Question about Vizio Televison & Video
Vizio 46" Gallevia Flat Screen
Posted by ssands44 on
  • dawnlewis196
    dawnlewis196 Jul 30, 2012
    hi steve. the same exact thing happened to our tv last night, did u ever fix the problem or find out what was wrong
Paul Storey
  • 47 Answers
Any display in the corners of channel number av etc ?? if you turn the volume up and down does that show on the display if not likely to be a dead panel
Posted on Dec 09, 2010
1helpful
Vizio Gallevia can't see whole picture
Check the button for picture size and adjust accordingly.
VIZIO GALLEVIA modle VIZIO GV47L FHDTV10A
Most plasma TV's have secoundary power boards, witch can be the cause, now I would try if I where you is to unplug it and let it set a hour or two, if that did not work then the tv will need to be looked at locally. The cause can be a bad power board inside the TV witch is a major cause why a Tv would have a power light put no function at all.
Hope this helps if you have any questions as to what parts to buy www.partstore.com is a best resource.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edwy_1a56970cf1ea4620
When I turn on my Vizio Gallevia 42" tv it Just Shows a Blue screen and no signal then turns off
Have you got anything connected to the TV? If so, make sure they are powered on, and all connected correctly.
Hope this helps
TV_Doctor
I was watching tv and it went to an all black the vizio logo still lights up but just a black screen and it wont turn off or any thing else
Unplugging it will surely turn it off. Keep it out for awhile and then plug it back in. See what happens then?
Did you somehow lost your signa input to it?
Maybe it had a hardware/software hangup - like a computer freezing. I hope it gets better?
2helpful
2answers
I went to turn on my Vizio and the scrren was
Do you have back light when turning on the TV? if you do then just replace the main board should resolve the problem. if you do not have back light, you will need to replace the inverter board(s) depending on your model. The inverter board(s) is located on the left side of the TV facing back of TV. you may have two inverter boards depending on your model. the other is located on the right side of the TV. Both mount vertically.
1helpful
I turn on the tv and it has a blue screen and no
Just try to reset so picture will back to normal again, some LCD TVs have a reset button. If available and accessible, try using the reset buttons before using the steps below. Using the reset buttons can save time.
1. Unplug the LCD TV power cord from the power outlet.
2. Unplug any connected devices (DVD, Set-top boxes, etc...)
3. Press and hold the LCD TV power button for five seconds.
4. Plug the LCD TV power cord back into the power outlet and turn on the TV.
5. Open the on-screen menu to confirm that the LCD TV is responding again.
6. Turn off the LCD TV and reconnect the devices.
7. Turn on the LCD TV.
Hope it may help you;
Regards;
VOTIT
My Vizio 32" Flat Screen suddenly turned blue and "no Signal"
Check the cable connector. If it is OK then the turner has gone bad. Replace main board will fix it.
3answers
TV NOT WORKING
blue screen no signal
Televison & Video Logo
Top Vizio Televison & Video Experts
Ekse
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
