rtf * DscDrv_Polaroid.dll * Polaroid Album.exe
320 x 240 dpi Photo Transfer Problem
Certain computer hardware and software configurations conflict with PhotoMAX or PhotoImpression software. As a result, you may not be able to transfer 320 x 240 dpi photos from your Polaroid Fun! Flash 640 digital damera. This problem does not occur if you use the camera's default resolution of 640 x 480 dpi.
Windows NT and Windows 2000 Compatibility
A new camera TWAIN driver (version 2.2L) compatible with Windows 2000 is now available for download. The new TWAIN driver will allow photo transfer using most image viewing or editing programs that are TWAIN compatible.
Top Polaroid Cameras Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Tom Shanks
Tom Shanks
Are you a Polaroid Camera Expert? Answer questions, earn points and help others
